Strange problem with bit set in variable
rikotech8
PostPosted: Sat Mar 01, 2014 4:11 pm     Reply with quote
I want to make a program that would read serial data on interrupt pin.
In this case the data is entered by me via button, therefore the BAUD rate is about 1. Here is the code:
#INCLUDE <16F1508.h>
#FUSES INTRC_IO, NOMCLR, NOWDT, PUT, NOBROWNOUT
#USE delay(clock=16M)
#use rs232(baud=9600, xmit=PIN_C0, rcv=PIN_C2)
#define butt pin_b7
#DEFINE LED PIN_B4
#define IND PIN_C7
#BYTE my_byte=0x20
int i=0;
#INT_RB
void B7_isr(void)                                           //sets serial bit
delay_ms(5);
if(input(butt))
output_toggle(LED);
bit_set(my_byte,i);
printf("\f%u",my_byte);
clear_interrupt(INT_RB7_L2H);
my_byte=0;
int1 s=1;
set_tris_b(0x80);
ENABLE_INTERRUPTS(INT_RB7_L2H);
ENABLE_INTERRUPTS(GLOBAL);
   while(true)
      for(i=0;s=1,i<8;i++)
      output_high(ind);                                        //during high indicator led I can set the bit by pressing button
      delay_ms(700);
      output_low(ind);
      DISABLE_INTERRUPTS(INT_RB7_L2H);
      delay_ms(200);
   s=0;
   my_byte=0;
   while(!input(butt))s=1;                                     //if I press the button filling my_byte resets
The problem is that my_byte can assume the following values: 1,2,4,8,16,32,64,128; I don't know why but if I set 1st and 2nd bits my_byte is dec. 2 instead of dec. 3. If I set 1st, 2nd and 5th bits, my_byte
is dec 32. Each less significant bit is being cleared when I set next one.
I know it is little bit confusing, but if you test the code you will see the outcomes.
A person who never made a mistake never tried anything new.
PostPosted: Sun Mar 02, 2014 11:59 am     Reply with quote
1- don't printf inside the ISR !!!!!
2- READ port b to clear the isr Inside the INT handler code
3- rethink the logic of what you coded , while you are at it.
a state machine can do this better - and maybe even without need of an ISR
then see where you are ....
PostPosted: Sun Mar 02, 2014 12:19 pm     Reply with quote
and, since you use delays in the ISR, interrupts will be disabled in all the external delays - the 700mSec...
The actual read will then occur after the LED goes out.
rikotech8
PostPosted: Mon Mar 03, 2014 5:04 am     Reply with quote
Thank You both!
I think it is done by this line
if(input(butt)) //B7
Isnt it enough to read a single bit of the port to clear the interrupt?
