moryoav
| ADH8066 code where to start |
Posted: Tue May 06, 2014 5:46 am |
so I'm using the GSM module ADH8066 with a pic18f2553 UBW.
at first i played a bit with the gsm using the terminal and it worked fine.
now i need to write a code to operate the module [mainly to make a call] and I've no idea how to do so.
the code I'm sure is basic, but they gsm shows no response.
adh8066 datasheet: http://goo.gl/gBOIk1
UBW datasheet: http://goo.gl/dWKs9w
pic datasheet: http://goo.gl/Oo5oIO
the code:
| Code: | #include <18f2553.h>
#fuses NOWDT, HS
#use delay (crystal=24MHz)
#use rs232 (baud=115200, xmit=PIN_C6, rcv=PIN_C7,stream=GSM, ERRORS)
while(1) //to check if the gsm calls a few times with no problems
delay_ms(5000);
fprintf(GSM "ATD+972502141890;\r");
delay_ms(15000);
Fprintf(GSM "ATH\r");
ezflyr
Posted: Tue May 06, 2014 7:13 am |
Let's start with hardware first. The ADH8066 has a maximum input voltage of 4.5V. How are you powering the module, and what is the Vdd voltage on your PIC? I used the 'LF' version of the PIC I selected, and powered the ADH8066 and the PIC at 3.8V. This allowed me to connect them directly together.
The ADH8066 has a specific 'power up' sequence having to do with manipulating the 'Pwr_On' signal of the module. You don't appear to be doing that.
John |
moryoav
Posted: Tue May 06, 2014 7:20 am |
| ezflyr wrote: | Hi,
John | right now im powering both of them with usb so supply voltage isn't a problem. in the future i'll use a voltage regulator to regulate the pic's 5V to the GSM's 4V
and what do you mean about the 'power up' sequence and what is the "Pwr_ON"? how do i use it in the code? |
Posted: Tue May 06, 2014 7:49 am |
| USB power is nominally 5v, so 'power voltage _is_ a problem'.... |
moryoav
Posted: Tue May 06, 2014 8:04 am |
| Ttelmah wrote: | | USB power is nominally 5v, so 'power voltage _is_ a problem'.... |
it supplies it with 4V i checked so no worries  |
ezflyr
Posted: Tue May 06, 2014 8:43 am |
moryoav,
Hmmm, read section 3 of the ADH8066 datasheet you posted. In fact, read the entire document.
John |
moryoav
ezflyr
Posted: Tue May 06, 2014 9:13 am |
moryoav,
Have you opened 'SJ4' and 'SJ5' to isolate the ADH8066 TxD and RxD signals from the FTDI USB chip? You don't want the FTDI chip in parallel with the PIC.
Also, walk before you run. When you are successfully communicating with the ADH8066, the module will respond with 'OK' when you send the 'AT' command.
You do have the AT command set document or the ADH8066, right?
John |
moryoav
Posted: Tue May 06, 2014 9:30 am |
| ezflyr wrote: | moryoav,
John |
what do you mean by opening them? to unsolder them? also how will that help?
and i do have the gsm and the AT commands. as i said before, i had no problems communicating with it- sending sms text and making a call. but now i need to do those things with a code and not via a terminal, and here i've no idea where to start.
i tried doing the same as i did with the EMIC (printf the AT commands) but it did not work so i came here for help :\ |
ezflyr
Posted: Tue May 06, 2014 11:40 am |
Yes, unsolder them. The ADH8066 cannot be connected to the FTDI chip and the PIC same time. This is a clear hardware problem.
Unsolder these connections and see if the PIC receives an 'OK' when you send "AT" and a carriage return.
John |
moryoav
Posted: Tue May 06, 2014 12:04 pm |
| ezflyr wrote: | Hi,
John |
a main part of the problem is that i dont know HOW to write the programs to do those stuff. i dont know how to talk to the ADH8066 through the PIC in a C code. how do i adress to those pwr_ON\answer from the GSM pins or whatever? i've went though every link in google and i just can't understand it.
anyways i unsoldered them and ran the same program again and nothing happened. i also noticed that the RX\TX LEDs are not even blinking. |
ezflyr
Posted: Wed May 07, 2014 8:26 am |
Hi moryoav,
Frankly, you've bitten off quite a complex for a beginner. I would advise you to step back a bit and forget the ADH8066 for a moment. Instead, connect your PIC to your PC and experiment with serial communications with this combination first, before moving on to the ADH8066. Search the forum archives, as this has been covered many, many times before! Also, there is a complete GSM modem project in the Code Library that you could use as the basis for your project.
