keypad
Abidi
keypad
PostPosted: Thu May 22, 2014 9:27 am     Reply with quote
Hi, I'm working in a project in which i used a keypad to enter value.
After entering this value, i want to return to execute the rest of my program, but the problem is that the execution still blocked on the function of keypad :(
I will appreciate your help.
#include <main.h>
#define LCD_ENABLE_PIN PIN_D0
#define LCD_RS_PIN PIN_D2
#define LCD_RW_PIN PIN_D1
#define LCD_DATA4 PIN_D6
#define LCD_DATA5 PIN_D5
#define LCD_DATA6 PIN_D4
#define LCD_DATA7 PIN_D3
#define buzzer PIN_D7
#use fast_io(a)
#include <lcd.c>
#include <flex_kbd.c>
char k;
unsigned long int lecture;
float v, Ifuite,Imax;
int j=60;
void keypad()
   kbd_init();
     lcd_gotoxy(1,1);
     printf(lcd_putc,"Entrer les");
     lcd_gotoxy(1,2);
     printf(lcd_putc,"parametres");
     delay_ms (1500) ;
     printf(lcd_putc,"Imax=%c",k);
    while (TRUE)
                    k=kbd_getc();
                    if(k!=0)
                    lcd_putc(k);
                    if(k=='#')
                    lcd_putc("\fTension\n");
                    if (k=='*')
                    lcd_putc("\fTemps\n");
void test()
          if ( Ifuite < Imax)
                 output_low(pin_c0);
                 printf(lcd_putc,"test OK \r");
                 output_high(pin_c1);
                 delay_ms(1500);
                 output_low(pin_c1);
          else if ( Ifuite >= Imax)
                 output_low(pin_c0);
                 printf(lcd_putc,"test NOT OK \r");
                 //output_high(pin_d7);
                 output_high(pin_c2);
                 delay_ms(1500);
                 output_low(pin_c2);
     printf(lcd_putc,"Bienvenue \r");
     delay_ms (1500) ;
     printf(lcd_putc,"sagemcom \r");
     delay_ms (1500) ;
     keypad();
     printf(lcd_putc,"start test \n");
     delay_ms (1500);
     printf(lcd_putc,"test en cours \r");
     output_high(pin_C0);
     delay_ms (1500);
    setup_adc_ports(AN0);
    set_adc_channel(0);
    delay_us(20);
   while(true)
   lecture=read_adc();
   delay_us(20);
   v=lecture*0.0048828125;
   delay_us(10);
   ifuite=v/1.5;
   delay_us(10);
   lcd_gotoxy(1,1);
   printf(lcd_putc,"I=%fmA",Ifuite);
   lcd_gotoxy(1,2);
   printf(lcd_putc,"Ttest=%d",j);
   j=j-1;
          if(j==0)
                    test();
PostPosted: Thu May 22, 2014 9:48 am     Reply with quote
This sample code shows how to poll the keypad every 10 ms in an
interrupt routine. If a key is pressed, it's put into a circular buffer.
Your main code can check 'bkbhit' to see if a character is available
in the keypad buffer. If so, you can get the character with bgetc().
http://www.ccsinfo.com/forum/viewtopic.php?t=42707&start=4
Because this keypad loop doesn't block (it's run by interrupts), you
can do other activities in your main loop.
Abidi
keypad
PostPosted: Sun May 25, 2014 5:10 am     Reply with quote
ok thanks Smile and how can i store a value of current entered by keypad, displayed on lcd, because in test i need this value to do the comparison.
PostPosted: Sun May 25, 2014 11:30 am     Reply with quote
This code shows how to get a password from the keypad and compare it
to a stored password.
http://www.ccsinfo.com/forum/viewtopic.php?t=45935
