RTD PT100
Goto page 1, 2  Next
Jim90
RTD PT100
PostPosted: Wed Feb 05, 2014 5:41 pm     Reply with quote
I recently bought a thin film pt100 temperature sensor and i am trying to measure the temperature value.
I built a voltage divider (100ohm + RTD PT100) and in the middle of the two i connect the received value which is going to the microcontroller (measure the temperature value).
The code which i am using is presented below:
         float value;
         value = read_adc();
         printf("VALUE:%fl\n",value);
My problem is that i receiving very high values. I don't understand what is going wrong ?
PostPosted: Wed Feb 05, 2014 6:45 pm     Reply with quote
'very high values' is not a good description to go on.
Typical RTD PT100 devices are 100r@0*C, 138r@100*C, if we assume a Vref of the ADC section to be 5.000 ( PIC power supply), the range is 2.50 to 2.89 volts.
You should tell us the temperature of the sensor and the raw ADC bits.
Also be aware that actual wiring of the sensor, board layout, etc. have a very important part in accurate measurements. Also RTDs are NOT linear devices so you need to do some 'math' to get the best results.
http://www.picotech.com/applications/pt100.html is one quick random 'google' for more information that should be useful.
You don't tell us what PIC, which ADC setup (8 bit, 10 bit, ??), conversion rate, etc. All this is important to know....
hth
jay
Mike Walne
PostPosted: Thu Feb 06, 2014 5:15 am     Reply with quote
You don't tell us which way up your divider is wired.
I'm assuming RTD to GND, 100R to +5V.
Have you read the data sheet for the RTD?
If it's thin film it could be getting hot.
Give us more to go on.
Mike
Jim90
RTD PT100
PostPosted: Thu Feb 06, 2014 7:19 am     Reply with quote
I use dspic33fj128gp802 with voltage Supply equal to 3.3V and ADC: 10 bits
I put a 200ohm resistor in series with rtp and in the middle is connected it to the adc input.(At one side of the resistor i connect a supply and at one side of the rtp i connect ground).
I know that i need to do some maths so to receive the correct value but i have little confusion what exactly i need to do.
I am waiting for your respond.
Mike Walne
PostPosted: Thu Feb 06, 2014 9:31 am     Reply with quote
Is this what your circuit looks like?
              100R           200R
 +3V3 _______WWWWW__________WWWWW______ Analogue I/P
 GND  _______WWWWW______|
              RTD
If it is, 10 bit ADC max reading is 1023.
So if ADC gives ADC_reading. Then calculate RTD resistance from:-
RTD/100 = ADC_reading/(1023-ADC_reading)
Which rearranges to:-
RTD = 100 * ADC_reading/(1023-ADC_reading)
For most RTDs, resistance is approximately proportion to absolute temperature.
So Absolute_Temperature = 273*(RTD/100)
OR in Celsius
Temperature_in_Celsius = Absolute_Temperature - 273
= 273*(RTD/100) - 273
= 273*(RTD/100 -1 )
Job done
Mike
PS If you work in tenths/hundreths of a degree you can use integers throughout and avoid fp maths.
Jim90
RTD PT100
PostPosted: Thu Feb 06, 2014 12:15 pm     Reply with quote
My circuit is :
200R RTD
+3V3 _______WWWWW__________WWWWW______ GND
dspic33
What are the necessary calculations for the above circuit?
Jim90
RTD PT100
PostPosted: Thu Feb 06, 2014 12:16 pm     Reply with quote
200R RTD
dspic33
Now is clear Smile . Sorry for the confusion.
PostPosted: Thu Feb 06, 2014 12:29 pm     Reply with quote
basic OHMs law voltage divider
Vout=(rtd/(rtd+200)) * Vin
rtd=+-100r@0*c
vin=3.3
Of course you must measure vin (it won't be 3.3), rtd value varies according to temperature obviously.
Simple test is to freeze the sensor then let it warm up, measure ADC input and record ADC bits on a chart, say every 10 seconds.
hth
jay
Jim90
RTD PT100
PostPosted: Tue Feb 11, 2014 5:03 pm     Reply with quote
I changed the circuit and I did it as Mike Walne presented.
My confusion is that the Mike Walne and the temtronic explained different ways to processing the input signal.
Can you make it more clear please?
Mike Walne
Re: RTD PT100
PostPosted: Tue Feb 11, 2014 5:15 pm     Reply with quote
Without having seen a clear schematic I was guessing at your voltage divider circuit.
I assumed your rdt was in series with 100R and calculated accordingly.
I also assumed that you're using the 3V3 supply as Vref for the ADC.
temtronic's maths is equivalent to mine but using the 200R which you later told us about.
In order to help you further we need to know exactly what you are doing.
Mike
Jim90
RTD PT100
PostPosted: Sun Feb 16, 2014 3:45 pm     Reply with quote
I came back to continue the project. I use the following circuit:
http://obrazki.elektroda.pl/1446047100_1392586975_thumb.jpg
The Vout = (RTD*VCC)/(RTD+R)
where VCC=3.3v and R=10K
According the following link :
http://www.michshur.co.il/image/users/190375/ftp/my_files/Files/TD_TV_PT1A.pdf?id=8609087
for temperature : -10 c -->R=96.09 and with the use of the Vout equation V=2,98
for temperature: 110c -->R=-->V=3,083
for a 12 bits adc (1023) 120/1023 = 0,111.
what is the next step???
Mike Walne
Re: RTD PT100
PostPosted: Sun Feb 16, 2014 6:01 pm     Reply with quote
There's something wrong with your calculator.
Mike
PostPosted: Sun Feb 16, 2014 8:42 pm     Reply with quote
i suggest using external analog processing of the sensor data, and
an external precision 2.5 volt ADC ref. like the lm4040, since if your last post were correct, it shows you are trying to map a 120 degree span into 127 bits. with a reasonable assumed uncertainty of any single ADC count,
of +/-1 bit, you won't resolve any less than 4 degrees on average.
unless your pic power supply is providing a highly accurate and compliant 3.3v, your accuracy is also never going to make you happy either.
your problem is in circuit design, or lack of.
Direct reading an RTD, unless the temp range is extremely wide, is tough with only 10 to 12 bits of conversion,..l..
analog processing is the cheaper way to get better resolution, rather than using a lot more expensive bits of external ADC to achieve the same ends.
Jim90
RTD PT100
PostPosted: Mon Feb 17, 2014 12:44 pm     Reply with quote
You are right Mike Walne,
the values are :
for temperature : -10 c -->R=96.09 and with the use of the Vout equation V=0.031
for temperature: 110c --->V=0.046.
asmboy i don't want to use an external adc.
these values look like ok?
(to be honest i expect to receive something like 0.3 instead of 0.03 )
PostPosted: Mon Feb 17, 2014 1:39 pm     Reply with quote
you might google this phase and look at the images:
rtd schematic
with a 10bit adc - you are simply not going to resolve the temperature range you hope for, or with a noise level in the readings you get, to want to brag about it . at least not with the simple circuit you hope to use.
to work well with so few bits you need a constant current source for the RTD and analog gain. Its just math.........
over and out Very Happy Very Happy Very Happy
BTW: (1023) 120/1023 = 0,111.
actually there is general agreement on this forum anyway,
that 1024 is 10 bits worth not 12
i think 1024 is 12 bits only on ATMEL MCUS Laughing Laughing Laughing Laughing
Goto page 1, 2  Next
Page 1 of 2
