10 bit ADC basics
rovtech
10 bit ADC basics
PostPosted: Thu Jan 30, 2014 3:53 pm     Reply with quote
Question 1.
Is the default actually 8 bit?
I am using a PIC16F1509 and my program works reading the ADC into an 8 bit variable.
Question 2.
Should I be using #device ADC=8 or is using the default OK (if there is one)?
Question 3.
After searching for answers I notice #device *=16 ADC=10 being used. What exactly is *=16 ? The CCS manual suggests it sets the pointer size. What pointer and why?
Question 4.
What is the default justification for 10 bits returned in a 16 bit variable?
Question 5.
How would I change a 16 bit value into an 8 bit variable?
Thanks in advance.
PostPosted: Thu Jan 30, 2014 4:11 pm     Reply with quote
ADC=8, is the default, but it is always safer to specify it yourself.
ADC=10, or ADC=16, take longer to read, larger code, and slower. If you only want an 8bit value, stick with ADC=8.
ADC=10 returns the value right justified (low ten bits). ADC=16 returns the value left justified (to the top of the 16bit result). 10bit value to 8bits, you'd have to divide by 4. To just read the top byte or low byte of a value look at the 'make8' instruction.
*=16, is not connected with the ADC, and can even be on another line. When you 'address' values in RAM, the address is called a 'pointer' (this is the C name for the address). The RAM memory in the PIC16 is 'paged'. So to talk to things bigger than one 'page' in RAM, a multi byte address is needed, and code has to be added to automatically select this. The default is to only handle the RAM in the bottom page of memory (quick). *=16, tells the compiler to generate code to address the whole of the RAM, allowing a maximum of 64KB of RAM to be addressed (doesn't do anything on larger chips without the RAM paging PIC18/24 etc. - often misused on these)
rovtech
PostPosted: Thu Jan 30, 2014 7:54 pm     Reply with quote
That was fast and informative, Thanks.
rovtech
PostPosted: Fri Jan 31, 2014 2:07 pm     Reply with quote
Here are two examples and some more questions. Only relevant code is shown.
// Example using an 8 bit variable and reading a 10 bit ADC as 8 bit
#include <16F1509.H>
#device ADC = 8                       // optional but better to use
   setup_oscillator(OSC_8MHZ);   // Set PIC to int osc
   int volts8;                               // voltage on pot, 8 bit
// setup ADC here including 10 us delay
   volts8 = read_adc();               // reads ADC, stores in volts8
   delay_ms(10);                        // wait 10 ms
// Example using a 10 bit ADC but converting to an 8 bit variable
#device ADC = 10
   long pot_val;                           // voltage on pot, 16 bit
   int volts8;                               // 8 bit value of voltage
   pot_val = read_adc();             // reads ADC, stores in pot_val
// Adjust 10 bit to 8 bit
   pot_val = pot_val >>2;           // multiply by 4
   volts8 = make8 (pot_val, 0);   // no byte offset
They both work but it is interesting to note that if I use #device ADC=16 in the first example it does not generate a compile error or warning, but the value in volts8 is garbage.
Question:
I can't remember why I use the 10 ms delay after reading the ADC, it is something I used to do several years ago. Is any delay here necessary. I know I need a delay after setting the ADC channel but I see delays all over the place in people's examples. Where should I get the delay value, from the data sheet?
Question:
The PIC16F1509 .h file shows only (I think) one method of setting the internal oscillator using the setup_oscillator(OSC_nMHZ); as shown. Is there another method and why does this statement not compile if I put it before the void main()
