Multiple TCPIP ports?!
stoyanoff
PostPosted: Sat Jan 18, 2014 12:05 pm     Reply with quote
Greetings! Until now I've used ex13b.c to create a TCPIP programs. In this example the state machine is configured to use only 1 port. How could I modify it to work with more than one port ?!
Thanks!
bkamen
Re: Multiple TCPIP ports?!
PostPosted: Wed Jan 22, 2014 11:55 am     Reply with quote
Thanks!
Why do you want more than one port?
stoyanoff
PostPosted: Thu Jan 23, 2014 1:34 am     Reply with quote
For example, I want more than one user to be connected simultaniously!
Thanks!
PostPosted: Thu Jan 23, 2014 8:21 am     Reply with quote
That doesn't involve multiple ports.
A 'connection' (socket) in a TCP/IP system, has source-IP, source-port, dest-IP, dest-port, and protocol components. Two systems can connect to the same port, because the source-IP differs, so a different socket is involved. Whether this is supported is down to whether the code is multi-threaded.
bkamen
PostPosted: Fri Jan 24, 2014 10:25 pm     Reply with quote
Doesn't need to be "multi-threaded" -- you just need to have enough handle slots in the stack to handle multiple socket opens to a given port number.
But otherwise, yea, 1 ethernet port with tcpip can definitely handle more than one user.
I used a PIC18F97J60 for an embedded webserver and it can handle 3 users (because that's all I wanted) simultaneously.
-Ben
PostPosted: Sat Jan 25, 2014 2:01 am     Reply with quote
Yes. You need a multi transaction handling on the stack, which in some environments is referred to as 'multi threading' here. Question of the term you use for the ability to be handling such transactions. Smile
bkamen
PostPosted: Sat Jan 25, 2014 2:41 am     Reply with quote
Meh. It's a pretty sloppy use of the term.
MCHP's stack handles all sorts of things in a single "thread" that simply goes down the various stack calls to see if any data in/out needs to be serviced.
Only one thing happens at a time in sequential order.
It can't even be called time-slicing.
I think "multi-threaded" used in the case of a PIC is too far.
PostPosted: Sat Jan 25, 2014 2:59 am     Reply with quote
Agreed, but the question then becomes of what is generating the data for the transactions?. If you are doing something involving multiple users accessing different things, the code 'behind', feeding the stack, requires multiple threads.
Not a TCP/IP problem, but a question of how the data is generated.
