PIC16F1459 getenv("SFR:SPBRG") ERROR 28
freesat
PostPosted: Mon Jul 14, 2014 2:24 pm     Reply with quote
Hi guys,
I'm trying to replace older pic I'm using with PIC16F1459, using same code that uses getenv, but getenv does not work with this ( Error 28: Expecting an identifier, Bad SRF name ), works on almost pics i have tried, if it does not have SPBRG simple return is 0 ( Not Detected in this case ).
#if getenv("SFR:SPBRG") == 0
   #error SBPRG: Not Detected!
#else
   #byte SPBRG  =  GETENV("SFR:SPBRG")
#endif
Using CCS 5.025.
Page 30 from datasheet says that pic have SPBRG ( 19Bh SPBRG ), but Page 37 from datasheet says ( 19Bh SPBRGL )
So what I'm doing wrong? how can i check if SPBRG or SPBRGL exists, using getenv without raise error?
PostPosted: Mon Jul 14, 2014 2:36 pm     Reply with quote
The 'SPBRG', is a 16bit register, made up of two halves 'SPBRGL', and 'SPBRGH' (low and high bytes). The compiler only knows the names of the halves. If you want to access the whole register (which is what you should be doing to write a value), use:
#if getenv("SFR:SPBRGL") == 0
#else
   #word SPBRG  =  GETENV("SFR:SPBRGL")
#endif
Then you can just write the 16bit value to SPBRG.
Why try to access it?. set_uart_speed(), directly writes to these registers, and knows how to convert a baud rate to the required values (done at compile time, so no overhead...).
PostPosted: Mon Jul 14, 2014 2:55 pm     Reply with quote
It's a little bit confusing, because if you look in the Memory Map section
of the 16F1459 data sheet, it uses the traditional Microchip terms of
SPBRG and SPBRGH. See Table 3-6.
But then if you go down to Table 3-12, Microchip switches terminology to
SPBRGL and SPBRGH.
This is a bug in the PIC's data sheet.
http://ww1.microchip.com/downloads/en/DeviceDoc/40001639B.pdf
You can use the SFR_VALID function to see if the SFR exists:
>>> Warning 224 "pcm_test.c" Line 7(1,2): #warning 0
>>> Warning 224 "pcm_test.c" Line 8(1,2): #warning 1
>>> Warning 224 "pcm_test.c" Line 10(1,2): #warning 1
Test program:
#include <16F1459.h>
#fuses INTRC_IO, NOWDT
#use delay(clock = 32M)
#warning getenv("SFR_VALID:SPBRG")
#warning getenv("SFR_VALID:SPBRGL")
#warning getenv("SFR_VALID:SPBRGH")
freesat
Hi Ttelmah,
Thanks for answer, it is for use with DMX protocol, because my code ( derived from Mark's code ) need it in that way, works perfectly in any device i have used, except this one.
I have write a code, that compile and works in any pic, without any changes on code or defines ( full automatic ) and is like universal, but now i get this trouble with that pic, i like to maintain the code universal, but now including the SPBRGL.
if i use ( getenv("SFR:SPBRGL") , it raise same Error 28, with chips that does not have SPBRGL like 16F628
So there other way to check if exists SPBRGL or SPBRG without raise an error?
PostPosted: Mon Jul 14, 2014 2:57 pm     Reply with quote
Yes, see the edit to my post that I made at the same time you posted.
PostPosted: Tue Jul 15, 2014 12:42 am     Reply with quote
Yes.
It is a case of CCS following a data sheet 'bug', without thinking about compatibility.
If SPBRGL is not valid, then test SPBRG and it should be OK.
#if ((!getenv("SFR_VALID:SPBRGL")) && (!getenv("SFR_VALID:SPBRG")))
#else
Fun little annoyance....
