function used but not defined
mvliege
PostPosted: Tue Aug 05, 2014 7:17 am     Reply with quote
I used internal oscillator with PIC18F46K22 but, I have faced this problem (it's delay problem in the lcd.c, it appears when I complied. )
"function used but not defined delay_ms 609 SRC=1356"
problem is about using internal oscillator?
#include <main.h>
#FUSES INTRC_IO
#include <lcd.c>
int a=0;
#use delay(internal=64MHz)
#INT_TIMER0
void  TIMER0_isr(void)
   set_timer0(15536);
   if(a==1)
   output_low(pin_c0);
   output_toggle(pin_c1);
   printf(lcd_putc,"\f ERROR \n PLC CHECK");
#INT_EXT
void  EXT_isr(void)
if(input(pin_b0)==1)
a=1;
Mike Walne
PostPosted: Tue Aug 05, 2014 7:55 am     Reply with quote
What happens if you put this line
ahead of this one?
#include <lcd.c>
Mike
mvliege
PostPosted: Tue Aug 05, 2014 8:11 am     Reply with quote
hi mike,
thank you for your reply,
here is you can find picture about this problem. Problem is about in "lcd.c"
thank you so much for your help
BS,
https://yadi.sk/i/ULRIdr74Z7zkJ
https://yadi.sk/i/gLGDV7PyZ82dc
https://yadi.sk/i/lCG3mpypZ82iM
dyeatman
PostPosted: Tue Aug 05, 2014 9:20 am     Reply with quote
He is trying to tell you, SWAP the two lines in your code.
Move #use delay up and move #include <lcd.c> down....
You cannot use the delay_ms() function before the #use delay line.
Google and Forum Search are some of your best tools
Mike Walne
PostPosted: Tue Aug 05, 2014 3:14 pm     Reply with quote
This line
tells the compiler how to handle the 'delay_us(xx)' and 'delay_ms(xx)' instructions.
To process this line
#include <lcd.c>
the compiler needs to know how to deal with one or both of the 'delay_yy(xx)' instructions.
(There are delay_yy(xx) instructions buried within 'lcd.c'.)
The compiler is complaining because you are presenting it with code in the wrong sequence.
Mike
mvliege
SOLVED!!!
PostPosted: Wed Aug 06, 2014 2:52 am     Reply with quote
Very Happy Very Happy SOLVED!!!
Thank you guys, I found out how to use "delay"
This code solved the problem below,
#use delay(internal)
thank you,
BS
Mike Walne
PostPosted: Wed Aug 06, 2014 9:45 am     Reply with quote
So, what is your complete code?
Mike
mvliege
PostPosted: Wed Aug 06, 2014 11:55 pm     Reply with quote
Hi Mike,
these are my full codes:
PS the problem is that Altough I have already mentioned frequency with pwm (495Hz) but when I run the program on the PIC, I could see frequency is 990Hz. Where is the problem?
#include <main.h>
int1 a=0;
int16 b=0;
float v=0;
#INT_TIMER0
   set_timer0(3036);
   if(a==1)
   output_low(pin_c0);
   output_high(pin_c1);
   printf(lcd_putc,"\f ERROR");
#INT_EXT
void  EXT_isr(void)
   a=1;
   set_tris_c(0xf0);
   lcd_init();
   setup_adc_ports(sAN0);
   setup_adc(ADC_CLOCK_DIV_2);
   setup_timer_0(RTCC_INTERNAL|RTCC_DIV_4);      //52,4 ms overflow
   enable_interrupts(INT_EXT);
      //TODO: User Code
      if(a==0)
         output_high(pin_c0);
         set_adc_channel(0);
         delay_us(20);
         b=read_adc();
         v=0.0048828125*b;
         printf(lcd_putc,"\f VALUE v:%1.2f",v);
      if(input(pin_b0)==0)
      a=0;
and it is head file:
#include <18F46K22.h>
#device ADC=10
#FUSES WDT128                   //Watch Dog Timer uses 1:128 Postscale
#FUSES NOBROWNOUT         //No brownout reset
#FUSES NOLVP                    //No low voltage prgming, B3(PIC16)
#FUSES NOXINST  //Extended set extension
#use delay(internal=8MHz)
#include <lcd.c>
#use pwm(CCP1,TIMER=2,FREQUENCY=495,DUTY=50)
