How to program PIC 12F629 ?
mmc01
PostPosted: Mon Jul 21, 2014 11:16 pm     Reply with quote
I program to 12F629. It have GP0-GP5. I can't use the code like this. 12F629 should use internal clock. I want to use microcontroller for 5 PIN only. What the number of microcontroller PIC suitable for me ? How to program PIC 12F629 ?
void main (void)
  while(TRUE){
     if(!input(GP0)){
         output_high(GP2);
PostPosted: Mon Jul 21, 2014 11:36 pm     Reply with quote
Post the rest of your code. The processor setup etc..
These are what define which pins you can use.
The only PIC's with 5 I/O pins or more, are the 8 pin PIC's like the 629, so stick with what you have.
Programming it depends on what programmer you have?.
#include <12F629.h>
#FUSES NOWDT, INTRC_IO, NOMCLR, NOBROWNOUT
#use delay(INTERNAL=4000000)
   setup_comparator(NC_NC);
   output_low(GP2);
       if(!input(GP0))
            output_high(GP2);
            output_low(GP2); //you needto lower the line again
            //or it'll stay high forever...
This is the 'example' program with fuses and clock, to give 5 general purpose I/O lines, and one input only line on GP3.
Note also that you have to pull GP2 low before and after you pull it high, or it'll just stay high forever.
mmc01
PostPosted: Tue Jul 22, 2014 12:47 am     Reply with quote
when I compile it show error like this. How to use 12F629 with CCS ?
Error 12 "main.c" Line 8(15,18): Undefined identifier GP2
Error 12 "main.c" Line 11(18,21): Undefined identifier GP0
Error 12 "main.c" Line 13(25,28): Undefined identifier GP2
Error 12 "main.c" Line 15(24,27): Undefined identifier GP2
4 Errors, 0 Warnings
PostPosted: Tue Jul 22, 2014 12:52 am     Reply with quote
I used the names you used in your code. You must have them defined somewhere. Your definitions need to be added if you are using your own names. The standard names are PIN_A0 to PIN_A5 (for current compilers).
mmc01
PostPosted: Thu Jul 24, 2014 8:16 pm     Reply with quote
The standard name of 12F629 different from 16F.
http://ww1.microchip.com/downloads/en/devicedoc/41190c.pdf
I'm not sure what is standard name of 12F629. Can I use 12F629 with PIN_A0 to PINA5 ?
PostPosted: Thu Jul 24, 2014 8:40 pm     Reply with quote
From the 12F629 CCS header file:
// Constants used to identify pins are:
#define PIN_A0 40
#define PIN_A1 41
#define PIN_A2 42
#define PIN_A3 43
#define PIN_A4 44
#define PIN_A5 45
PostPosted: Fri Jul 25, 2014 12:11 am     Reply with quote
If you want to use the "GP" names for the pins, just add this code above main():
#define GP0   PIN_A0
#define GP1   PIN_A1
#define GP2   PIN_A2
#define GP3   PIN_A3
#define GP4   PIN_A4
#define GP5   PIN_A5
