AKIOM
USB AND interrupts INT_AD problem |
Posted: Fri May 16, 2014 7:34 pm |
I would like to convert analog to digital in sleep mode to reduce noise. Then, I send the value via usb port. When I enable INT_AD, PIC18f4550 can not send anything to computer. Even, I script sleep mode and left only enable INT_AD, it only see as com-port on my computer (I use usb cdc module) but it cannot send anything. Please help me.
Note that if I enable other interrupts such as INT global or INT_RA, my PIC can send data via usb (condition of the test does not get PIC in sleep mode). I use all day to find this solution by searching from internet but I can not.
I use PIC18f4550 and 5.024 ccs complier
Thank you very much
* File :
* Purpose : Test ADC SLEEP MODE AND THEN SEND VIA USB
#include <18F4550.h>
#device adc=10
#use delay (clock= 48M)
#include <stdlib.h>
#include <usb_cdc.h>
#fuses HSPLL ,PLL5 ,USBDIV ,CPUDIV1 ,VREGEN, NOLVP, NOWDT, NOPROTECT
* Constants
#define Vbe 0.00488758553 //->(5/1023)
FUNCTION: Mainprogram
setup_adc_ports(AN0);
int16 ADC_Value;
float volt;
while(true)
enable_interrupts(INT_AD);
set_adc_channel(0);
clear_interrupt(INT_AD);
read_adc(ADC_START_ONLY);
sleep();
delay_cycles(1);
ADC_value=read_adc(ADC_READ_ONLY);
disable_interrupts(INT_AD);
volt=ADC_Value* (float) Vbe;
usb_cdc_init();
usb_init(); //init USB and enable USB interrupt.
usb_task();
//// %ld unsigned lohg decimal
if (usb_enumerated())//Returns TRUE if the device has been enumerated(specified)by the PC.
printf(usb_cdc_putc, "\n\rval: %ld",ADC_Value);// %ld unsigned lohg decimal
printf(usb_cdc_putc, "\n\rval: %f",volt);// %ld unsigned long decimal
oxo
Posted: Fri May 16, 2014 10:41 pm |
Data sheet p35.
All clocks are disabled in sleep mode.
What do you think this means for the usb controller and the adc? |
AKIOM
I read datasheet p35 as you suggest |
Posted: Sat May 17, 2014 1:23 am |
I read datasheet p35 as you suggest. The detail is when the PIC sleep, it use internal oscillator so adc work. After, it finish reads Analog signal, it should be waked by INT_AD. All in all, I test my code by script *"sleep mode"*(pic does not sleep" and left only enable INT_AD but it does not send any data to usb port. |
oxo
Posted: Sat May 17, 2014 1:34 am |
But the usb will not have a clock. You cannot sleep with usb active. |
Posted: Sat May 17, 2014 2:56 am |
You basically cannot do this.
USB, requires the USB peripheral is always active, once enumerated (unless the host puts the device to sleep). As Oxo has told you the master oscillator stops, so the USB peripheral stops.....
Use the main CPU clock with a suitable divider. The internal RC clock is not 'better' in terms of noise. It is only better because using it you can stop the CPU (which then potentially reduces noise from this), but with USB running you _cannot_ do this. With good supply design, decoupling, and a well designed ground plane round the CPU, you can quite easily reach the design limits of the PIC ADC with the internal clock. |
AKIOM
Posted: Sat May 17, 2014 6:29 am |
Dear oxo and Ttelmah
Thank both of you very much for answering me.
I have the question in my mind about my code.
sleep();
delay_cycles(1);
This process is wake up cpu when reading ADC finish. After that, I start usb from initial process with
usb_cdc_init();
usb_task();
This process runs infinite loop after finishing adc converter. So, I think it can enable USB peripheral active.
I have to do this (sleep) because I test ADC by reading from battery 1.2 V and the value is +-5 point (230-240) ->1. 2/5*1023. This error is common error or not. I use supply from USB and use C 0.1uf decoupling USB supply. I should use external supply and regulator or not. Another question is I want more accuracy how can I do?. My project want 10 Kbps ADC sampling rate. Please advise me, I am a new user about PIC.
Thank you very much. |
Posted: Sat May 17, 2014 9:17 am |
Forget about sleeping the chip.
To get _accuracy_, you want an external Vref.
Currently your accuracy will be <10% if that. The USB supply at the PC, must be +/-5% (it's allowed to be worse than this for USB3....), but add your cables and connectors, and +5/-10% is more typical. It is not suitable for use as a reference voltage.
