uma
| what are the steps to read a digital input like toggle swtch |
Posted: Sat Apr 19, 2014 12:29 am |
give me the basic idea to write code to read a digital input using 16F877a in CCS compiler and to display a message as that particular" DI is high" in LCD . waiting for the reply. _________________ uma
Application Engineer,
ETPL |
Mike Walne
Posted: Sat Apr 19, 2014 2:33 am |
Start by doing an LED flasher.
When it flashes at the correct speed you know the compiler & PIC are working properly.
Progress to making a switch control the LED.
Next get the LCD to do "Hello World".
Finally merge the switch and LCD codes.
CCS provides schematics for the hardware, and examples for all the code.
Mike |
uma
Posted: Sat Apr 19, 2014 3:05 am |
OK sure ,i will come back with the concept again.thank you. _________________ uma
ETPL |
ezflyr
Posted: Sat Apr 19, 2014 5:34 am |
Look at the 'input' function....
If (input(Pin_A0))
Printf("Pin A0 is high\n\r");
Else
Printf("Pin A0 is low\n\r");
John |
gpsmikey
Posted: Sat Apr 19, 2014 8:57 am |
Don't forget you have to debounce the switch or you will get LOTS of switch activations
mikey _________________ mikey
uma
| is the format rgt to link led ,Lcdand switch? getting error |
Posted: Mon Apr 28, 2014 6:36 am |
I am getting error as numeric expression is expected. I want to on/off switch and corresponding LED as a do should be on/off. Msg is respectively displayed in LCD.
#include <16f877a.h>
#fuses XT,NOWDT,NOPROTECT,BROWNOUT,PUT,NOLVP
#define Button Pin_C4;
#define Led Pin_B4;
#include <lcd.c>
lcd_init();
//lcd_putc,("/f welcome to ETPL");
//lcd_putc,("/n LCD interface");
If(input(Pin_C4))
Printf(" Pin C4 is high\n\r");
output_B(0);
output_high(Pin_B4);//PIN_B4=1;
Else
Printf("Pin C4 is low/n/r");
ETPL |
alan
Joined: 12 Nov 2012 Posts: 358 Location: South Africa
Posted: Mon Apr 28, 2014 6:53 am |
If(input(Pin_C4))
output_B(0);
Else
You need to add the brackets as shown. |
bkamen
Joined: 07 Jan 2004 Posts: 1619 Location: Central Illinois, USA
Posted: Mon Apr 28, 2014 8:17 am |
For what it's worth,
I'm a HUGE fan of ALWAYS encapsulating conditional statements with brackets/braces (whatever the language uses).
I never use:
If ()
statement;
statement;
I ALWAYS use:
If () {
statement;
} else {
statement;
I've seen too many bugs of people adding things to conditionals that didn't use braces and when they added stuff, the braces didn't go in, the extra code didn't run right. _________________ Dazed and confused? I don't think so. Just "plain lost" will do. :D |
drh
Joined: 12 Jul 2004 Posts: 194 Location: Hemet, California USA
Posted: Mon Apr 28, 2014 8:32 am |
| Quote: |
[/code]
#define Led Pin_B4;
#include <lcd.c>
Remove the ; from the PIN_C4 and PIN_B4 defines. _________________ David |
Mike Walne
| Re: is the format rgt to link led ,Lcdand switch? getting er |
Posted: Mon Apr 28, 2014 5:09 pm |
| uma wrote: | I am getting error as numeric expression is expected. I want to on/off switch and corresponding LED as a do should be on/off. Msg is respectively displayed in LCD.
#define Led Pin_B4;
#include <lcd.c>
lcd_init();
If(input(Pin_C4))
output_B(0);
Else
1) Code offered is neither complete nor compilable.
2) lcd_init(); should not be inside while loop. Only needs to happen once.
3) Insert a 1 second delay before initialising LCD to allow device to settle.
4) You have defined Button and Led, then do not use them!!!
Mike |
uma
Posted: Mon Apr 28, 2014 11:09 pm |
I am connecting the button switch to pin C4 and LED to Pin B4, then how can i mention that in the code mr. mike, especially to link everything in the main code? _________________ uma
ETPL |
uma
Posted: Mon Apr 28, 2014 11:28 pm |
After putting Brace,
my code is,
#define Led Pin_B4;
#include <lcd.c>
lcd_init();
If(input(Pin_C4))
output_B(0);
//PIN_B4=1;
Else
link for screen shot:
http://s28.postimg.org/rdpepndel/screen_with_connection.jpg _________________ uma
ETPL |
Mike Walne
Posted: Tue Apr 29, 2014 2:23 am |
Your code is still neither complete nor compilable.
1) Count the opening and closing braces.
2) I said put the delay BEFORE the lcd_init().
3) You are still not using the Button and Led defines in your code.
Mike |
uma
Posted: Wed Apr 30, 2014 12:56 am |
sorry i put the braces correctly,the mistake occurred in the above code while copying.but i didnot understand that u have told me i have not used the defines LED and button,i used it as pin C4 and B4, then how to use it? _________________ uma
ETPL |
