naughty_mark
| Question about const pointer and CCS compiler error |
Posted: Mon May 19, 2014 5:49 pm |
Hi guys.
I am using CCS compiler v5.016. I am doing some const pointer code but CCS gave a error.
I am trying to define a font structure so that once user set current font, then the display module can use a generic function to display many kinds of font on LCD. The code I define my structure and variable as below:
typedef struct _charLib //for character library
unsigned int charAmount;
unsigned char width;
unsigned char heigth;
unsigned char bytePerRow;
const unsigned char *pCharArray;
} charLib;
charArray is the font bitmap and it is defined as
const unsigned char Font1616Array[FONT1616_TOTAL_CHAR][CHAR_DOUBLE_WIDTH] =
/* Character Data - Index: 0 */
0x00,0x00,0x00,0x00,0xF0,0x3F,0x10,0x20,0x10,0x20,0x10,0x20,0x10,0x20,0x10,0x20,0x10,0x20,0x10,0x20,0x10,0x20,0xF0,0x3F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
/* Character Data - Index: 1 */
0x00,0x00,0x00,0x00,0xF0,0x3F,.........
I just put a little part of that font array on otherwise it is too big.
Then I compile, the compiler gave me error:
*** Error 34 "C:\Project\iconCharLib.h" Line 32(31,36): Unknown type
It says in the structure define "const unsigned char *pCharArray;" is unknown type.
And if I remove "const" at both structure definition and font bitmap definition, the error gone.
I think most likely it is something stupid I make, but anyone can explain why, thanks a lot~
Kind Regards
Mark |
Posted: Mon May 19, 2014 6:28 pm |
In CCS, 'const' tells the compiler to store the data in Program Memory
(i.e., in Flash memory, instead of RAM). It's a good idea to declare
your font table as const, but I don't see how it helps to declare the
pointer as being stored in flash. You might want to change the pointer to
use a different font table. The pointer should be in RAM.
Anyway, I'm pretty sure we previously discussed the issue of mixing
const and RAM variables in a struct, but I can't find the thread in the
forum archives. The consensus was that the compiler doesn't support it.
So remove 'const' in the structure declaration. |
naughty_mark
Posted: Mon May 19, 2014 9:32 pm |
| PCM programmer wrote: | In CCS, 'const' tells the compiler to store the data in Program Memory
Thanks for the explanation, PCM programmer!
I remove the "const" term in structure declaration, but I got another error
Error 27 "C:\Project\iconCharLib.h" Line 916(151,152): Expression must evaluate to a constant
The error point to the code below:
charLib Font16x16 = {
FONT1616_TOTAL_CHAR,
16,
16,
2,
Font1616Array,
It says "Font1616Array" expression must evaluate to a constant. I often get confused to use pointer is there anything wrong? Thanks |
naughty_mark
Posted: Tue May 20, 2014 12:16 am |
Thanks PCM programmer!
As the solution showed in that thread, my problem solved, and the .sym file indicates that big array move to ROM and can use pointer to point.
Next time I will do search in forum first~
Thanks for your kind help again.
Kind Regards
Mark |
