Does SD Card library work on PIC24?
haxan7
PostPosted: Mon Jul 21, 2014 2:54 pm     Reply with quote
I know that there are a lot of issues with CCS fat library.
I need to know if anyone has gotten it to work with PIC24 before I dive into it.
EDIT:
mmcsd.c works for PIC24 out of the box.
fat.c does NOT.
Compiler Version: 5.015
dyeatman
PostPosted: Mon Jul 21, 2014 4:13 pm     Reply with quote
It helps if you try a search first...
http://www.ccsinfo.com/forum/viewtopic.php?t=52210
Google and Forum Search are some of your best tools
haxan7
PostPosted: Mon Jul 21, 2014 4:31 pm     Reply with quote
I did search and found that post, but somehow managed to miss the PIC24 part.
I also found this post that had me worrying, so I decided to create a new thread.
https://www.ccsinfo.com/forum/viewtopic.php?t=51163&highlight=fat32
dyeatman
PostPosted: Mon Jul 21, 2014 4:46 pm     Reply with quote
An SD card library should be essentially processor independent.
As long as the clock and peripherals (SPI etc) of the PIC functions normally
the processor used should be largely irrelevant.
If they don't function correctly it's not the fault of the SDHC code.
With the posted patches I have also been able to get the
PIC24 and DsPICs 30 and 33 to work with the CCS library
so you have some choices...
asmallri
PostPosted: Tue Jul 22, 2014 8:12 am     Reply with quote
There are a couple of minor caveats that may or may not be a issue with the CCS driver (I do not know because I do not use it). Care must be taken when operating the SPI bus at higher speeds. Some PICs and/or specific hardware implementations require skew adjustment for the SPI bus to be used reliably with SD/MMC media at high clock rates.
If porting code from 8 to 16 or 32 bit processors care must be taken to avoid word alignment issues that would not be an issue with an 8 bit controller. This situation occurs with SD/MMC cards in the boot sector where some of the fields that must be processed are not word aligned.
Regards, Andrew
haxan7
PostPosted: Tue Jul 22, 2014 8:51 am     Reply with quote
I am total noob, another question does Allocation unit size matter with ccs driver?
hssn601
PostPosted: Wed Jul 23, 2014 3:42 am     Reply with quote
yes it works for !
I have tested SD and SDHC cards 2~16gb on PIC24f and dsPIC33E
for initialization use:
Function: InitializeSD()
Return 1 if success
Return 0 if unsuccessful
from this link:
http://www.ccsinfo.com/forum/viewtopic.php?p=187808#187808
after initialization rest of every thing will work ok Smile
Best Regards,
Hassan Shakeel
haxan7
PostPosted: Wed Jul 23, 2014 3:45 am     Reply with quote
hssn601 wrote:
yes it works for !
Return 1 if success
from this link:
Thanks for the reply.
Did you use fat32 file system? If yes, then did you use ccs driver as it is, or did you apply the fixes?
