datvo06
| si4432 module |
Posted: Sat Feb 22, 2014 10:27 pm |
Hi everyone.
I've been trying to get si4432 module to work for several weeks but no luck. I can't figure out what's the problem, it seems that tx is working but I am unable to receive packets.
Can anyone provide a simple working code for si4432 & ccs please ?
Thanks for you guys help! |
Posted: Sun Feb 23, 2014 1:59 am |
First, if this is a new product, look at the 4460 instead.
The 4430, is obsolete, and is not guaranteed to be available for much longer. Doing a lot of work on an old product, can be rather a wasted exercise....
There are also a lot of errata for this unit. Have you looked at these?.
Are you running direct mode, or FIFO mode?.
datvo06
Posted: Sun Feb 23, 2014 2:43 am |
Hi Ttelmah,
I tried that, using the excel, translating example code from hoperf and the example code for 8051 to ccs, I'm using software spi from hoperf code and FIFO mode.
also, I got wrong nIRQ signal in Rx and I cant get pass
| Code: | //SW reset
SpiWriteRegister(0x07, 0x80); //write 0x80 to the Operating & Function Control1 register //wait for POR interrupt from the radio (while the nIRQ pin is high)
while ( NIRQ == 1);
//read interrupt status registers to clear the interrupt flags and release NIRQ pin
ItStatus1 = SpiReadRegister(0x03); //read the Interrupt Status1 register
ItStatus2 = SpiReadRegister(0x04); //read the Interrupt Status2 register
//wait for chip ready interrupt from the radio (while the nIRQ pin is high)
while ( NIRQ == 1); // I cant get past this line until I remove it. | Thanks for your reply  |
Joined: 01 Jul 2010 Posts: 9623 Location: Greensville,Ontario
Posted: Sun Feb 23, 2014 6:24 am |
When posting please tell us what PIC you're using,a 'link' to the 'module' that doesn't work right,whether the device is a handsoldered chip or a PCB unit.Also a small,compilable program we can download to test.
Problems are in two catagories, hardware and software.Have you run any basic PIC test programs(1Hz LED, Hello World) to confirm it's 'alive and well'.If the 'module' or 'device' needs a driver, post that. Can you communicate with the device(setting and read back a register ?).
NIRQ.Hmm..have you enabled the appropriate interrupt and cut a good ISR for the PIC(which we don't know...)? Did you test the ISR manually(with a switch, not the device)?
I did lookup the device,saw that it's a 3 volt unit.Obvious hardware issue would be 5V PIC- 3V device.Seems there's a LOT of Ardunio code you could look at after all C is C, more or less....
bottom line, the more info you supply, thre better we can 'armchair diagnose' !
hth
jay |
datvo06
Posted: Sun Feb 23, 2014 7:24 am |
sorry, this is the first time I've ever been posting. Anyway, I'm using pic18f2550 smd and the mcu,connection,spi are fine. I'm testing module on two ordered PCB.
