neochrome32
Solved: Speech 2 |
Posted: Thu Feb 06, 2014 8:48 pm |
this is meant to sing daisy daisy.
it doesn't sound QUITE right// the PWM appears to be correct. as the samples come out perfect.. but for some off reason...
it sounds lame
eg.
int8 a, b;
uint16_t c = a + (b*2)/a;
this seems to be screwing up..
CPU, PIC18F46k22, running 64Mhz
//# POLY SYNTH #//
uint16_t pitchPhase, form1Phase,form2Phase,form3Phase;
uint16_t pitchPhaseInc,form1PhaseInc,form2PhaseInc,form3PhaseInc;
uint8_t form1Amp,form2Amp,form3Amp;
uint8_t noiseMod=10;
int8_t noise;
int16_t phaseNoise = (int16)noise * (int16)noiseMod;
const int8_t sinCalc[256] = {
/* This table rolls a lot of functions together for speed.
Extracting phase and amplitude from the nybble packed form
Sine calculation
Exponential amplitude mapping
Scaling to appropriate range
ROUND(
FLOOR(a/16,1)
*SIN(
2
* PI()
* IF(
MOD(a,16),
EXP(0.18*MOD(a,16)),
0
) /16
)*127
,0)
0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
0,2,2,3,3,4,5,6,7,8,10,12,14,17,20,24,
0,4,4,5,6,7,9,11,13,15,18,22,26,31,37,45,
0,5,6,7,8,10,12,14,17,20,24,28,34,41,49,58,
0,5,6,7,9,10,12,15,18,21,26,31,37,44,53,63,
0,-2,-2,-3,-3,-4,-5,-6,-7,-8,-10,-12,-14,-17,-20,-24,
0,-4,-4,-5,-6,-7,-9,-11,-13,-15,-18,-22,-26,-31,-37,-45,
0,-5,-6,-7,-8,-10,-12,-14,-17,-20,-24,-28,-34,-41,-49,-58,
0,-5,-6,-7,-9,-10,-12,-15,-18,-21,-26,-31,-37,-44,-53,-63,
const int8_t sqrCalc[256] ={
0,1,2,2,2,3,3,4,5,5,6,8,9,11,13,16,
0,-1,-2,-2,-2,-3,-3,-4,-5,-5,-6,-8,-9,-11,-13,-16,
void audioOn() {
#if defined(__AVR_ATmega8__)
// ATmega8 has different registers
TCCR2 = _BV(WGM20) | _BV(COM21) | _BV(CS20);
TIMSK = _BV(TOIE2);
#elif defined(__AVR_ATmega1280__)
TCCR3A = _BV(COM3C1) | _BV(WGM30);
TCCR3B = _BV(CS30);
TIMSK3 = _BV(TOIE3);
#else
// Set up PWM to 31.25kHz, phase accurate
TCCR2A = _BV(COM2B1) | _BV(WGM20);
TCCR2B = _BV(CS20);
TIMSK2 = _BV(TOIE2);
setup_timer_2(T2_DIV_BY_1,0xff,1); //22.8 us overflow, 22.8 us interrupt
//setup_timer_2(T2_DIV_BY_1,90,1); //256 us overflow, 256 us interrupt
setup_timer_3(T3_DISABLED | T3_DIV_BY_1);
setup_timer_4(T4_DISABLED,0,1);
