zombiePIC
PIC programmer, beginner problems, setting up clock etc.... |
Posted: Sat Feb 08, 2014 7:43 am |
Hi Guys
My set up as follows:
PIC16F87
IDE version 5.016
PCB version 5.016
PCM version 5.016
PCH version 5.016
ICD-U64
CCS LOAD V4.051
Windows 8.1 64 bit
My devboard
https://www.beta-estore.com/download/rk/RK-10121_103.pdf
I am new to pic programming, and i am having problems with rs232 communication which I believe it is down to the clock set up, which could be related to my devboard set up. can people have a look here and let me know of any faults
http://imgur.com/I5kKLdD
data sheet:
When using external clock set up at 20MHZ it get a value in the debugger at 19.88MHZ which can be seen through the debug window.
I am sending data from an arduino (its all i got) and the best baud rate i can achieve is 2400 and the data is still not correct . I would prefere 9600.
Anyway i tried switching over to internal clock at 8MHZ (using PIC wizard) and all i am getting 0.03MHZ, from debug window.
What am i doing wrong? Is it my custom cable that i am using for the ICD to the devboard... is it my devboard????
What do people use to devlope on PIC16f87
I know this might seem like a question that is asked quite often, but I have spent alot of time here (searching this forum) trying to figure it out with no success.
Thanks |
Joined: 01 Jul 2010 Posts: 9524 Location: Greensville,Ontario
Posted: Sat Feb 08, 2014 1:39 pm |
first question is ...
Do you have a MAX232 or equal between the PIC and PC?
I don't use the ICD-U64 so can't help you with the 'debugging' data. I use MPLAB and compiler in 'release' mode,burn the PIC, test in real world.
Using the internal 8MHz clock, you should get 9600 baud. Use the 'code' button and show us your code so we can see what you're doing.
hth
jay |
zombiePIC
Posted: Sat Feb 08, 2014 3:47 pm |
Thanks for the reply
Just to make myself clear i was hoping to send data from one PIC to multiple PICs wirelessly. From searching the forums it looks doable.
But anyway i am starting from scratch (no wireless) and i am running into problems setting up the clock.
All i have between pic and PC is the ICD-u64.
I followed this guide when connecting to my devboard
http://www.ccsinfo.com/faq.php?page=connect_icd
I don't have a MAX232.
To the best of my knowledge i would not require a MAX232 chip as the ICD allows data to be routed through pin B3 via the icd-u64 and then on to the PC which is connected via usb.
here is a sample of code that was taken from the pic wizard.
Code: | #include <16F87.h>
#use delay(internal=8MHz)
//TODO: User Code
I compile the code and press debug and this is what i get:
http://imgur.com/Cryne6n
notice the 0.03MHZ where i wan to run at 8mhz... |
Mike Walne
Posted: Sat Feb 08, 2014 4:45 pm |
Quote: | I don't have a MAX232.
To the best of my knowledge i would not require a MAX232 chip as the ICD allows data to be routed through pin B3 via the icd-u64 and then on to the PC which is connected via usb. |
Do a simple test with a voltmeter.
Most USB to RS232 devices I've met work on +/- 9V to 12V levels.
Check the TX from the PC and the TX from the ICD-U64.
You should then be able to work out whether you need a MAX232 or not.
Quote: | notice the 0.03MHZ where i wan to run at 8mhz... |
The 0.03MHz looks close to the 32kHz default internal oscillator setting.
I believe the Code: | #use delay(internal=8MHz) | should produce the correct frequency with recent compilers.
However you could try the setup_oscillator(xxx) option. See if that gets you nearer to where you want to be.
Mike
PS
Your 20MHz clock SHOULD be OK to 19,200 or even 38,400 baud.
The <1% error is not significant. |
Posted: Sat Feb 08, 2014 7:03 pm |
Hopefully someone who uses that ICD will reply as I have a HUGE problem trying to figure out HOW data on B3 gets routed to the ICD.
According to the schematic of your board (show 16F628) but 16F87/88 similar pinout, B3 goes to a header. The ICD gets connected only to the ICSP pins (same as PICkit3 that I use).
