tienchuan
Problem PIC reset when interrupts RB |
Posted: Sat Jun 14, 2014 5:44 am |
Hi.
I have a problem when try using RB interrupt to detect AC signal.
Here is my circuit to detect AC 220V-50Hz:
When I plugged in AC 220V, the PIC will reset.
In my schematic, because I want to capacitor discharge faster, so that I put serial with resistor,can it make a problem ?
In my program, I used RB interrupt to detect signal from optocoupler.
int8 input_state_b(void)
#byte PortB = getenv("SFR:PORTB")
return(PortB);
#int_rb
void ngat_rb()
delay_ms(50);
check_so_sa=1;
temp_read=input_state_b();
clear_interrupt(int_rb);
and here's configs of fuses:
#include <18F4680.h>
#fuses H4,PUT,NOPROTECT,NODEBUG,NOLVP,NOWDT,NOPBADEN,MCLR,BROWNOUT,BORV21,NOSTVREN
#use delay(clock=40000000)
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, errors)
I'm used PIC18F4680, CCS C complier 5.025.
Thanks all. |
Joined: 01 Jul 2010 Posts: 9527 Location: Greensville,Ontario
Posted: Sat Jun 14, 2014 6:49 am |
hardware....
Those on your 'side of the pond' can help with a better 'front end'. I prefer to use a small 220-5V step down transformer instead of having 330VDC entering an optocoupler on MY PCB ! It's a safety issue for me and my PIC.
A series resistor with a capacitor will really slow response.
Since the name of the input is 'count_ac' , is the PIC supposed to count pulses? If so..then a capacitor will slow things down as well!
There are commercial devices available like the IAC5.If you Google that, you may see a schematic of what's 'inside the box'.
software...
You do not need to clear the interrupt, inside the ISR. The compiler does that for you automatically.
Also delete the delay-ms(50); from the ISR. You do NOT require it.The ISR was triggered by an 'event'. ISRs are supposed to be FAST, get in...do 1 or 2 simple things(like flags,or set variables) then get out fast.
hth
jay |
Posted: Sat Jun 14, 2014 2:13 pm |
Temtronic is right. On my home energy monitoring system I use 110v to
3v step down transformers and feed that via isolation resistors to
the PIC input(s) (I monitor both halves of single phase 220 to neutral so I
have two transformers and two inputs). I mounted the transformers in the
circuit panel so the only voltage that leaves is the 3VAC to the PIC circuit.
I attached a good quality DVM on the 110VAC input then scaled the
resulting conversion to match the actual AC input.
BTW, be sure and fuse the xfrmr inputs and outputs!
I fused mine at 750ma...on both sides _________________ Google and Forum Search are some of your best tools!!!! |
tienchuan
Posted: Sun Jun 15, 2014 1:29 am |
temtronic wrote: | hardware....
software...
hth
jay |
Thanks u.
In this project, I don't want to use transformer down voltage 220-5V, because it make PCB large and not good low cost solution.
In the last, I tested with 110V AC- with this circuit, but when i change plug 220VAC, the resistor is so hot, I can't understand why it wrong because flw caculated the resistor only 2W, but I put resistor 5W, but it still hot.
Sorry, It right to detect signal AC, not count AC, because I haven't fix this schematic.
In my interrupt RB, I know it auto clear interrupt flag but I want to ensure it's cleared, because i don't read ASM code.
Thanks for your reply, I'll repair this circuit and update to you.
Thanks _________________ Begin Begin Begin !!! |
Mike Walne
Posted: Sun Jun 15, 2014 6:11 am |
tienchuan wrote: |
Thanks |
Running a 5W resistor @ 2W it WILL get hot.
I've just looked up the data sheet for a typical 5W part.
It's derated 5W to 0W from 25C to 350C.
Therefore you can expect it to rise roughly 65C per W.
That's a 130C rise for your 2W case.
As an aside, the effect of the capacitor in your circuit is to almost completely remove the ability detect 50Hz AC.
Mike |
Posted: Sun Jun 15, 2014 7:17 am |
The resistor, will probably be larger than the transformer...
(Once you allow for some cooling area.)
You can get PCB mount transformers that are under one cubic inch.
Have a look at:
<http://www.nordtek.com/index.php?m=products&id=81>
2W of heat still has to go somewhere. A '5W' resistor is typically rated at a temperature like 110C _in free air_. So resistor sitting well off the board, with a good airflow around it. Stick it tight to the board, with restricted airflow, and it's rating plummets, and it'll run _hot_.....
A solution is a whole set of parts, including things like 'where the heat goes'. |
Posted: Sun Jun 15, 2014 7:48 am |
Since you're drawing over 2 watts, the resistor should have at least a 10W rating to NOT heat up. Over time a hot resistor will fail, usually at 3 in the morning on a cold Winter's night! You could use 2 or more resistors in series to reduce the power loss per resistor. Adds more cost, bigger PCB, 2X the failure possible.
You could 'cheat' and use a capacitor to reduce the 330VDC down to 5-ish volts...well known in some products.
But....it still means there's MAINS voltage on the PIC PCB. Never a good idea, especially for a commercial product. If that's the case you MUST get 'approval' from some regulatory body. That's WHY 'wallwarts' were invented ! They're pre-approved and allow SAFE levels of electrons to flow all over your project.
I'm still in favour of a small transformer solution. Cheap, safe, reliable and OFF the PCB.
Doesn't matter if this is a one-off or batch of 1,000 units; parts cost is minimal per unit compared to R&D time.
hth
jay |
Posted: Sun Jun 15, 2014 2:44 pm |
As a separate comment, look carefully at the voltage rating of any resistor used like this. With a 230v input, the peak voltage will be nearly 330v. Allow then for the over-voltage that a supply can have, and you need resistors with perhaps a 500v rating. Many types do not offer this.... |