setup_timer_5(T5_DISABLED | T5_DIV_BY_1);
//setup_timer_6(T6_DIV_BY_4,126,1);
//setup_timer_6(T6_DIV_BY_4,200,1);
setup_timer_6(T6_DIV_BY_4,146,1);
setup_ccp1(CCP_PWM|CCP_SHUTDOWN_AC_L|CCP_SHUTDOWN_BD_L);
void setup() {
audioOn();
//setup_ccp1(CCP_OFF);
enable_interrupts(INT_TIMER6);
#define FORMANT_SZ 7
enum {
_SP,_DOT,_QM,_COM,_HYP,_IY,_IH,_EH,_AE,_AA,
_AH,_AO,_UH,_AX,_IX,_ER,_UX,_OH,_RX,_LX,
_WX,_YX,_WH,_R,_L,_W,_Y,_M,_N,_NX,
_DX,_Q,_S,_SH,_F,_TH,__H,__X,_Z,_ZH,
_V,_DH,_CHa,_CHb,_Ja,_Jb,_Jc,_Jd,_EY,_AY,
_OY,_AW,_OW,_UW,_Ba,_Bb,_Bc,_Da,_Db,_Dc,
_Ga,_Gb,_Gc,_GXa,_GXb,_GXc,_Pa,_Pb,_Pc,_Ta,
_Tb,_Tc,_Ka,_Kb,_Kc,_KXa,_KXb,_KXc
const uint8_t formantTable[] = {
0x0, 0x0, 0x0,0x0,0x0,0x0,0x0,/*00 space*/ 0x13,0x43,0x5b,0x0,0x0,0x0,0x0,/*01 .*/
0x13,0x43,0x5b,0x0,0x0,0x0,0x0,/*02 ?*/ 0x13,0x43,0x5b,0x0,0x0,0x0,0x0,/*03 ,*/
0x13,0x43,0x5b,0x0,0x0,0x0,0x0,/*04 -*/ 0xa,0x54,0x6e,0xd,0xa,0x8,0x0,/*05 IY*/
0xe,0x49,0x5d,0xd,0x8,0x7,0x0,/*06 IH*/ 0x13,0x43,0x5b,0xe,0xd,0x8,0x0,/*07 EH*/
0x18,0x3f,0x58,0xf,0xe,0x8,0x0,/*08 AE*/ 0x1b,0x28,0x59,0xf,0xd,0x1,0x0,/*09 AA*/
0x17,0x2c,0x57,0xf,0xc,0x1,0x0,/*10 AH*/ 0x15,0x1f,0x58,0xf,0xc,0x0,0x0,/*11 AO*/
0x10,0x25,0x52,0xf,0xb,0x1,0x0,/*12 UH*/ 0x14,0x2c,0x57,0xe,0xb,0x0,0x0,/*13 AX*/
0xe,0x49,0x5d,0xd,0xb,0x7,0x0,/*14 IX*/ 0x12,0x31,0x3e,0xc,0xb,0x5,0x0,/*15 ER*/
0xe,0x24,0x52,0xf,0xc,0x1,0x0,/*16 UX*/ 0x12,0x1e,0x58,0xf,0xc,0x0,0x0,/*17 OH*/
0x12,0x33,0x3e,0xd,0xc,0x6,0x0,/*18 RX*/ 0x10,0x25,0x6e,0xd,0x8,0x1,0x0,/*19 LX*/
0xd,0x1d,0x50,0xd,0x8,0x0,0x0,/*20 WX*/ 0xf,0x45,0x5d,0xe,0xc,0x7,0x0,/*21 YX*/
0xb,0x18,0x5a,0xd,0x8,0x0,0x0,/*22 WH*/ 0x12,0x32,0x3c,0xc,0xa,0x5,0x0,/*23 R*/
0xe,0x1e,0x6e,0xd,0x8,0x1,0x0,/*24 L*/ 0xb,0x18,0x5a,0xd,0x8,0x0,0x0,/*25 W*/
0x9,0x53,0x6e,0xd,0xa,0x8,0x0,/*26 Y*/ 0x6,0x2e,0x51,0xc,0x3,0x0,0x0,/*27 M*/
0x6,0x36,0x79,0x9,0x9,0x0,0x0,/*28 N*/ 0x6,0x56,0x65,0x9,0x6,0x3,0x0,/*29 NX*/
0x6,0x36,0x79,0x0,0x0,0x0,0x0,/*30 DX*/ 0x11,0x43,0x5b,0x0,0x0,0x0,0x0,/*31 Q*/
0x6,0x49,0x63,0x7,0xa,0xd,0xf,/*32 S*/ 0x6,0x4f,0x6a,0x0,0x0,0x0,0x0,/*33 SH*/
0x6,0x1a,0x51,0x3,0x3,0x3,0xf,/*34 F*/ 0x6,0x42,0x79,0x0,0x0,0x0,0x0,/*35 TH*/
