tonkostz
| Pwm and frequency generator |
Posted: Fri Mar 28, 2014 8:43 am |
I am trying to make a variable duty and variable frequency generator.
I use two pots connected to AN0 and AN1 adc channels.
Duty cycle should vary from 1% to 99% and the frequency - from 400Hz to around 2KHz.
I tryed following software method but the frequency range is not enough. Give me an idea how to increase the frequncy range without affecting the duty cycle.
My compiler version is 4.120.
| Code: | #include <18F4550.h>
#device *=16
#fuses HSPLL,PLL5,CPUDIV1,NOWDT,MCLR,USBDIV,VREGEN,NOLVP
#use delay(clock=48000000)
#define PWM_OUT PIN_C1
#define TIMER0_PRELOAD 149
#define LOOPCNT fr
int16 fr=0,width=0;
#INT_TIMER0
void tick_interrupt(void)
static int16 loop = LOOPCNT;
static int16 pulse;
set_timer0(get_timer0()+TIMER0_PRELOAD);
if(--loop==0)
loop=LOOPCNT;
pulse=width;
if(pulse)
output_high(PWM_OUT);
pulse--;
else output_low(PWM_OUT);
setup_timer_0(RTCC_INTERNAL | RTCC_DIV_1 | RTCC_8_BIT);
set_timer0(TIMER0_PRELOAD);
setup_adc(ADC_CLOCK_DIV_64);
setup_adc_ports(AN0_TO_AN1);
while(true)
set_adc_channel(0);
delay_us(25);
fr=read_adc();
if(fr>1022) fr=1023;
if(fr<50) fr=50;
set_adc_channel(1);
delay_us(25);
width=read_adc();
if(width<1) width=1;
if(width>150) width=150;
alfaec
Posted: Fri Mar 28, 2014 10:46 am |
Hi
I don't know if you can help you.
I'm using this interrupt timer routine where i modify the value of "pwm_tm" variable
in main.
#define PWM_TIMER 500 // duty cycle
int1 pwm_so
int16 pwm_tm
#int_timer1
void pwm_clock(void) {
if (pwm_so) {
// OFF
set_timer1(0xffff - (PWM_TIMER - pwm_tm));
else {
// ON
set_timer1(0xffff - pwm_tm);
pwm_so = ~pwm_so;
_________________ _______________________
Alessio Fabbri |
Posted: Fri Mar 28, 2014 11:38 am |
with what sort of resolution per step of PWM duty cycle change??
1% ?" 10 25% , .1% ????
what you want to do is a tall order ESPECIALLY with the 4550 as it is!
if i were trying to do such a thing - i believe i would use a 16F1509
with a maximally fast clock - for its NCO function - and use the nco
OUTput to drive two out of three modules interconnected in an 82C54 -
to get a phase locked , precise digital 'one shot'- for high resolution PWM control.
in short more circuitry and less PIC in the solution...... |
alfaec
Posted: Sat Mar 29, 2014 2:16 am |
Hi asmboy
The frequency, using Timer0 as 16bit Timer, can vary from 6 MHz theoretically (1 bit resolution timer) to 91 Hz (2^16 preset timer).
Realistically, using 16 bit timer, you could vary from 23,4 kHz ( 2^8 preset timer to 183 Hz (2^15 bit preset timer), so the execution time of the interrupt does not affect the frequency.
The accuracy is very high.
I think that your pic has sufficient performance to do the job required.
Your problem is that you are using two pots that have an 8 bit resolution, so you cannot achieve the desired performance. _________________ _______________________
Alessio Fabbri |
Posted: Sat Mar 29, 2014 8:07 pm |
the OP's code setup for timer0 as 8 bit ,
will rollover every 21.3 uSecs -
or 256 I-cycles of the pic. the .LST file clearly shows in the area of the int handler that the INT steals even more cycles from the foreground.
based on the above-
it is difficult to see how this is going to allow the part of the program in MAIN() to be anything but severely impaired -jitter wise. |