Your count will easily vary by 20 or more counts as the USB supply varies, and with different PC's. A bandgap reference feeding the ADC Vref is the way to get accuracy.
No point in sleeping at all.
The fastest CPU clock speed you can legally use for full accuracy on the internal ADC on this chip is 40MHz. This is actually difficult to do with USB on this chip. Best is to run with HSPLL, and CPUDIV2, which from a crystal that is a multiple of 4MHz (with the correct PLL ratio selected), then give the CPU at 32MHz. This does a conversion in 22uSec, with 7.6uSec required between conversions for a maximum rate just over 33KHz. However you are unlikely to be able to do anything like this rate for any duration.
First the PIC can't store many values.
Then when USB requires servicing, there will be 100+uSec pauses as this is handled.
To get this sort of rate and feed it to USB with a steady throughput, you need a chip with possibly DMA.
So if this is just a short 'burst' of readings, then OK. But if you want a long period of readings, you have not got the hardware to handle it.... |
AKIOM
Posted: Sat May 17, 2014 10:58 am |
Ttelmah, Thank you very much again.
After I read your suggestion. To accurate ADC, It should have
1. External Voltage Reference for ADC
2. External supply with voltage regulator
3. Decoupling capacitor from supply
4. Ground plane around PIC
5. External Oscillator for ADC Clock.
6. Do not use sleep mode for reducing noise while connecting USB
For my project, I read your suggestion. The conclusion is
1. It is hard to use ADC at sampling rate 10 kbps and send via USB port. by using PIC18F4550.
If I really change my PIC, what PIC I should start.
I go to microchip website and try to select the PIC that has USB mode and
DMA. I think dspic33EP256MU806' spec is suitable for my project. I do not
know this PIC is proper for me. I am just a starter and do not know much about micro-controller. Please advise me. Thank you very much. |
Joined: 01 Jul 2010 Posts: 9527 Location: Greensville,Ontario
Posted: Sat May 17, 2014 5:53 pm |
You should tell us WHAT analog input you're sampling that needs 10KHz.
Also along with previous replies...., you'll need real GOOD PCB layouts,proper decoupling, shielded cables, etc. to get accurate ADC readings !
hth
jay |
Posted: Sun May 18, 2014 2:54 am |
and seriously, you need to walk before you can ride.
You need to start much smaller.
Set yourself a series of parts to do one step at a time.
Before starting, if all you want is to sample a voltage 10000* per second, there are any number of USB modules on the market already that can do this without building anything. Some of the data logger units do exactly this.
Once you are sure you need to build something:
First get an actual PIC project working, sending data to a serial port.
Then perhaps try USB.
Then try running the chip without decoupling, then with, and realise why this is _essential_.
Then try some ADC readings, and see what the noise is like, and study the effect of decoupling round the chip, and using an external Vref (and no, you don't need 'an external supply with voltage regulator'). The Vref is all that is needed here.
Then depending on what your signal is, look at what analog preprocessing may be necessary. Remember the PIC ADC needs a relatively low impedance source, and the ADC is linear. Is this what your signal can generate, and requires?.
Only once you are happy with your ability to do all this, and understand the effect of things round the chip, look at what processor may best suit your needs. |
AKIOM
Posted: Sun May 18, 2014 6:48 am |
Dear all
Thank you very much for suggestions.
My project is measure voltage signal from photo-detector array.
Ttelmah, I very appreciate your suggestion. I will start walking as you advise me. All suggestion is very useful for me.
AKIOM |
Posted: Sun May 18, 2014 1:25 pm |
Seriously, you need to do a lot of basic learning, before starting this project.
Now a photodiode array, covers a huge range of different devices, and what is needed for the preprocessing, will depend on the nature of the device, and the lighting intensities involved. You'll need a constant current source feeding the diodes, and a buffer amplifier to feed the ADC. You need to get this processing right before even beginning to think about the PIC circuit. One way, could be to use two PIC's, and a small amount of dual port memory. Then one PIC samples the signal at a constant rate transferring the data to the memory, and the other handles sending this to the USB.
However I have to repeat the comment about the number of off the shelf units that can do this. If you want less than a few hundred units, it'll be a lot quicker and cheaper to use one of these. The PIC solution becomes worth developing, when the costs of development can be amortised over a lot of units, The sort of unit I'm talking about is the NI USB-6008. |
Posted: Sun May 18, 2014 4:18 pm |
You should tell us the make/model of this 'array' or a 'link' to the datasheet. Someone here might have already used it or similar.
hth
jay |
