PIC 18F4550 RC4 RC5 Digital input Problem
Alzmeier
PostPosted: Thu Feb 06, 2014 8:35 am     Reply with quote
Hello all,
I want to use the RC4 and RC5 Ports as digital inputs.
So I added:
// disable USB module
#byte UCON = 0xF6D
#bit USBEN = UCON.3
// disable on-chip USB transceiver
#byte UCFG = 0xF6F
#bit USBTRANS = UCFG.3
USBEN = 0;
USBTRANS = 1;
do
They are working, but sometimes without a external Signal Voltage they turn to 1. I use 10kohm external Resistence for pull down and 100 ohms in the signal Line.
To check them I use
 RC5=input_state(PIN_C5);
If somebody has an idea, would be great, because I´m getting mad.
PostPosted: Thu Feb 06, 2014 8:42 am     Reply with quote
is there any issue with using input_state() for the pins in question??
or does that fail for you too??
what drives the pins externally?
perhaps your "disable" strategy is not working as you believe??
what compiler version??
Alzmeier
PostPosted: Thu Feb 06, 2014 8:54 am     Reply with quote
externally it is a signal 5V, 100Ohm in Serial, 10kOhm for pull down, the 5V are connected when a Relay is closed,
I use input_state, because at all my other inputs it is working fine
Alzmeier
PostPosted: Thu Feb 06, 2014 9:08 am     Reply with quote
Sorry,
compiler version PCWH 3.245
the problem is that they work, I connect 5V, I get a 1, I disconnect 5V, I get a 0. But some times they get to 1 without an external 5V
PostPosted: Thu Feb 06, 2014 9:10 am     Reply with quote
Jast had a look at the datasheet, page 119,chapter 10.3. There's an entire PAGE on how complicated the 'setup' is for those 2 pins!
Yeesh...My guess is your code edits the tris registers which can be a big problem. You might have to use fast_io() and manually configure the ports.
hth
jay
