1Wire and PIC24FV32KA304
DerWolf
PostPosted: Sat Jan 18, 2014 1:05 pm     Reply with quote
I am trying to use a 1Wire Bus on a PIC24FV32KA304 with 16MHz (internal) on PIN_C3. I have successfully used the one wire code already with a PIC18F4523 with 10MHz on PIN_D0. The same code (changing the PINs of course) is not running on the PIC24. The one wire bus is connected to Pin C3 and using a 4KOhm resistor to +5V.
I wrote a small dummy program just waiting 10 sec. after starting then setting the pin C3 low and after 10 sec. high waiting for a other 10 sec. Using a Voltmeter and measuring the 1wire bus against ground showed the first 10 sec. 0V then 5V but after setting it again it did not return to 0V.
thanx
A. Wolf
PostPosted: Sat Jan 18, 2014 1:46 pm     Reply with quote
While I don't use the 24 series PIC and haven't seen your code, have you disabled any/all peripherals(UARTs,PWM,ADC) that are on your C3 pin? Is it a 'programmable' pin not configured correctly ?
hth
jay
DerWolf
PostPosted: Sun Jan 19, 2014 12:08 pm     Reply with quote
Everything should be fine with the configuration. I can't find the reason.
regards
A. Wolf
#FUSES NOWDT
#FUSES CKSFSM
#FUSES NOBROWNOUT
#FUSES FRC_PLL
#device ICSP=1
#use delay(clock = 16MHZ)
#use STANDARD_IO( C )
#use FIXED_IO( A_outputs=PIN_A3,PIN_A2,PIN_A1,PIN_A0 )
#use FIXED_IO( C_outputs=PIN_C8 )
#define IO_1Wire  PIN_C3
#use rs232(UART1, baud=115200, stream=UART_PORT1)
set_tris_c(0b0010000000);
   delay_ms(10000);
   output_low(IO_1Wire);
   delay_ms(10000);
   output_high(IO_1Wire);
   delay_ms(10000);
   output_float(IO_1Wire);
   delay_ms(10000);
PostPosted: Sun Jan 19, 2014 3:26 pm     Reply with quote
Get rid of the fixed_io line, then it has a chance to work. You are
sabotaging your program with the fixed_io line.
DerWolf
PostPosted: Mon Jan 20, 2014 4:40 pm     Reply with quote
Thank you it is working now.
regards
A.Wolf