here're the codes:
for RX:
#include <main.h>
#include <string.h>
#use FIXED_IO( A_outputs=PIN_A0,PIN_A1,PIN_A2,PIN_A3,PIN_A4,PIN_A5 )
#use FIXED_IO( B_outputs=PIN_B4,PIN_B3,PIN_B2,PIN_B0 )
#define SDN PIN_B0
#define nIRQ PIN_B1
#define nSEL PIN_B2
#define SCK PIN_B3
#define SDI PIN_B4
#define SDO PIN_B5
#define STATION_1 PIN_A3
#define STATION_2 PIN_A4
#define STATION_3 PIN_A5
#define RUN_USB PIN_A2
#define TXON PIN_A0
#define RXON PIN_A1
typedef unsigned char uchar;
typedef unsigned int uint;
#define RF22_PWRSTATE_READY 01
#define RF22_PWRSTATE_RX 05
#define RF22_Rx_packet_received_interrupt 0x02
#define RF22_PWRSTATE_POWERDOWN 00
uchar ItStatus1,ItStatus2;
uchar RF_RXBUF[35];
void to_rx_mode(void);
void to_ready_mode(void);
uchar spi_read_rf(uchar address);
void send_read_address(uchar i);
uchar read_8bit_data(void);
void spi_write_rf(uchar address, uchar data);
void send_8bit_data(uchar i);
void Write8bitcommand(uchar command);
void RF22_init_parameter(void);
void delay_50ms(void);
void delay_5ms(void);
void delay_1ms(void);
void port_init(void);
void power_on_delay(void);
void Write0( void );
void Write1( void );
void to_sleep_mode(void);
unsigned char* check = "BUTTON1";
//setup_timer_2(T2_DIV_BY_1,166,2);
//setup_ccp1(CCP_PWM);
output_bit(STATION_1,0);
output_bit(RUN_USB,0);
output_bit(RXON,0);
output_bit(TXON,0);
output_float(PIN_B5);
output_high(PIN_A2);
output_float(nIRQ);
RF22_init_parameter();
while(true)
to_rx_mode();
void RF22_init_parameter()
output_low(SDN);
delay_ms(20);
ItStatus1 = spi_read_rf(0x03);
ItStatus2 = spi_read_rf(0x04);
spi_write_rf(0x07,0x80);
while(input(nIRQ));
/*spi_write_rf(0x75,0x53);
spi_write_rf(0x76,0x7D);
spi_write_rf(0x77,0x00);*/
spi_write_rf(0x75,0x75);
spi_write_rf(0x76,0xBB);
spi_write_rf(0x77,0x80);
spi_write_rf(0x1C,0x05);
spi_write_rf(0x20,0xA1);
spi_write_rf(0x21,0x20);
spi_write_rf(0x22,0x4E);
spi_write_rf(0x23,0xA5);
spi_write_rf(0x24,0x00);
spi_write_rf(0x25,0x13);
spi_write_rf(0x1D,0x40);
spi_write_rf(0x72,0x1F);
spi_write_rf(0x2A,0x20);
spi_write_rf(0x33,0x02);
spi_write_rf(0x32,0x00);
spi_write_rf(0x36,0x2D);
spi_write_rf(0x37,0xD4);
spi_write_rf(0x30,0x85);
spi_write_rf(0x71,0x63);
spi_write_rf(0x35,0x28);
spi_write_rf(0x34,0x0A);
spi_write_rf(0x0C,0x12);
spi_write_rf(0x0D,0x15);
spi_write_rf(0x5A,0x7F);
spi_write_rf(0x58,0x80);
spi_write_rf(0x59,0x40);
spi_write_rf(0x6A,0x0B);
spi_write_rf(0x68,0x04);
spi_write_rf(0x1F,0x03);
spi_write_rf(0x09,0xD7);
uchar a= spi_read_rf(0x01);
if(a==0x07) output_high(TXON);
spi_write_rf(0x07,0x05);
spi_write_rf(0x05,0x03);
spi_write_rf(0x06,0x00);
void to_rx_mode()
if(!input(nIRQ))
/*if((ItStatus1 ==0)){
output_low(RXON);
output_high(RXON);
output_low(RXON);
unsigned int8 length;
length = spi_read_rf(0x4B);
if(length==0)
output_low(RXON);
output_high(RXON);
output_low(RXON);
if( (ItStatus1&(0x01)) == 0x01)
spi_write_rf(0x07,0x01);
spi_write_rf(0x08,0x02);
spi_write_rf(0x08,0x00);
