Periodic interrupt 30 uS
oxo
PostPosted: Wed May 07, 2014 4:34 am     Reply with quote
Hi all, I've never used the CCP before, and I need to have a regular 30 uS interrupt.
I have created this code, but I don't get any interrupts.
#define T3INTERVAL 960
 void sample_init(void)
   // timer
   setup_timer_3(T3_INTERNAL | T3_DIV_BY_1);
   // ccp
   setup_ccp3(CCP_COMPARE_INT);
   enable_interrupts(INT_CCP3);
   CCP_3 += T3INTERVAL;
#int_ccp3
void timer3ccpinterrupt()
compiler V 5.025
PIC 18F26K22
clock is 64 MHZ
PostPosted: Wed May 07, 2014 5:17 am     Reply with quote
Your 'code' is just code..not a real program so no one here can 'cut/paste/test'.
Please post your entire program,it'll make life a lot easier.
hth
jay
oxo
PostPosted: Wed May 07, 2014 6:39 am     Reply with quote
hth
jay
Heres my test program.
// testccp.c
#include <18F26K22.h>
#device CONST=ROM
#device ADC=8
#FUSES BROWNOUT                  //No brownout reset
#FUSES PUT                       //Power Up Timer
#FUSES HSM                       //External oscillator
#FUSES PLLEN                     //enable the x4 PLL
#use delay(clock=64M, crystal = 16M)
#define CLOCK     PIN_C0
   // timer
   // ccp
#int_ccp3
   output_high(CLOCK);
   output_low(CLOCK);
void Initialise()
   setup_timer_1(T1_DISABLED);
   setup_ccp1(CCP_OFF);
   sample_init();
   Initialise();                       //configure uC for operation
PostPosted: Wed May 07, 2014 9:35 am     Reply with quote
Why do it with the CCP?.
Timer2. T2_DIV_BY_4. PR2=143.
Interrupt every 2304 clocks. 36uSec.
Keep it simple.
The reason it is not working, is the timer. CCP_USE_TIMER3_AND_TIMER4 is needed. Currently the CCP is running off timer1 (the default).
oxo
PostPosted: Thu May 08, 2014 1:28 am     Reply with quote
Thanks Tt.
oxo
PostPosted: Thu May 08, 2014 3:10 am     Reply with quote
Supplementary question:-
What is the interrupt latency? is it 3 cycles + 2 to stack the PC?
PostPosted: Thu May 08, 2014 3:21 am     Reply with quote
No. About 30 instructions.
_Every_ register used inside the interrupt code, has to be saved.....
The compiler (unfortunately) defaults to saving everything.
Now, if your interrupt code is simple. One interrupt, and you only do basic operations like talking to an I/O pin, or incrementing a counter, then you can elect not to save the registers, by writing the handler as 'INT_GLOBAL'. You then save just the registers you need. Still be perhaps five instructions minimum. Remember your code then also needs to clear the interrupt flag, and restore the registers before exit. On the PIC18, certain basic registers (BSR, STATUS, and WREG), are saved for you by the hardware. These are restored by the RETFIE 1 instruction at the end of the handler. Unfortunately the saving this produces is 'lost' because of the number of other registers present.
The PIC is not the chip to choose for really fast interrupt handling. Many much older chips have the ability to save all the registers with just one instruction, or have alternative register sets for interrupt use.
oxo
PostPosted: Thu May 08, 2014 10:17 am     Reply with quote
Yikes!
Is it 30 on entry plus 30 to restore on exit?
PostPosted: Thu May 08, 2014 11:30 am     Reply with quote
Actually about 28 each end. However if you reckon on 60 instruction times to get into and out of an interrupt you won't be far off....