John |
moryoav
Posted: Thu May 08, 2014 6:02 am |
now i REALLY need help. now that the FTDI's rx soldering is ruined.
the only way i can talk to the gsm is through c codes and i dont know how -___-
how do i address in the code to the pins of the eval board?
for example: i want to turn off a led when the uC receives an OK from the GSM.
i wrote the following code:
#fuses NOWDT, HS
#use rs232 (baud=2400, xmit=PIN_C6, rcv=PIN_C7,stream=GSM, ERRORS)
output_high(PIN_B6); //LED
fprintf(GSM, "AT\n\r");
// fprintf(GSM, "0x0D 0x00"); //is this command needed instead of the \n\r?
if(input(PIN_B7)) //receives an OK from the GSM (had it connected to the DTR pin. is that the right connection to make?)
output_low(PIN_B6);
ezflyr
Posted: Thu May 08, 2014 6:47 am |
Hi moryoav,
Sorry to hear about your ADH8066 evaluation board! I hope that you have access to a low wattage soldering iron, and possibly some solder wick? Anything else, and you'll probably dislodge copper traces/pads on the board!
First, I used the Sparkfun ADH8066 evaluation when I was beginning my AHD8066 development effort. I found this board to be poorly designed (by Sparkfun), and configured in a way that was contrary to specific recommendations made by ADH in their hardware design guide. I find that a lot of the Sparkfun 'designs' are poor in this regard. Having said that, I got it to work fine for my initial development work. Basically, I used it to 'play' with the ADH8066 to see how it responded to the 'AT' command set, and to log the messages it would generate so that I could design a robust parsing routine.
From your comments, it seems that you are unclear about how the ADH8066 communicates with it's host microprocessor. This communication is done using asynchronous serial communications. For example, when the PIC host sends 'AT\r' to the ADH8066 via its UART Tx pin, the ADH8066 will (hopefully!) respond with 'OK' that is received via the PIC UART Rx pin. The required hardware connections are:
PIC UART Tx ---> ADH8066 UART Rx
PIC UART Rx <--- ADH8066 UART Tx
In general, the volume of data sent back and forth between the PIC and the ADH8066 is quite modest, so I do not use any hardware flow control. I connect ADH8066 pins DSR0 and DTR0 to ground thru 1K ohm resistors to disable flow control.
You will want your PIC to control the power up sequence of the ADH8066. I use a PIC pin configured as digital I/O to control the 'On_Key' signal using a BJT transistor and some discrete components. I also use two digital inputs to monitor the 'Net_Ready' and 'CMD_Ready' signals generated by the ADH8066. These signals let me know when everything is 'Good To Go'!
Just an FYI. I have designed several commercial products based on the ADH8066, but recently started to use the SIM900 for new designs as the ADH8066 is now 'end-of-life'. The SIM900 also has the advantage of being quite a bit cheaper that the ADH8066, although you need more external support components (antenna connector, SIM socket, etc.)
John
PS Did you look at the GSM 'driver' in the Code Library written by forum user 'Gabriel'?? He shows a couple of routines that will allow you to test the serial communications between the PIC and ADH8066. |
moryoav
Posted: Thu May 08, 2014 7:30 am |
| ezflyr wrote: | Hi moryoav,
John
if your'e saying all it takes is to connect Rx to Tx and Tx to Rx, which is what i did, then all i can say is that my code is wrong.
as i said before, the Rx\Tx LEDs on the eval board does not even blink when i run the code.
so, is the first code i posted alright?
| Code: | void main()
delay_ms(5000);
delay_ms(15000);
also i will look for the said guide and hope it will help me.
thanks for the answer and sorry for the bother  |