0xe,0x49,0x5d,0x0,0x0,0x0,0x0,/*36 /H*/ 0x10,0x25,0x52,0x0,0x0,0x0,0x0,/*37 /X*/
0x9,0x33,0x5d,0xf,0x3,0x0,0x3,/*38 Z*/ 0xa,0x42,0x67,0xb,0x5,0x1,0x0,/*39 ZH*/
0x8,0x28,0x4c,0xb,0x3,0x0,0x0,/*40 V*/ 0xa,0x2f,0x5d,0xb,0x4,0x0,0x0,/*41 DH*/
0x6,0x4f,0x65,0x0,0x0,0x0,0x0,/*42 CHa*/ 0x6,0x4f,0x65,0x0,0x0,0x0,0x0,/*43 CHb*/
0x6,0x42,0x79,0x1,0x0,0x0,0x0,/*44 Ja*/ 0x5,0x42,0x79,0x1,0x0,0x0,0x0,/*45 Jb*/
0x6,0x6e,0x79,0x0,0xa,0xe,0x0,/*46 Jc*/ 0x0, 0x0, 0x0,0x2,0x2,0x1,0x0,/*47 Jd*/
0x13,0x48,0x5a,0xe,0xe,0x9,0x0,/*48 EY*/ 0x1b,0x27,0x58,0xf,0xd,0x1,0x0,/*49 AY*/
0x15,0x1f,0x58,0xf,0xc,0x0,0x0,/*50 OY*/ 0x1b,0x2b,0x58,0xf,0xd,0x1,0x0,/*51 AW*/
0x12,0x1e,0x58,0xf,0xc,0x0,0x0,/*52 OW*/ 0xd,0x22,0x52,0xd,0x8,0x0,0x0,/*53 UW*/
0x6,0x1a,0x51,0x2,0x0,0x0,0x0,/*54 Ba*/ 0x6,0x1a,0x51,0x4,0x1,0x0,0xf,/*55 Bb*/
0x6,0x1a,0x51,0x0,0x0,0x0,0x0,/*56 Bc*/ 0x6,0x42,0x79,0x2,0x0,0x0,0x0,/*57 Da*/
0x6,0x42,0x79,0x4,0x1,0x0,0xf,/*58 Db*/ 0x6,0x42,0x79,0x0,0x0,0x0,0x0,/*59 Dc*/
0x6,0x6e,0x70,0x1,0x0,0x0,0x0,/*60 Ga*/ 0x6,0x6e,0x6e,0x4,0x1,0x0,0xf,/*61 Gb*/
0x6,0x6e,0x6e,0x0,0x0,0x0,0x0,/*62 Gc*/ 0x6,0x54,0x5e,0x1,0x0,0x0,0x0,/*63 GXa*/
0x6,0x54,0x5e,0x4,0x1,0x0,0xf,/*64 GXb*/ 0x6,0x54,0x5e,0x0,0x0,0x0,0x0,/*65 GXc*/
0x6,0x1a,0x51,0x0,0x0,0x0,0x0,/*66 Pa*/ 0x6,0x1a,0x51,0x0,0x0,0x0,0x0,/*67 Pb*/
0x6,0x1a,0x51,0x0,0x0,0x0,0x0,/*68 Pc*/ 0x6,0x42,0x79,0x0,0x0,0x0,0x0,/*69 Ta*/
0x6,0x42,0x79,0x0,0x0,0x0,0x0,/*70 Tb*/ 0x6,0x42,0x79,0x0,0x0,0x0,0x0,/*71 Tc*/
0x6,0x6d,0x65,0x0,0x0,0x0,0x0,/*72 Ka*/ 0xa,0x56,0x65,0xc,0xa,0x7,0x0,/*73 Kb*/
0xa,0x6d,0x70,0x0,0x0,0x0,0x0,/*74 Kc*/ 0x6,0x54,0x5e,0x0,0x0,0x0,0x0,/*75 KXa*/
0x6,0x54,0x5e,0x0,0xa,0x5,0x0,/*76 KXb*/ 0x6,0x54,0x5e,0x0,0x0,0x0,0x0 /*77 KXc*/
uint16_t pitchTable[64] = {
// Covers A1 to C7
58,61,65,69,73,77,82,86,92,97,
103,109,115,122,129,137,145,154,163,173,
183,194,206,218,231,244,259,274,291,308,
326,346,366,388,411,435,461,489,518,549,
581,616,652,691,732,776,822,871,923,978,
1036,1097,1163,1232,1305,1383,1465,1552,1644,1742,
1845,1955,2071,2195
const uint8_t frameList[] = {
#if 1
_Da,3,0,39,_Db,1,0,39,_Dc,1,3,39,_EY,8,6,39,_YX,20,3,39, // Dai..