More 'troubles' as the UART uses pins RB5(tx) and RB2(rcv). So there is NO way I can see of getting 'serial' data from the PIC to the PC through the ICD unit.
I would add a 10pin header and cable to a MAX232 then to the PC.
hth
jay |
zombiePIC
Posted: Sun Feb 09, 2014 11:14 am |
I dont need to use a MAX232 chip as I am using the ICD-U64, explained in better detail here:
https://pic-c.com/forum/viewtopic.php?p=168382
Quote: | The difference between debug monitoring and plain monitoring is....
Debug
With CCS IDE and debug monitoring using #USE RS232(DEBUGGER) any printf is directed through the default pinB3 to the monitor screen in the CCS IDE when debug is selected. The choice of the monitor pin is selectable.
Run time
Now suppose you don't want to debug but would still like to monitor. Also suppose you are powering the target board via the ICDU64. Your printf can still be directed through PIN_B3. The small advantage is you don't need to add a max232 level shifter and since you originally wired your target for programming and debugging via the ICD- U64 there is no extra wiring. The ICD-U64 delivers the printf data through the usb cable to a PC program without needing the IDE and its debugger. This avoids the very small overhead the debugger would need. Again its a small advantage that is a bit more useful with small code space PIC's and can help in some rare situations
I tried to send data from arduino to PIC (will be moving on to PIC to PIC, when i get the PIC sorted out)
here is the arduino code:
Code: | /*
Uses a FOR loop for data and prints a number in various formats.
int x = 0; // variable
void setup() {
Serial.begin(9600); // open the serial port at 9600 bps:
void loop() {
// print labels
Serial.print("NO FORMAT"); // prints a label
Serial.print("\t"); // prints a tab
Serial.print("DEC");
Serial.print("\t");
Serial.print("HEX");
Serial.print("\t");
Serial.print("OCT");
Serial.print("\t");
Serial.print("BIN");
Serial.print("\t");
for(x=0; x< 64; x++){ // only part of the ASCII chart, change to suit
// print it out in many formats:
Serial.print(x); // print as an ASCII-encoded decimal - same as "DEC"
Serial.print(x, DEC); // print as an ASCII-encoded decimal
Serial.print(x, HEX); // print as an ASCII-encoded hexadecimal
Serial.print(x, OCT); // print as an ASCII-encoded octal
Serial.println(x, BIN); // print as an ASCII-encoded binary
// then adds the carriage return with "println"
delay(500); // delay 200 milliseconds
Serial.println(""); // prints another carriage return
Here is my PIC ccs c code
Code: | #include <16F87.H>
#device ICD=TRUE
#use delay (clock=20000000)
#fuses HS, NOWDT, NOPROTECT, BROWNOUT, PUT, NOLVP, NODEBUG
#use RS232(STREAM=Arduino,BAUD=9600, RCV=PIN_B2)
#use RS232(STREAM=debug,BAUD=9600, XMIT=PIN_B3,RCV=PIN_B3)
main(void)
char ch;
ch = getchar(Arduino);
fputc( ch, debug);
This is an image of my set up:
[IMG]http://i.imgur.com/9GyFdht.jpg?1[/IMG]
http://imgur.com/9GyFdht
This is what is being sent by the arduino:
Code: | O FORMAT DEC HEX OCT BIN 0 0 0 0 0
1 1 1 1 1
2 2 2 2 10
3 3 3 3 11
4 4 4 4 100
5 5 5 5 101
6 6 6 6 110
7 7 7 7 111
8 8 8 10 1000
9 9 9 11 1001
10 10 A 12 1010
11 11 B 13 1011
12 12 C 14 1100
13 13 D 15 1101
14 14 E 16 1110
15 15 F 17 1111
16 16 10 20 10000
17 17 11 21 10001
18 18 12 22 10010
19 19 13 23 10011
20 20 14 24 10100
21 21 15 25 10101
22 22 16 26 10110
23 23 17 27 10111
24 24 18 30 11000
25 25 19 31 11001
26 26 1A 32 11010
27 27 1B 33 11011
28 28 1C 34 11100
29 29 1D 35 11101
30 30 1E 36 11110
31 31 1F 37 11111
32 32 20 40 100000
33 33 21 41 100001
34 34 22 42 100010
35 35 23 43 100011
36 36 24 44 100100
37 37 25 45 100101
38 38 26 46 100110
39 39 27 47 100111
40 40 28 50 101000
41 41 29 51 101001
42 42 2A 52 101010
43 43 2B 53 101011
44 44 2C 54 101100
45 45 2D 55 101101
46 46 2E 56 101110
47 47 2F 57 101111
48 48 30 60 110000 |
This is what is recieved by the PIC....
