PIC24 doesn't wake up with WDST
alfaec
PostPosted: Fri Mar 28, 2014 10:26 am     Reply with quote
Here is my problem.
I'm using PIC24FV32KA302 with CCS PCD 5 and i'm testing Wake Up from Deep Sleep using DS Watchdog.
Attached you can find my simple test code.
I don't understand what are not running, because one time hardware go to sleep, it could not wake up using internal watch dog deep sleep functionality.
Can someone tell me where i'm wrong?
What's your running source code with this PIC?
If i use Wake Up from Deep Sleep using EXT INT0, everything is working properly.
#include <24FV32KA302.h>      // compiler include
#word   rRCON = 0x0740
int16   wRCON;
#locate wRCON = 0x0740
#fuses   NOBROWNOUT
#fuses  NOPUT
#fuses    DSWDT, DSWDT32
#use delay(internal=8M)
#use fast_io(ALL)
void go_2_sleep(void) {
   sleep(SLEEP_FULL);
   reset_cpu();            //  IRRELEVANT
void main(void) {
   setup_oscillator(OSC_INTERNAL, 8000000);
   #asm
      BCLR   wRCON,#10   // RESET DPSLP (RCON<10>)
      BCLR   wRCON, #0   // RESET RELEASE (RCON<0>)
   #endasm
   set_tris_a(0x77);      // MY TEST BOARD
   set_tris_b(0x45FE);      // MY TEST BOARD
   unsigned int16   i;
   for (i=0; i<0xf000; i++) {
      #asm
         NOP
         NOP
         NOP
      #endasm
   go_2_sleep();
_______________________
Alessio Fabbri
rikotech8
re
PostPosted: Fri Mar 28, 2014 11:05 am     Reply with quote
Try to enable WDT in software.
A person who never made a mistake never tried anything new.
PostPosted: Fri Mar 28, 2014 11:39 am     Reply with quote
If you don't fiddle around with assembler, and let the compiler locate things, you find an error at once:
#bit DPSLP=getenv("BIT:DPSLP")
#bit RELEASE=getenv("BIT:RELEASE")
#fuses   NOBROWNOUT
#fuses   NOPUT
#fuses   DSWDT, DSWDT32, DSWDTCK_LPRC
#use fast_io(ALL)
   sleep(SLEEP_FULL);
void main(void) {
   DPSLP=FALSE;
   RELEASE=FALSE;
   unsigned int16   i;
     delay_cycles(3);
   go_2_sleep();
If you look at the listing, you see:
....................    DPSLP=FALSE;
0236:  BCLR.B  741.2
....................    RELEASE=FALSE;
0238:  BCLR.B  758.0
Note the different register address.
your code reset RCON:0, which is POR, not RELEASE.....
I also explicitly select the LPRC oscillator, It _should_ default to this, but never _assume_ defaults. Smile
Re: re
PostPosted: Fri Mar 28, 2014 11:40 am     Reply with quote
No, he is using the deep sleep watchdog, which is separate from the 'normal' watchdog, that the software enable affects. It is a big difference about these chips....
alfaec
re: Ttelmah
PostPosted: Sat Mar 29, 2014 1:46 am     Reply with quote
Thank you Ttelmah
I'm going to test your code on my environment.
Alessio Fabbri