_Z,10,0,36,_IY,35,3,36, // ..sy
_Da,3,0,32,_Db,1,0,32,_Dc,1,3,32,_EY,8,6,32,_YX,20,3,32, // Dai..
_Z,10,0,27,_IY,35,3,27, // ..sy
_Ga,2,0,29,_Gb,2,0,29,_Gc,2,0,29,_IH,10,3,29,_V,5,0,29, // Give
_M,2,0,31,_IY,10,3,31, // me
_YX,5,0,32,_AO,10,0,32,_RX,5,0,32, // your
_AH,25,0,29,_NX,5,0,29, // an..
_S,2,0,32,_ER,10,0,32,_RX,3,0,32, // ..swer
_Da,3,0,27,_Db,1,0,27,_Dc,1,3,27,_UX,80,3,27,_WX,5,0,27, // do
_AY,5,20,34,_YX,10,0,34,_M,8,0,34, // I'm
__H,5,0,39,_AX,30,0,39,_F,10,0,39, // half
_Ka,3,0,36,_Kb,3,0,36,_Kc,4,0,36,_R,5,0,36,_EY,30,0,36, // cra..
_Z,5,0,32,_IY,40,0,32, // ..zy
_AO,10,0,29,_LX,5,0,29, // all
_F,5,0,31,_AO,10,0,31, // for
_DH,5,0,32,_AH,10,0,32, // the
_L,5,0,34,_AH,20,0,34,_V,5,0,34,// love
_AA,10,0,36,_V,5,0,36,// of
_Y,10,0,34,_UX,80,0,34, // you
_IH,10,0,36,_Ta,2,0,36,_Tb,1,0,36,_Tc,2,0,36,// It
_W,2,0,37,_OH,10,0,37,_N,1,0,37,_Ta,1,0,37,_Tb,1,0,37,_Tc,1,0,37,// won't
_Ba,2,0,36,_Bb,1,0,36,_Bc,2,0,36,_IY,10,0,36,// be
_AH,15,0,34,// a
_S,2,0,39,_Ta,2,0,39,_Tb,2,0,39,_Tc,2,0,39,_AY,1,10,39,_YX,10,0,39,// sty..
_L,3,0,36,_IH,10,0,36,_SH,2,0,36,// ..lish
_M,5,0,34,_AE,10,0,34,// ma..
_R,5,0,32,_IH,60,0,32,_Ja,2,0,32,_Jb,2,0,32,_Jc,2,0,32,// ..rriage
_AY,5,10,34,_YX,5,0,34,// I
_Ka,2,0,36,_Kb,2,0,36,_Kc,2,0,36,_AH,20,0,36,_N,2,0,36,_Ta,2,0,36,_Tb,2,0,26,_Tc,2,0,36,// can't
_AX,15,0,32,// a..
_F,5,0,29,_AO,20,0,29,_R,2,0,29,_Da,1,0,29,_Db,1,0,29,_Dc,1,0,29,// ..fford
_AX,15,0,32,// a
_Ka,1,0,29,_Kb,1,0,29,_Kc,1,0,29,_AE,12,0,29,// ca..