Code: | ߌþƬkÆïÖ¬ïïÎßßîÆ¬kÆï߬ÿÞïÖ¬ÿïÎÏߌçÎÏßŒîÆ¬ÏïþÆ¬ÏÆïÖ¬ÿï߬ÿïÎÏߌïÎÏߌþƬÏýîÆ¬ÏçÎï߬ÿïÖ¬ÿçÎÏάÿŒþÖŒîÆ¬ÖŒþƬÏÿïß¬çÆŒß¬ÿçÎÏÖþÎÏßŒîÆ¬çÆÆ¬kÆïÖ¬ÆÞŒÖÿþÎÞÞîïïýïÆ¬ïcÖçÆ¬ŒïÆýïÆŒÿÿŒïþÆŒïþïçÎçÎîÖÏ߬ïþÖŒÏÿý¬cÖŒÿÏÆ¬ïþÖŒÏÆý¬ßÖŒÿÏÿïÏÏŒîÆ¬¬ÿïÏÎçÎßÖüîÆ¬¬ÆïÖߌïÎßÖÎþƬ¬ÿïÏßïçÎßߌþƬ¬ÆýïÖßïÎßîÎÆ¬¬ïíïÏÎŒïÎßÖìîÆ¬kÆï߬ïïÖ¬ÿçÎÏÖŒïÎÏÖŒîÆ¬ÖïþƬkçÞïÖ¬ïï߬ÿçÎÏߌçÎÏߌþÆ¬ßŒîÆ¬ÏÆïßÏïïÖ¬cïÎÏÜÿçÎÏßîά֌þÆ¬ÏÆÆ¬Ïÿï߬c÷ÎϬÿïÎÏÖŒþÆ¬ÖŒîÆ¬ÏÆÆ¬ÏÿïÖ¬ÿÿÏÖ¬ÿïÎÏߌïÎÏߌþƬîÎÆ¬ßÿïÎíçïŒßƌߌÿ¬ÆŒÖïïŒþÆŒïþŒcÆýŒÆÎÿïÿßïçÎÖŒÏïý¬ßÖŒÿ |
I am at a huge loss...... |
Mike Walne
Posted: Sun Feb 09, 2014 11:47 am |
1) How do you KNOW what characters the PIC receives?
2) Can you convert the characters to HEX then compare with the expected characters?
3) Did the setup_oscillator help with clocks?
4) Are you in effect using a software UART on chip with a built in hardware one?
5) I'd be probing signals with a 'scope and some very short loop tests.
Mike |
Posted: Sun Feb 09, 2014 12:38 pm |
I just did some experiments to determine the baud rate of the ICD
debugger monitor channel by comparing .LST files. It's actually 2400 baud.
(At least, for compiler vs. 5.016).
Change your #use rs232() line to this and see if it works better:
Code: | #use RS232(STREAM=DEBUGGER,BAUD=2400, XMIT=PIN_B3,RCV=PIN_B3) |
zombiePIC
Posted: Sun Feb 09, 2014 3:43 pm |
Hi thanks guys but i am still not 100%
I simplified my PIC and ARDUINO code
Quote: | I just did some experiments to determine the baud rate of the ICD
My PIC code is updated to include your comment..
#device ICD=TRUE
main(void)
char ch;
fputc( ch, DEBUGGER);
printf("\n\r");
Arduino code:
void setup() {
void loop() {
Serial.print("Hello"); // prints a Hello
delay(1000); // delay 1000 milliseconds
changing the Baud to 2400 improves things but all i am getting on the Debug monitor is
H
H
H
H
H
H
H
H
H
H
H
H
H
H
H
H
H
H
H
H
H
H
H
H
Looks like i can only display the first character "H" of "Hello".
