davt
| humidity sensors |
Posted: Thu Oct 16, 2003 8:50 am |
Hi all
Can anyone recomend a humidity sensor which is cheap and relatively accurate and is easily interfaced to a Pic. I have looked at the sensirion SHT11 but this seems quite expensive and from what I gather needs linearising. If this is the only reasonable device has anyone got a snipet of code to evaluate it?
Many thanks for any help.
Regards.
Dave |
TSchultz
Joined: 08 Sep 2003 Posts: 66 Location: Toronto, Canada
Posted: Thu Oct 16, 2003 9:22 am |
The nature of humidity sensor is such that they are difficult to read. From a micro point of view the Sensitron is the easiest to handle since it already has a digital interface. Most of the RH sensors available are either capacitive or inductive and they require specialized excitation and conditioning circuitry to abtian a useable signal. In addition most of them are extremely non-linear, many are actually logarithmetic. An added problem is they are all influenced by temperature and in most cases have to be compensated.
The Philips H1 is one of the more common sensors, it is capacitive with a typical capacitance of 122pF @ 43%RH and has a change of 0.4pF per % RH. Another is Panametrics MiniCap 2, it is also capacitive with a typical capacitance of 207 pF @ 33 % RH, and has a change of 0.3pF per % RH. The Panametrics sensor tends to be fairly linear if driven properly.
Accuracy of these, or any other RH sensor, is highly dependant upon many things, the actual circuit used, the components used, the environment, and contaminants, etc. Keep in mind that many of these sensors are also also very sensitive to contanimants and can be damaged by exposure to things like acetone. They fail becuase the contaminant actually degrades the hygroscopic polymer coating used in the sensor itself.
Some of the newer RH sensors such as the Hygrometrix HMX2000 are micromachined silicon sensors, provide a DC output, are more linear, and are easier to interface to a micro.
The final decision will depend very much on how many you will use, the cost target, and how much work you are willing to invest. All of the RH sensors have their pros and cons, and after having spent the last 15 years working with many of these sensors, I can tell you that they are not at all what they appear to be on paper. |
Neutone
Posted: Thu Oct 16, 2003 9:23 am |
| When it comes to measurements accuracy has cost. That SHT11 is an accurate part. As far as linearising goes that only improves it's accuracy. How good is good enough? |
rrb011270
| Re: humidity sensors |
Posted: Thu Oct 16, 2003 6:17 pm |
Check below: This is a code I coded for SHT1x... the code has not yet implemented the Checksum features of the SHT1x...
I guess u can figure it out by reading the appnotes from sensirion...
Yes, SHT1x is an accurate temp & humidity sensor...
| davt wrote: | Hi all
Regards.
Dave |
#include <18F452.h> // MCU specific library
#device ICD=TRUE // with an ICD debugger
#fuses HS,NOLVP,NOWDT,PUT // high speed, no watch dog timer
#use delay (clock=20000000) // 20MHz clock
#include <math.h>
// set DATA to PortA1 and SCK to portA2
#define DATA PIN_A1
#define SCK PIN_A2
#define noACK 0
#define ACK 1
// SHT1x address=000 is currently supported
// SHT1x command code
//adr command r/w
#define STATUS_REG_W 0x06 //000 0011 0
#define STATUS_REG_R 0x07 //000 0011 1
#define MEASURE_TEMP 0x03 //000 0001 1
#define MEASURE_HUMI 0x05 //000 0010 1
#define RESET 0x1E //000 1111 0
// constant use for SHT1x Humidity Measurement
#define C1 -4.0