output_high(RXON);
delay_ms(10000);
output_low(RXON);
else if((ItStatus1&(0x02)) == 0x02)
int8 i;
for(i=0;i<8;i++)
output_bit(TXON,1);
output_bit(TXON,0);
if(length<11)
for(i=0;i<8;i++)
RF_RXBUF[i] = spi_read_rf(0x7F);
if(length ==8)
if(memcmp(&RF_RXBUF[0], check ,7) ==0)
output_high(RXON);
output_high(TXON);
delay_ms(2000);
output_bit(RXON,0);
output_bit(TXON,0);
if(RF_RXBUF[0]=='B')
//output_high(TXON);
output_bit(RXON,0);
void Write0( void )
// SCK=0;
// NOP();
output_bit(SCK,0);
delay_us(10);
// SDI=0;
// NOP();
output_bit(SDI,0);
delay_us(10);
// SCK=1;
// NOP();
output_bit(SCK,1);
delay_us(10);
void Write1( void )
//SCK=0;
// NOP();
output_bit(SCK,0);
delay_us(10);
//SDI=1;
//NOP();
output_bit(SDI,1);
delay_us(10);
//SCK=1;
//NOP();
output_bit(SCK,1);
delay_us(10);
void Write8bitcommand(uchar command) // keep sel to low
uchar n=8;
nSEL = 1;
SCK=0;
nSEL=0;
output_bit(nSEL,1);
output_bit(SCK,0);
output_bit(nSEL,0);
while(n--)
if(command&0x80)
Write1();
Write0();
command = command << 1;
//SCK=0;
output_bit(SCK,0);
uchar result;
send_read_address(address);
result = read_8bit_data();
// nSEL = 1;
output_bit(nSEL,1);
return(result);
address |= 0x80;
Write8bitcommand(address);
send_8bit_data(data);
//nSEL = 1;
output_bit(nSEL,1);
i &= 0x7f;
Write8bitcommand(i);
uchar n = 8;
//SCK=0;
output_bit(SCK,0);
while(n--)
if(i&0x80)
Write1();
Write0();
i = i << 1;
// SCK=0;
output_bit(SCK,0);
uchar Result, i;
//SCK=0;
output_bit(SCK,0);
Result=0;
for(i=0;i<8;i++)
{ //read fifo data byte
Result=Result<<1;
// SCK=1;
// NOP();
output_bit(SCK,1);
delay_us(10);
if(input(SDO))
Result|=1;
// SCK=0;
//NOP();
output_bit(SCK,0);
delay_us(10);
return(Result);
//TXEN = RXEN = 0;
//LED_GREEN = 0;
output_bit(TXON,0);
output_bit(RXON,0);
spi_write_rf(0x07, RF22_PWRSTATE_READY);
ItStatus1 = spi_read_rf(0x03); //read the Interrupt Status1 register
spi_write_rf(0x07, RF22_PWRSTATE_POWERDOWN);
and TX:
#include <main.h>
#use FIXED_IO( A_outputs=PIN_A0,PIN_A1,PIN_A2 )
#define SDN PIN_B0
#define nIRQ PIN_B1
#define nSEL PIN_B2
#define SCK PIN_B3
#define SDI PIN_B4
#define SDO PIN_B5
#define LED_RED PIN_A2
#define TXEN PIN_A0
#define RXEN PIN_A1
uchar RF_RXBUF[35];
void to_tx_mode(void);
//NOP();
delay_us(10);
to_tx_mode();
void Write0( void )
// SCK=0;
// NOP();
output_bit(SCK,0);
delay_us(10);
// SDI=0;
// NOP();
output_bit(SDI,0);
delay_us(10);
// SCK=1;
// NOP();
output_bit(SCK,1);
delay_us(10);
void Write1( void )
//SCK=0;
// NOP();
output_bit(SCK,0);
delay_us(10);
//SDI=1;
//NOP();
output_bit(SDI,1);
delay_us(10);
//SCK=1;
//NOP();
output_bit(SCK,1);
delay_us(10);
uchar n=8;
nSEL = 1;
SCK=0;
nSEL=0;
output_bit(nSEL,1);
output_bit(SCK,0);
output_bit(nSEL,0);
while(n--)
if(command&0x80)
Write1();
Write0();
//SCK=0;
output_bit(SCK,0);
uchar result;
// nSEL = 1;
output_bit(nSEL,1);
return(result);
address |= 0x80;
//nSEL = 1;
output_bit(nSEL,1);
output_low(SDN);
delay_ms(20);
