Question about button() function
sahu77
PostPosted: Tue Feb 18, 2014 11:59 am     Reply with quote
Anybody can explain
 if(button(PIN_A0, 0, 50, 10, A0, 1))
? its sw function.
sahu
PostPosted: Tue Feb 18, 2014 12:19 pm     Reply with quote
Easy ! goto -> http://www.ccsinfo.com/forum/viewtopic.php?t=23837
PCMProgrammer's 'button' function. EVERYTHING you need to know about it is carefully commented. It's his version of the PBP 'button' function.
hth
jay
sahu77
PostPosted: Tue Feb 18, 2014 12:49 pm     Reply with quote
thank you dear temtronic,
i have need 1 simple code for push on switch.
1) push switch till 500 ms
2) count =1
3) ofter 2 sec again push switch till 500 ms
4) count =2
count =8
if( count >=8)
count ==0
pl help me
sahu
ezflyr
PostPosted: Tue Feb 18, 2014 1:51 pm     Reply with quote
Sahu,
Please don't hijack ZombiePIC's thread!! Start your own thread with your switch question! Don't confuse things more than they already are by posting it here!!
John
Split into new thread per request.
- Forum Moderator
ezflyr
PostPosted: Wed Feb 19, 2014 9:45 am     Reply with quote
Hi Sahu,
What is the significance of the 500mS 'On' time, and the 2 second 'Off' time? No intelligently designed User Interface is going to have those constraints 'just because'...... If you use PCM Programmers 'button' function, it will take care of the switch debounce for you, so all you need to do is add the counting code with terminal reset at a count of 8. Should be very easy!
What am I missing?
John