#define C2 0.0405
#define C3 -0.0000028
// constant use for SHT1x Temperature Measurement
#define D1 -40.0
#define D2 0.01
// constant use for SHT1x True Humidity Measurement
#define T1 0.01
#define T2 0.00008
// SHT1x Transmission Start Sequence
void sht1x_xmission_start()
output_high(DATA);
output_low(SCK);
delay_us(2);
output_high(SCK);
delay_us(2);
output_low(DATA);
delay_us(2);
output_low(SCK);
delay_us(2);
delay_us(2);
delay_us(2);
output_high(SCK);
delay_us(2);
output_high(DATA);
delay_us(2);
output_low(SCK);
delay_us(2);
// SHT1x Connection Reset Sequence
void sht1x_connection_reset()
int i;
output_high(DATA);
for (i=0; i<9; i++)
output_high(SCK);
delay_us(2);
output_low(SCK);
delay_us(2);
sht1x_xmission_start();
// SHT1x Address & Command Mode with address=000
void sht1x_command_mode(int iMode)
int i;
for (i=128; i>0; i/=2)
if (i & iMode) output_high(DATA);
else output_low(DATA);
delay_us(2);
output_high(SCK);
delay_us(2);
output_low(SCK);
output_float(DATA);
delay_us(2);
output_high(SCK);
delay_us(2);
output_low(SCK);
// delay >11ms for 8-bit measurement
// delay >55ms for 12-bit measurement
// delay >210ms for 14-bit measurement
// before data read from SHT1x
delay_ms(250);
// SHT1x Soft Reset
// resets the interface, clears the status register to default values
// wait minimum 11ms before next command
void sht1x_soft_reset()
sht1x_connection_reset();
sht1x_command_mode(RESET);
// read data from SHT1x and store
long sht1x_read_data()
int i;
long lTmp;
long lVal1=0;
long lVal2=0;
long lValue;
// get MSB from SHT1x
for (i=0; i<8; i++)
lVal1<<=1;
output_high(SCK);
lTmp = input(DATA);
delay_us(2);
output_low(SCK);
delay_us(2);
if (lTmp) lVal1|=1;
// acknowledge routine
output_high(SCK);
output_low(DATA);
delay_us(2);
output_float(DATA);
output_low(SCK);
delay_us(2);
// get LSB from SHT1x
for (i=0; i<8; i++)
lVal2<<=1;
output_high(SCK);
lTmp = input(DATA);
delay_us(2);
output_low(SCK);
delay_us(2);
if (lTmp) lVal2|=1;
lValue = make16(lVal1,lVal2);
return(lValue);
// calculate dewpoint
float sht1x_calc_dewpoint(float fRh,float fTemp)
float fDewpoint;
float fLogEW;
fLogEW = ((7.5*fTemp)/(237.3+fTemp))+log10(fRh)-1.33923;
fDewpoint = ((0.66077-log10(fLogEW))*(237.3))/(log10(fLogEW)-8.16077);
return(fDewpoint);
// Main Program
main()
float fRh_lin;
float fRh_true;
float fTemp_true;
float fDew_point;
long lValue_rh;
long lValue_temp;
setup_adc_ports(NO_ANALOGS);
while (TRUE)
// delay >11ms before next command
delay_ms(12);
// start transmission
// measure temperature
sht1x_command_mode(MEASURE_TEMP);
lValue_temp = sht1x_read_data();
// temperature calculation
fTemp_true = (D1+(D2*lValue_temp));
// delay 11ms before next command
delay_ms(12);
// measure relative humidity
sht1x_command_mode(MEASURE_HUMI);
lValue_rh = sht1x_read_data();
// relative humidity calculation
fRh_lin = (C1+(C2*lValue_rh)+(C3*lValue_rh*lValue_rh));
fRh_true = (((fTemp_true-25)*(T1+(T2*lValue_rh)))+fRh_lin);
// dewpoint calculation
fDew_point = sht1x_calc_dewpoint(fRh_true,fTemp_true);
printf("\nTemperature: %3.6fC",fTemp_true);
printf("\nRelative Humidity: %3.6f%%",fRh_true);
printf("\nDew Point: %3.6fC",fDew_point);
printf("\n");
| [/code] |
jamesjl
| No change in LSB |
Posted: Sun Nov 02, 2003 5:04 am |
I have spent some time looking at your code and producing an implementation of it my self with no real modifications to the main code routines. It appears to work well but I am not getting any change in the LSB when I fetch the 14 bits of the temperature word or the 12 bits of the RH word.
