Connecting i2C lines on dspic33
newCCSUser
PostPosted: Tue Jul 08, 2014 1:40 pm     Reply with quote
Hi.
Am confused regarding the i2c connection.
We are building demo board and as far as i know i2c should be connected to sda i scl line but there are some schematics examples where he uses INT.
Is this possible or am missing something ?
newCCSUser
PostPosted: Wed Jul 09, 2014 1:06 am     Reply with quote
forget it, i will connect it by the book.
Thank you anyway.
PostPosted: Wed Jul 09, 2014 8:22 am     Reply with quote
There are two ways of handling I2C.
'Soft' I2C (master only) can use any pins. 'Hardware' I2C. The chip hardware sends and receives the bytes for you.
For the 'hardware' I2C, you have to use the hardware pins. The software implementation can use any pins you want.
The hardware implementation, is faster, and can be sending/receiving, while the chip is doing other things.
bkamen
PostPosted: Fri Jul 11, 2014 10:50 am     Reply with quote
If you see pins on an I2C chip like INT or IRQ, that's because the chip can generate flags (like MCHP's GPIO extenders that can create an interrupt-on-change).
So these can optionally be hooked to a pin on a PIC or other MCU that can generate interrupts.
Good examples are INT_RB or INT0/INT1/etc....
but yes, SDA and SCL are the 2 major pins of importance.
Cheers,
-Ben
