Please do not post bug Reports on this forum. Send them to support@ccsinfo.com
16 bits I2C communication between 2 PICs 18F
cleberalbert
PostPosted: Thu Jul 31, 2014 2:51 pm     Reply with quote
This program is to provide 16 bits I2C communication between 2 PICs 18F. The code was done on CCS 5.018, it's commented and working. Tested with PIC18F4520.
Master.c
#include <18f4520.h>
#fuses HS
#fuses PUT
#fuses NOWDT                    //No Watch Dog Timer
#fuses NOBROWNOUT               //No brownout reset
#fuses NOLVP                    //No low voltage prgming, B3(PIC16) or B5(PIC18) used for I/O
#fuses NOXINST                  //Extended set extension and Indexed Addressing mode disabled (Legacy mode)
#use delay(crystal=20MHz)
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, ERRORS) //+++ up baud rate?
#use i2c(master, sda=PIN_C4, scl=PIN_C3, FORCE_HW)
/* Bit defines */
#define EEPROM_SCL PIN_C3
#define EEPROM_SDA PIN_C4
#define SLAVE_ADDRESS 0x20 // addr=2 reserved, note address masking.
#define I2C_DELAY_US           16 // worked 20 //Worked 32 //75 //100
#define I2C_INTERBYTE_DELAY_US 60 // worked 80
#byte PIC_SSPCON2  = 0xfc5
void initI2C (void);
void writeI2C (int16 word, unsigned int slave_addr);
int16 readI2C (unsigned int slave_addr);
int16 mainI2C ();
void initI2C (void)
   output_float(EEPROM_SCL);
   output_float(EEPROM_SDA);
   i2c_start();
   delay_us(I2C_DELAY_US);
   i2c_write(slave_addr);  /* Device Address */
   i2c_write(word & 0x00ff);            //LSB first
   i2c_write((word & 0xff00) >> 8);     //MSB second
   i2c_stop();
   int8 b1=0, b2=0;
   i2c_start();   // restart condition
   i2c_write(slave_addr + 1);
   delay_us(I2C_INTERBYTE_DELAY_US);
   b1 = i2c_read(1);
   b2 = i2c_read(0);
   i2c_stop();
   return make16(b2, b1);
void main(){
int16 data_to_send=18099;
int16 data_received;
initI2C();
delay_ms(10);
  // Write
  writeI2C(data_to_send, SLAVE_ADDRESS);
  printf("Message sent successfully from the Master to the Slave: %ld\n",data_to_send);
  // Read
  data_received = readI2C(SLAVE_ADDRESS);
  printf("Answer received successfully from the Slave to the Master: %ld\n",data_received);
  printf("\n");
Slave.c
#fuses HS
#fuses PUT
#use i2c(Slave, Slow, sda=PIN_C4, scl=PIN_C3, force_hw, address=0x20)
/* PIC Registers */
#byte SSPBUF   = 0xfc9
#byte SSPADD   = 0xfc8
#byte SSPSTAT  = 0xfc7
#byte SSPCON1  = 0xfc6
#byte SSPCON2  = 0xfc5
#byte PIE1     = 0xf9d
#byte TRISC    = 0xf94
int16 data_to_send=18100; //In the next step of the code development this data is going to change every loop (sensor data)
int16 data_sent;
#int_SSP
void i2c_interrupt() {
   //Get state
   int state;
   int writeBuffer[2];
   int readBuffer[2];
state = i2c_isr_state();
if(state==0) //Address match received with R/W bit clear, perform i2c_read( ) to read the I2C address.
i2c_read();
else if (state==0x80) //Address match received with R/W bit set; perform i2c_read( ) to read the I2C address, and use i2c_write( ) to pre-load the transmit buffer for the next transaction (next I2C read performed by master will read this byte).
i2c_read(2);
if (state>=0x80) //Master is waiting for data
writeBuffer[0] = (data_to_send & 0xFF); //LSB first
writeBuffer[1] = ((data_to_send & 0xFF00)>>8);  //MSB secound
i2c_write(writeBuffer[state - 0x80]); //Write appropriate byte, based on how many have already been written
if ((state-0x80)==2){
data_sent=make16(writeBuffer[1],writeBuffer[0]);
printf("\nFull data sent: %ld\n",data_sent);
else if(state>0) //Master has sent data; read.
readBuffer[state - 1] = i2c_read(); //LSB first and MSB secound
if (state==2){
data_received=make16(readBuffer[1],readBuffer[0]);
printf("\nFull data received: %ld\n",data_received);
void main() {
   enable_interrupts(INT_SSP); //Enable interrupts
   i2c_slaveAddr(0x20);
   while (TRUE)
   delay_us(10);
