Failure on watchdog pic18f46k80
Goto page 1, 2  Next
mhz1575
PostPosted: Mon Mar 17, 2014 2:23 pm     Reply with quote
Hello folks,
I have a problem on watchdog because my feeling it that doesn't work.
I forced a problem on the software and the micro didn't reboot.
Is my code wrong?
CCS PCH 5.0
Thank you
Mario
#include <18F46K80.h>
#device ADC=10 // 10 Bit 0..1023
#FUSES WDT
#FUSES WDT512
#FUSES NOXINST                  //Extended set extension and Indexed
#use delay(crystal=20mhz)
   boot();
   setup_wdt(WDT_ON);
while(true)
restart_wdt();
PostPosted: Mon Mar 17, 2014 2:30 pm     Reply with quote
Read this thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=51760
PostPosted: Mon Mar 17, 2014 3:03 pm     Reply with quote
Other possibility is the old MPLAB one. A search here will find this.
mhz1575
PostPosted: Tue Mar 18, 2014 3:58 am     Reply with quote
Hi, I read the post in the past but do not solve my problem.
Can someone tell me which string have I to write for use the wdt on my pic?
Fuse, enable and disable.
I assume that mine is wrong where I don't know.
On the forum I found these simple instructions, the same of mine but on my micro doesn't works. Sad
#include <18F66J60.h>
#fuses HS
#fuses WDT,WDT512
#use delay(clock=10M)
   SETUP_WDT(WDT_ON);
      delay_ms(32000);
Thank you for your help Sad Sad
drh
PostPosted: Tue Mar 18, 2014 8:56 am     Reply with quote
#FUSES WDT_SW
David
PostPosted: Tue Mar 18, 2014 12:34 pm     Reply with quote
With the watchdog enabled, as you show it should be triggering. I go back to my possibility that this is the old MPLAB problem. Are you compiling through MPLAB?.
If you are, you need to ensure you are setting this to compile for 'release' It defaults to 'debug', and this overrides (turns off) the watchdog...
oxo
PostPosted: Wed Mar 19, 2014 5:16 am     Reply with quote
Thread title: Failure on watchdog pic18f46k80
Code: #include <18F66J60.h>
mhz1575
PostPosted: Wed Jun 11, 2014 1:14 am     Reply with quote
Hello folks,
I'm coming back to these issue because after many test following all your indications the situation doesn't change.
The situation is this:
My compiler enviroment is only a CCS 5
I wrote code both for PCM or PCH but didn't works
Due to your experience is better to use Microchip ide mplab + ccs compiler?
Other suggest to obtain a watchdog?
Thank you
oxo
PostPosted: Wed Jun 11, 2014 1:25 am     Reply with quote
How do you know the watchdog reset is not happening?
mhz1575
PostPosted: Wed Jun 11, 2014 11:13 am     Reply with quote
I know for two reasons:
First on my effective program where I have a modem that didn't answer on the uart blocking on a getc.
Second using a very simple sw where there isn't a reboot by wdt.
Consider that to write this test sw I have used the CCS wizard.
I'm frustrated....
#device ADC=16
#FUSES WDT                      //Watch Dog Timer
#FUSES WDT512                  //Watch Dog Timer uses 1:512 Postscale
#use delay(crystal=20000000)
#use rs232(baud=115200,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,stream=GPS,restart_wdt,errors)
   switch ( restart_cause() )
      case WDT_TIMEOUT:
         fprintf(GPS,"\r\nRestarted processor because of watchdog timeout!\r\n");
      case NORMAL_POWER_UP:
         fprintf(GPS,"\r\nNormal power up!\r\n");
   setup_wdt(WDT_ON);
      //TODO: User Code
      restart_wdt();
      printf("Hit any key to avoid a watchdog timeout.\r\n");
      getc();
PostPosted: Wed Jun 11, 2014 11:42 am     Reply with quote
It won't give a restart on a getc, since you are turning that off. That is what 'restart_wdt' does in the #use RS232. It adds code to the RS232 routines to prevent the watchdog triggering in these....
oxo
PostPosted: Wed Jun 11, 2014 12:02 pm     Reply with quote
And.. If you are testing in Debug mode, watchdog is disabled.
PostPosted: Wed Jun 11, 2014 12:29 pm     Reply with quote
I'm frustrated....
Expanding on Ttelmah's comment (I was testing this in hardware at
the same time):
You edited the CCS example file, ex_wdt18.c and added the parameter
shown below in bold:
This is the reason why your program is not working. Remove the restart_wdt parameter.
mhz1575
PostPosted: Wed Jun 11, 2014 12:33 pm     Reply with quote
Opps, sometimes happen to do wrong after many many test.
Anyway removing restart_wdt from uart declaration the situation didn't change on the test program attacched in the last post. The micro didn't restart.... ufff ufff ufff
No debug, sure.
Could be a problem on the 18f46k80.h files?
PostPosted: Wed Jun 11, 2014 12:51 pm     Reply with quote
1. Are you testing this WDT program on a real hardware board ?
2. Did you buy the board ? Or did you build it yourself ?
If you bought the board, post a link to the website for the board.
If you made the board by yourself, post a link to the schematic.
3. Post your CCS compiler version. Example of version numbers:
http://www.ccsinfo.com/devices.php?page=versioninfo
Goto page 1, 2  Next
Page 1 of 2