_R,5,0,27,_IH,45,0,27,_Ja,2,0,27,_Jb,2,0,27,_Jc,2,0,27,// ..rriage
_Ba,1,0,27,_Bb,1,0,27,_Bc,1,0,27,_AH,10,0,27,_Ta,1,0,27,_Tb,1,0,27,_Tc,1,0,27,// but
_Y,5,0,32,_UH,10,10,32,_L,5,0,32,// you'll
_L,3,0,36,_UH,10,0,36,_Ka,1,0,36,_Kb,1,0,36,_Kc,1,0,36,// look
_S,2,0,34,_W,2,0,34,_IY,20,0,34,_Ta,2,0,34,_Tb,2,0,34,_Tc,2,0,34,// sweet
_AX,15,0,27,// a..
_Ka,2,0,32,_Kb,2,0,32,_Kc,2,0,32,_R,2,0,32,_AA,20,0,32,_S,5,0,32,// ..cross
_DH,5,0,36,_AH,10,0,36,// the
_S,2,0,34,_IY,10,0,34,_Ta,2,0,34,_Tb,2,0,34,_Tc,2,0,34,// seat
_AE,15,0,37,// a
_Ba,2,0,39,_Bb,2,0,39,_Bc,2,0,39,_AY,5,5,39,_YX,5,0,39,// bi..
_S,5,0,36,_IH,10,0,36,// ..cy..
_Ka,2,0,32,_Kb,2,0,32,_Kc,2,0,32,_L,9,0,32,// ..cle
_M,2,0,34,_EY,5,10,34,_YX,10,0,34,_Da,2,0,34,_Db,2,0,34,_Dc,2,0,34,// made
_F,5,0,27,_OY,1,5,27,_RX,5,0,27,// for
_Ta,2,0,32,_Tb,2,0,32,_Tc,2,0,32,_UX,50,0,32,// two
_Ta,0,0,61
int16 frameTime = 15; // ms
uint16_t basePitch;
int16 formantScale;
#define pgm_read_byte(x) (unsigned int8)read_program_eeprom(x)
#define delay(x) delay_ms(x/4)
void loop() {
formantScale = 54;//random(20,80);//54;
uint8_t *framePos = &frameList;
//uint8_t n;
uint8_t startFormant,staticFrames,tweenFrames;
int16_t startPitch,nextPitch;
uint8_t nextFormant;
int16_t startForm1PhaseInc,startForm2PhaseInc,startForm3PhaseInc;
uint8_t startForm1Amp,startForm2Amp,startForm3Amp;
uint8_t startMod;
uint8_t *formantPos;
//uint8_t* formantPos;
int16_t deltaForm1PhaseInc,deltaForm2PhaseInc,deltaForm3PhaseInc;
int8_t deltaForm1Amp,deltaForm2Amp,deltaForm3Amp;
int8_t deltaMod;
uint8_t nextMod;
int16_t deltaPitch;
while(1) {
// Read next framelist item
startFormant = pgm_read_byte(framePos++);
staticFrames = pgm_read_byte(framePos++);
if (!staticFrames) break; // End of phrase
tweenFrames = pgm_read_byte(framePos++);
startPitch = pitchTable[pgm_read_byte(framePos++)];
nextFormant = pgm_read_byte(framePos);
nextPitch = pitchTable[pgm_read_byte(framePos+3)];
pitchPhaseInc = startPitch;
formantPos = &formantTable + (startFormant * FORMANT_SZ);
form1PhaseInc = startForm1PhaseInc = pgm_read_byte(formantPos++)*formantScale;
form2PhaseInc = startForm2PhaseInc = pgm_read_byte(formantPos++)*formantScale;
form3PhaseInc = startForm3PhaseInc = pgm_read_byte(formantPos++)*formantScale;
form1Amp = startForm1Amp = pgm_read_byte(formantPos++);
form2Amp = startForm2Amp = pgm_read_byte(formantPos++);
form3Amp = startForm3Amp = pgm_read_byte(formantPos++);
noiseMod = startMod = pgm_read_byte(formantPos++);
for (;staticFrames--;) delay(frameTime);
if (tweenFrames) {
tweenFrames--;
formantPos = &formantTable + (nextFormant * FORMANT_SZ);
deltaForm1PhaseInc = pgm_read_byte(formantPos++)*formantScale - startForm1PhaseInc;
deltaForm2PhaseInc = pgm_read_byte(formantPos++)*formantScale - startForm2PhaseInc;
