18F4520 PWM1CON ECCP dead band delay
sunay
PostPosted: Tue Oct 04, 2011 8:03 am     Reply with quote
I've tried to design a microcontroller based half-bridge Mosfet circuit. I 'm using PIC18F4520 that has ECCP module on CCP1. I managed to create PWM signal with this CCP1 module on P1A and out of phase on P1B. Now I just want to make a delay between these PWM signals. I read this site's topics which includes PWM1CON and dead band delay. I used the code as below.
void set_deadband(int8 deadband)
      #byte PWM1CON = 0x9B
      if(deadband > 127)
         deadband = 127;
         PWM1CON = deadband;
on its data sheet it says that DELAY=Tosc* PWM1CON
my Tosc =10^-7 and I want 1 us delay so 10^-6/10^-7=PWM1CON
PWM1CON=10 =0x0A
But when I look from the scope with X10 I coulnt catch the delay time :(
Why didnt I see the delay time ? do you have any idea?
with best regards,
sunay
PostPosted: Tue Oct 04, 2011 8:10 am     Reply with quote
PWM1CON, is _not_ at address 0x9B.
That looks like the address for a 16 chip, rather than a 18 chip.
Safest, use:
#byte PWM1CON=getenv("SFR:PWM1CON")
which will automatically put the right address in for you, to avoid this. PWM1CON on your chip is at 0xFB7.....
sunay
PostPosted: Tue Oct 04, 2011 10:15 am     Reply with quote
you are absolutely right. I already missed PWM1CON address...
your correction has solved my problem.
Thanks for your quick help.
with kind regards,
Sunay
haseeb younus
PostPosted: Mon Feb 10, 2014 1:30 pm     Reply with quote
Can you plz send me your code on my id harry.haseeb@gmail.com
