alan
Joined: 12 Nov 2012 Posts: 358 Location: South Africa
| #FUSES NOOSCIO |
Posted: Tue May 13, 2014 5:05 am |
dsPIC33EP32MC202
CCS 5.024
I am going crazy here.
If you include #FUSES NOOSCIO and use the FRC what do you get out at the OSC2 pin? The Fosc or Fcy?
I have setup the Fosc as 80Mhz, gone through the registers, which looks right to me.
But I am getting a frequency of 40MHz out of the OSC2 pin. Also by using the code below the Tcy are 50ns corresponding to 40MHz instead of the 25ns expected.
while (TRUE) {
output_high(LED);
output_low(LED);
output_high(LED);
output_low(LED);
output_high(LED);
output_low(LED);
output_high(LED);
output_low(LED);
output_high(LED);
output_low(LED);
I have the following fuses
#FUSES NOOSCIO //OSC2 is general purpose output
#FUSES NOCKSNOFSM //Clock Switching is disabled, fail Safe clock monitor is disabled
#FUSES NOWINDIS //Watch Dog Timer in Window mode
#FUSES NOJTAG //JTAG disabled
#use delay(internal=80MHz)
I also tried using the
setup_oscillator(OSC_INTERNAL,80000000);
| with no difference in the outputs.
Regards |