deltaForm3PhaseInc = pgm_read_byte(formantPos++)*formantScale - startForm3PhaseInc;
deltaForm1Amp = pgm_read_byte(formantPos++) - startForm1Amp;
deltaForm2Amp = pgm_read_byte(formantPos++) - startForm2Amp;
deltaForm3Amp = pgm_read_byte(formantPos++) - startForm3Amp;
deltaMod = pgm_read_byte(formantPos++) - startMod;
deltaPitch = nextPitch - startPitch;
deltaMod = nextMod - startMod;
for (int16_t i=1; i<=tweenFrames; i++) {
form1PhaseInc = startForm1PhaseInc + (i*deltaForm1PhaseInc)/tweenFrames;
form2PhaseInc = startForm2PhaseInc + (i*deltaForm2PhaseInc)/tweenFrames;
form3PhaseInc = startForm3PhaseInc + (i*deltaForm3PhaseInc)/tweenFrames;
form1Amp = startForm1Amp + (i*deltaForm1Amp)/tweenFrames;
form2Amp = startForm2Amp + (i*deltaForm2Amp)/tweenFrames;
form3Amp = startForm3Amp + (i*deltaForm3Amp)/tweenFrames;
pitchPhaseInc = startPitch + (i*deltaPitch)/tweenFrames;
noiseMod = startMod + (i*deltaMod)/tweenFrames;
delay(frameTime);
delay(300);
//#int_timer2
int8_t value;
#int_timer6
Void SounderNow(){
int8_t noise;
int16_t phaseNoise = noise * noiseMod;
noise += noise<<2; noise++; // noise' = 5*noise+1
form1Phase += form1PhaseInc;
value = pgm_read_byte(sinCalc+(((form1Phase>>8) & 0xf0) | form1Amp));
form2Phase += form2PhaseInc;
value += pgm_read_byte(sinCalc+(((form2Phase>>8) & 0xf0) | form2Amp));
form3Phase += form3PhaseInc;
value += pgm_read_byte(sqrCalc+(((form3Phase>>8) & 0xf0) | form3Amp));
value = (value * (0xff^(pitchPhase>>8)))>>8;
pitchPhase += pitchPhaseInc;
if ((pitchPhase+phaseNoise) < pitchPhaseInc) {
form1Phase = 0;
form2Phase = 0;
form3Phase = 0;
set_pwm1_duty(127 + value);
Posted: Fri Feb 07, 2014 2:08 am |
Don't set variables, except to things that are constant, in the declaration line.
For example:
int8_t noise;
At the point where you declare 'phaseNoise', 'noise', contains an undefined value. So PhaseNoise will also end up with an undefined value.
If you read K&R (the C reference - they were the people who wrote it...), you have (slightly trimmed to shorten):
"A variable may be initialised in it's declaration. If the name is followed by an equals sign, and an expression, the expression serves as an initialiser"
Then followed by:
"The initialisation is done once only, conceptually before the program starts executing, and the initialiser must be a constant expression."
There is more concerning automatic variables (these are ones declared inside a function), but the ones shown here are not automatic....
Generally it is better also to avoid doing maths inside the initialisation, since the rules then are the rules of the compiler parser, not the C itself. Results may therefore differ from what is expected.
In the section in 'sounderNow', you are dealing with automatic variables, but again 'noise' is undefined at the point where you use it....