For example
lValue_temp = 6655 = 001100111111111 = 26.6
lValue_temp = 6691 = 001101011111111 = 29.1
The above two samples are consecutive with nothing generated in between that is different.
As you can see there is no change in the values of the lsb in each case.
This gives me a resolution of 2.55 degress not the 0.01 resolution specified by the manufacturer.
I have included my entire listing but as you can see very little is different to your original. I have used a different controller and frequency (16F874 @ 4MHz) but that is all.
Any help that can be offered is greatly appreciated.
Kind regards,
Jason James.
#include <16F874.h> // MCU specific library
#fuses XT,NOLVP,NOWDT,NOPUT, NOBROWNOUT
#use delay (clock=4000000) // 4MHz clock
#use rs232(baud=4800, xmit=PIN_C6, rcv=PIN_C7, bits=8, parity=N)
#include <math.h>
#define DATA PIN_A1
#define SCK PIN_A2
#define noACK 0
#define ACK 1
//adr command r/w
#define C1 -4.0
#define C2 0.0405
#define D1 -40.0
#define D2 0.01
#define T1 0.01
#define T2 0.00008
output_high(DATA);
output_low(SCK);
delay_us(2);
output_high(SCK);
delay_us(2);
output_low(DATA);
delay_us(2);
output_low(SCK);
delay_us(2);
delay_us(2);
delay_us(2);
output_high(SCK);
delay_us(2);
output_high(DATA);
delay_us(2);
output_low(SCK);
delay_us(2);
int i;
output_high(DATA);
for (i=0; i<9; i++)
output_high(SCK);
delay_us(2);
output_low(SCK);
delay_us(2);
int i;
delay_us(2);
output_high(SCK);
delay_us(2);
output_low(SCK);
output_float(DATA);
delay_us(2);
output_high(SCK);
delay_us(2);
output_low(SCK);
delay_ms(250); //250
// SHT1x Soft Reset
int i;
long lTmp;
long lVal1=0;
long lVal2=0;
long lValue;
for (i=0; i<8; i++)
lVal1<<=1;
output_high(SCK);
lTmp = input(DATA);
delay_us(2);
output_low(SCK);
delay_us(2);
if (lTmp) lVal1|=1;
output_high(SCK);
output_low(DATA);
delay_us(2);
output_float(DATA);
output_low(SCK);
delay_us(2);
for (i=0; i<8; i++)
lVal2<<=1;
output_high(SCK);
lTmp = input(DATA);
delay_us(2);
output_low(SCK);
delay_us(2);
if (lTmp) lVal2|=1;
return(lValue);
float fDewpoint;
float fLogEW;
return(fDewpoint);
// Main Program
float fRh_lin;
float fRh_true;
float fTemp_true;
float fDew_point;
int8 counter;
long lValue_rh;
long lValue_temp;
delay_ms(2000);
while (TRUE)
// sht1x_connection_reset();
delay_ms(12);
delay_ms(12); //12
// Format of transmitted string for processing by PC
// !!lValue_temp,lValue_rh??
printf ("!!%lu,%lu??",lValue_temp, lValue_rh);
// Five seconds between successive samples.
delay_ms(5000);
Viltor Guest
| The routine acknowledge is erroneous |
Posted: Mon Dec 08, 2003 1:15 pm |
This is the good
output_low(DATA);
output_high(SCK);
delay_us(2);
output_low(SCK);
output_float(DATA);
delay_us(2);
Regards
Viltor
http://webs.ono.com/viltor |
dazlogan
Joined: 19 Oct 2003 Posts: 24 Location: Cambridge, UK
| Precision |
Posted: Mon Dec 08, 2003 1:25 pm |
Just for your information:
If you a looking for precision humidity measurement, then visit www.michell-instruments.com.