ItStatus1 = spi_read_rf(0x03); // read status, clear interrupt
while(input(nIRQ));
//spi_write_rf(0x75,0x53);
//spi_write_rf(0x76,0x7D);
//spi_write_rf(0x77,0x00);
spi_write_rf(0x6E,0x4E);
spi_write_rf(0x6F,0xA5);
spi_write_rf(0x70,0x2C);
spi_write_rf(0x72,0x48);
spi_write_rf(0x30,0x0D);
//spi_write_rf(0x5A,0x7F);
//spi_write_rf(0x59,0x40);
//spi_write_rf(0x09,0xD7);
i &= 0x7f;
uchar n = 8;
//SCK=0;
output_bit(SCK,0);
while(n--)
if(i&0x80)
Write1();
Write0();
i = i << 1;
// SCK=0;
output_bit(SCK,0);
uchar Result, i;
//SCK=0;
output_bit(SCK,0);
Result=0;
for(i=0;i<8;i++)
Result=Result<<1;
// SCK=1;
// NOP();
output_bit(SCK,1);
delay_us(10);
if(input(SDO))
Result|=1;
// SCK=0;
//NOP();
output_bit(SCK,0);
delay_us(10);
return(Result);
output_high(TXEN);
spi_write_rf(0x3E,8);
spi_write_rf(0x7F,0x42); //B
spi_write_rf(0x7F,0x55);
spi_write_rf(0x7F,0x54);
spi_write_rf(0x7F,0x4F);
spi_write_rf(0x7F,0x4E);
spi_write_rf(0x7F,0x31);
spi_write_rf(0x7F,0x0D);
spi_write_rf(0x05,0x04);
spi_write_rf(0x07,0x09);
ItStatus1 =spi_read_rf(0x03);
ItStatus2 =spi_read_rf(0x04);
while(input(nIRQ));
output_low(TXEN);
//TXEN = RXEN = 0;
//LED_GREEN = 0;
output_bit(TXEN,0);
output_bit(RXEN,0);
output_bit(LED_RED,0);
[/img] |
Posted: Sun Feb 23, 2014 8:20 am |
hmm..could you post link to the RF PCB unit?
are you running PIC at 3 volts ?
there's no processor type include as the first line of your code....
does the PIC pass the 1Hz LED program ?
hth
jay |
datvo06
Posted: Sun Feb 23, 2014 10:41 am |
It is NEVER good idea to run PIC at 5 V with a 3V external device!
The PICs SPI pins are Schmitt Trigger types and require an input of 80% Vdd(.8 * 5) and that's 4 volts. There is NO way your RF module, running at 3 volts can supply a 'high' logic level.
You can use the Low voltage version of that PIC (PIC18LF2550) and correctly interface with your RF module or you can run that PIC and the rf module from 3 volts.
Check with the datasheet to be sure you can run the PIC at 20MHz at 3 volts though.
hth
jay |
datvo06
Posted: Sun Feb 23, 2014 10:52 am |
I got it now!
because the voltage level isn't enough so the pic can't receive signal from Module.on the other It can still be able to write to module register cause 5V is more than enough...That's why TX still working,but I can't receive anything...and that's why I got the wrong nIRQ low signal,because it's always recognized as low.
Thanks very much ,I'll try again and post the result. |
Posted: Sun Feb 23, 2014 11:02 am |
Look at this thread:
<http://www.ccsinfo.com/forum/viewtopic.php?t=51955>
Look at my reply about SPI voltages.
Same applies to your project...
I see you have just 'got the point', while I posted.
The same answer I gave will also apply to you. Use a logic IC that has 'TTL' compatible inputs, and suitable voltage dividers (to avoid damaging the 3.3v chip), to get round the problem. |
datvo06
Posted: Sun Feb 23, 2014 11:57 am |
thanks guys |