Explicitly initialise _all_ variables before you use them. |
neochrome32
Posted: Fri Feb 07, 2014 10:02 am |
TTelmah,
Thank you again!
code update;
im still not quite clear on the "Shortened" part tho?
i deftyped all to signed, and specified uint16_t
with things
the bit that worries me is the initialiser
a = b = c;
sounds like i have to
a = b = 5; // forexample
if thats the case.. it seems to work on SOME parts and not others
the NOISE part still doesnt get heard, and the T sounds dont work still...
i found "ROM" and CONST pretty much do the same, for speed interest i am using const, but will change to ROM later (Speed meaning, upload time) lol
it sounds much clearer tho...
i'll upload a mp3
http://www.electronscape.co.uk/daisy_2.mp3
//# POLY SYNTH #//
uint16_t noiseMod;
int16_t noise;
int16_t phaseNoise;
Sine calculation
ROUND(
FLOOR(a/16,1)
*SIN(
2
* PI()
* IF(
MOD(a,16),
0
) /16
)*127
,0)
void audioOn() {
TIMSK = _BV(TOIE2);
TCCR3B = _BV(CS30);
#else
TCCR2B = _BV(CS20);
setup_timer_2(T2_DIV_BY_1,255,1); //45.5 us overflow, 45.5 us interrupt
//set_pwm1_duty((int16)362);
//setup_timer_2(T2_DIV_BY_1,70,1); //22.8 us overflow, 22.8 us interrupt
setup_timer_6(T6_DIV_BY_4,150,1);
void setup() {
audioOn();
delay_us(10);
enum {
_SP, _DOT, _QM, _COM, _HYP, _IY, _IH, _EH, _AE, _AA,
_AH, _AO, _UH, _AX, _IX, _ER, _UX, _OH, _RX, _LX,
_WX, _YX, _WH, _R, _L, _W, _Y, _M, _N, _NX,
_DX, _Q, _S, _SH, _F, _TH, __H, __X, _Z, _ZH,
_V, _DH, _CHa, _CHb, _Ja, _Jb, _Jc, _Jd, _EY, _AY,
_OY, _AW, _OW, _UW, _Ba, _Bb, _Bc, _Da, _Db, _Dc,
_Ga, _Gb, _Gc, _GXa, _GXb, _GXc, _Pa, _Pb, _Pc, _Ta,
_Tb, _Tc, _Ka, _Kb, _Kc, _KXa, _KXb, _KXc
0x6,0x54,0x5e,0x0,0xa,0x5,0x0,/*76 KXb*/ 0x6,0x54,0x5e,0x0,0x0,0x0,0x00/*77 KXc*/
// Covers A1 to C7
1845,1955,2071,2195
#define frameList frameList2
const int8_t frameList1[] ={
_S,2,0,34, _W,2,0,34, _IY,20,0,34, _Ta,2,0,34, _Tb,2,0,34, _Tc,2,0,34,// sweet
_S,2,0,34, _EH,21,1,34, _Ka,3,0,36,_Kc,4,0,34, _S,2,0,34,// [spam]
_S,0,0,0
const int8_t frameList2[] = {
#if 1
_AH,15,0,34,// a
_AX,15,0,32,// a..
_AX,15,0,32,// a
_AX,15,0,27,// a..
_AE,15,0,37,// a
_Ta,0,0,61
startFormant = pgm_read_byte(framePos++); // phonetic (waveform)
staticFrames = pgm_read_byte(framePos++); // static, is space?
tweenFrames = pgm_read_byte(framePos++); // frame treen?
startPitch = pitchTable[pgm_read_byte(framePos++)]; // pitch
// PHONETIC, Pause, tween, pitch
const uint8_t frameL0ist[] = {
_AY,5,10,36,_YX,10,0,29, // I
_AH,10,0,29,_m,10,0,29, // am..
