mbarrett
| Oscillator fuses for PIC24H device |
Posted: Wed Mar 05, 2014 5:32 am |
I have just changed from using a 18F device to a 24H device, most of the code works but I do find the fuses for the oscillator very confusing!
from the header file I lots of options
FRC,FRC_PLL,PR,PR_PLL,SOSC,LPRC,FRC_DIV_BY_16,FRC_PS,NOIESO,IESO,EC,XT,HS,NOPR, OSCIO,NOOSCIO
but I find it difficult to map these to the configurations in the data sheet.
Am I missing something is there a document somewhere that could help or do I need just to try them and then look at the code and reverse engineer what they mean?
I guess the problem is using a compiler that is compatable with such a large range of devices, but it is good to be able to move code between devices.
thanks
mike |
Posted: Wed Mar 05, 2014 5:46 am |
In the compiler directory.
Fuses.txt.
Gives the CCS names, and what they are....
mbarrett
Posted: Wed Mar 05, 2014 5:57 am |
| Ttelmah wrote: | In the compiler directory.
Fuses.txt.
Thankyou!
did not know that file was there.
cheers
mike |
Posted: Wed Mar 05, 2014 6:47 am |
Yes, it's worth always 'looking', since there is also a 'readme' with details of recent compiler changes as well.  |
jeremiah
Posted: Wed Mar 05, 2014 9:50 am |
Most PIC24 chips use 2 different fuses to setup your system clock. The first fuse specifies what type of external circuit your chip is connecting to:
EC - External Oscillator Chip
XT - Medium speed crystal
HS - High speed crystal
NOPR - No external primary clock (I.E. using an internal clock)
The second fuse tells the internal system clock mux where the system clock should be routed from. Options for this fuse can vary a lot from chip to chip. Here are some common options:
PR - Primary external clock (previous fuse tells what type)
PR_PLL - Primary external clock + PLL
FRC - Internal Fast RC circuit
FRC_PLL - Internal Fast RC + PLL
SOSC - Secondary external oscillator
LPRC - Internal low power RC circuit
There are other fuses that provide settings for your clocks and their pins:
IESO, NOIESO handle internal to external switching mode
OSCIO, NOOSCIO handle turning external oscillator pins to digital (or not)
SOSC_DIGITAL, SOSC_ANALOG, NOSOSC handle turning secondary oscillator pins to digital (or analog or neither)
There can various others. The big thing is to figure out where you want your clock to come from. If it is internal, set NOPR for the first fuse, and then select the mux setting for which internal you want. If you are using an external chip, use EC with the mux fuse set to PR or PR_PLL. If you are using an external crystal, then use the data sheet to figure out if it is XT or HS and then set the mux fuse for PR or PR_PLL.
NOTE: that some of these fuse names also can change from chip to chip on the older compiler revs.
Joined: 01 Jul 2010 Posts: 9613 Location: Greensville,Ontario
Posted: Wed Mar 05, 2014 10:49 am |
Seems the newer PICs have more fuse settings than instructions !
When I've got a 'set of fuses' that does work, I save it as a file.
Something like '46k22_projectname.fuz', then #include it at the beginning of the programs.
It gives me a known, WORKING set of fuses for all projects with that PIC, saves me a lot of retyping, as I'm not a good typist (half dead finger), and save visual space in 'main' as a whole page of fuses is now in one line!
To me the less clutter on the screen is important.
hth
jay |
newguy
Posted: Wed Mar 05, 2014 12:42 pm |
Depending on the crystal you choose you might also run into issues with the processor's oscillator not starting upon power up. I bought the CCS DSP Analog Development Kit some time ago and just getting it to run was the most frustrating thing I've ever done. Long story short, CCS built the board with a crystal that the processor isn't capable of starting from upon power up. I had to "boot" with the internal oscillator, then immediately do an internal-to-external oscillator switchover.
Details can be found here: http://www.ccsinfo.com/forum/viewtopic.php?p=159723&highlight=crystal#159723 |