Mike
5) I'd be probing signals with a 'scope and some very short loop tests. |
1. I am using Tera Term to monitor serial data sent from arduino to PIC
2. I will try...
3.I switched back to 20mhz...debugger says its at 19.88Mhz.... i should still be within the error?
4.I am recieving data on pin B2 which is hardware UART then the data is sent on through a software UART through Pin B3 a requirement by the icd-u64.
5. I've no scope at the moment but if I get my hands on I will loop "0x55" for sure. |
Mike Walne
Posted: Sun Feb 09, 2014 4:10 pm |
2. I will try...
1) OK. The data from the arduino is confirmed as good. What I meant was, how did you know what the garbage recieved by the PIC was?
2) Comparing the HEX (or binary) codes for the sent and received data may give a clue as to what's going wrong.
3) The setup_oscillator controls the clock frequency when using the internal RC clock. Have you tried it?
4) So you're stuck with that.
5) Good, at least you know which tests to try for starters.
Mike. |
zombiePIC
Posted: Mon Feb 10, 2014 2:54 pm |
Hi mike,
I am starting to make good progress.... thats with the external 20mhz
Quote: | 1) OK. The data from the arduino is confirmed as good. What I meant was, how did you know what the garbage received by the PIC was?
Mike. |
1.I can see all the garbage in the debug monitor window in the CCS C compiler window.
2. YES done that and it works
3.I got everything working on the external clock, gonna try internal next.
4.Yes stuck with that, but not an issue I think.
5.Pick the 0x55 from reading the forums.
So my simple code so far to get data from arduino to PIC. The most important parts that i would like to highlight are the println("") line in the arduino(sends CR) which is needed for the PIC. Also i would highlight the 2400 baud setting for the ICD debugger.
The code so far:
Arduino
Code: | void setup() {
void loop() {
Serial.print("Hello,world");// prints a Hello,world
Serial.println(""); prints CR
PIC16F87
#include <16F87.H>
#device ICD=TRUE
#use RS232(STREAM=DEBUGGER,BAUD=2400, XMIT=PIN_B3,RCV=PIN_B3)//2400 baud is the key for debugging
main(void)
char ch[20]; //More than enough room for all the characters
fgets(ch,Arduino);
fputs(ch,DEBUGGER);
Data received by PIC every 1 second....
Hello,world
Hello,world
Hello,world
Hello,world
Hello,world
...ect
The next step is to test the internal clock.....
Then I will try and figure out how to add a few serial interrupts/buffer incoming serial data... which I think the file EX_SISR.c will help.
Then hopefully a bit of manchester coding for wireless transmission....
I will have a million questions....
Thanks |
Posted: Mon Feb 10, 2014 3:35 pm |
Quote: | #use RS232(STREAM=Arduino,BAUD=9600, RCV=PIN_B2) |
This is a software UART. The hardware UART pins are B5 and B2.
When you only specify one of them in #use rs232(), the compiler will
make a software UART on that pin.
printf("\n\r");
That's the reason why you could only receive the letter 'H' with this loop.
The software UART waits for the character, gets it, and then you spend
a lot of time transmitting characters. By the time you're done doing that,
you have missed the "ello" part.
Quote: | while(1)
fgets(ch,Arduino);
fputs(ch,DEBUGGER);
This one above works much better because fgets waits to get the whole string.
The best way would be to use ex_sisr.c and modify it to work with streams
Code: | #use RS232(STREAM=Arduino, BAUD=9600, UART1, ERRORS) |
zombiePIC
Posted: Tue Feb 11, 2014 10:32 am |
Thanks PCM
This line of code works perfect....
I have modified the ex_sisr.c, only minimum changes were needed everything is working perfect.
I think the setting of 2400 baud for the ICD-u64 was where i got caught, and the hardware/software UART issue.
I am gonna see will things work off the internal clock now.
Thanks for all the help. |