_N,5,0,29,_aa,10,0,29,_Ta,8,3,37, // not
_ga,10,0,24,_ey,12,6,34, _yx,10,8,26,
_Ta,0,0,61
int16 basePitch;
int16 formantScale;
#define pgm_read_byte(x) (int8_t)read_program_eeprom(x)
#define pgm_read_bytel(x) (uint16_t)read_program_eeprom(x)
void loop() {
formantScale = 64;//random(20,80);//54;
//uint8_t n;
uint16_t staticFrames;
int16_t startFormant,tweenFrames;
int16_t nextFormant;
uint16_t startForm1Amp,startForm2Amp,startForm3Amp;
uint16_t startMod;
int16_t deltaForm1Amp,deltaForm2Amp,deltaForm3Amp;
int16_t deltaMod;
uint16_t nextMod;
int16_t deltaPitch;
while(1) {
if (tweenFrames) {
tweenFrames--;
for (uint16_t i=1; i<=tweenFrames; i++) {
form1PhaseInc = startForm1PhaseInc + (i*(int16)deltaForm1PhaseInc)/tweenFrames;
form2PhaseInc = startForm2PhaseInc + (i*(int16)deltaForm2PhaseInc)/tweenFrames;
form3PhaseInc = startForm3PhaseInc + (i*(int16)deltaForm3PhaseInc)/tweenFrames;
form1Amp = startForm1Amp + (i*(int16)deltaForm1Amp)/tweenFrames;
form2Amp = startForm2Amp + (i*(int16)deltaForm2Amp)/tweenFrames;
form3Amp = startForm3Amp + (i*(int16)deltaForm3Amp)/tweenFrames;
delay(frameTime);
//set_timer6(0);
//clear_interrupt(int_timer6);
delay(200);
//#int_timer2
int8_t value;
#int_timer6
Void SounderNow(){
//int16_t
//value = value + (phaseNoise>>6);
value = (value * (0xFF^(pitchPhase>>8)))>>8;
form1Phase = 0;
form2Phase = 0;
form3Phase = 0;
//set_pwm1_duty(1024 + (value+(phaseNoise>>8)));
set_pwm1_duty(128+value);
Posted: Fri Feb 07, 2014 10:54 am |
You are still ignoring what I'm saying. First still using & where you shouldn't - look at the original code.
Then still using the read byte functions. These are not needed if you use rom. The avr, like the PIC needs different code to access things in the program memory, but CCS can do this for you. Look at the example I posted.
a=b=c; is perfectly legitimate C, and works fine in CCS.
Where there are problems, is the assumption that variables will contain something when they are declared. On things like the PC, RAM is zeroed at boot. You have variables being set to variables that are not initialised. If you are going to do this (bad practice anyway...), then add #zero_ram to the code so the values will be zeroed.
Then the other killer is the interrupt frequency. Every 256 instructions. It takes over 60 instructions on the PIC just to get into and out of an interrupt. Each program memory read takes a dozen instructions. Add the other stuff being done in the interrupt, and it is doubtful that it can be done in time. |
neochrome32
Posted: Fri Feb 07, 2014 3:57 pm |
Ttehmah thanks again..
i thought read everything didn't think i was ignoring anything! ok im gonna go through your example (i've noticed you turned the noiseMod back to an uint8...
#zero_ram is in my main.h, will this protocol happen on any NEW variable declared AFTER this?
uint8 test1;
#zero_ram
uint8 test2;
would this clear BOTH variables?
im really sorry i thought i had a grasp of this... stupid thing is, i can make an OS, radio interface, 3D stuff on it, but only because im starting from scratch..
i HAD noticed the rom and const appeared to do something different.
as im doing im converting probably TOO literal!
Will keep you posted..
again THANK YOU so much! |
neochrome32
Posted: Fri Feb 07, 2014 5:31 pm |
WHAT THE
am i missing something else???
const int8 frame[255]={
<randomdata>
int8 *p
int8 p = &frame;
int16 i;
t = frame[i++];
is slower than t = read_program_eeprom(p++)
looks like i have a lot more work :( |
neochrome32
Posted: Sat Feb 08, 2014 11:38 am |
seems that i got it working, but again its not a great sounding system... im gonna have a crack at making my own speech engine instead... converting code appears to have taken more time than it would have if i made one from scratch....
ALSO the speech chip 1: has some interesting ways to do things so im gonna use that phoneme system.
Wish me luck, when done i'll be posting the code here for everyone to either improve or just have :D |
neochrome32