They are leaders in the field.
Unfortunately though, they don't supply sensors on their own, only fully fledged transmitters and precision dew point meters.
Regards,
Darren |
picprogrammer
Posted: Tue Nov 23, 2004 4:28 pm |
Same like i posted in another thread:
output_low(DATA);
delay_us(2);
output_high(SCK);
delay_us(2);
output_low(SCK);
output_float(DATA);
delay_us(2);
It runs ok on a 18F452 16mhz |
phaychee
Posted: Thu Jan 11, 2007 5:41 am |
hi there
I had tried on the SHT11 code as above.
And for the result, sometimes it can display the reading of humidity and temperature correctly.
But after a few seconds it will display the fault humidity value , such as 2933.14% something like that.
May I know what happen to my SHT11? |
Piccolo
Posted: Thu Jan 11, 2007 7:54 am |
Take a look at HIH-4000 relative humidity sensor from Honeywell.
It has a linear output and good accuracy |
mfer
Posted: Thu Jan 11, 2007 8:19 am |
Hello.
I used HIH-4000 with Microchip MCP3221, which gives I2C output. Works fine. Note, that HIH-4000 has rather fast response. (o.k., compared to what, but for me it was fast enough)
Regards,
mfe |
asmallri
Joined: 12 Aug 2004 Posts: 1670 Location: Perth, Australia
Posted: Thu Jan 11, 2007 8:35 am |
| phaychee wrote: | hi there
I use the SHT7x sensors which are higher precision versions of the SHT1x sensors. I use these sensors in precision environmental monitoring systems which operate in harsh conditions and they have proven very reliable, stable, and repeatable. I use my own CCS drivers and sample application including CRC validation. _________________ Regards, Andrew
phaychee
Posted: Thu Jan 11, 2007 8:48 pm |
asmallri,
hi, although we r not using the same humidity sensor from sensiron, but can u post up ur sht 7X driver for reference?
Btw, u also don't know what is my sensor problem right?
Thanks anywhere.
Piccolo and mfer,
I had considered sensor from Honeywell before, but it is too expensive if compare to SHT11  |
asmallri
Posted: Fri Jan 12, 2007 1:53 am |
| phaychee wrote: | asmallri,
hi, although we r not using the same humidity sensor from sensiron, but can u post up ur sht 7X driver for reference? |
These sensor use the same low level driver. I cannot post the driver - it is a commercial product and I sell the driver source code.
[quote]
Btw, u also don't know what is my sensor problem right? [/qoute]
No I do not know your problem. It is possible, but unlikley, that you have a faulty sensor. Either you have a software problem or more likely you have a corrupted data stream.
The corrupted data stream will give you weird results which is why you should use CRC to validate the message from the sensor to the PIC.
A common mistake with first time users of these sensors is to forget to use pull up resistors on the clock and data lines to the sensor or, if using the SMD part, forgetting the 0.1uF capacitor which must be mounted as close as possible to the sensor PCB. _________________ Regards, Andrew
rnielsen
Posted: Fri Jan 12, 2007 12:18 pm |
The SHTXX series sensors are not completely I2C compliant. The SHT15 is a more precise version of the SHT11. The SHT7X is the same but only in a different packaging.
The SHTXX sensors are not I2C compliant because the Start signal requires both a Start and Stop signal to tell the sensor that you want to talk to it. The address command then tells it what you want to do (write to a register or read a value out of it). I've used this sensor a lot and I have to bit-bang the signals to it. They are quite reliable and I've not had one go bad that was placed into a production environment. The sensor has a register that contains the calibration values for it. The spec. sheet contains the formulas that will ensure the linearity is correct. It also contains a bit that will tell you when the End-of-Life has been reached. You should poll this register once in a while to make sure that the calibration is within spec.
Ronald |
