Ex_PCD_Bootload.c with Interrupt
arnadan
PostPosted: Fri Jan 10, 2014 1:15 am     Reply with quote
I can successfully build and run Ex_PCD_Bootloader.c and Ex_PCD_Bootload.c. The Ex_PCD_Bootload.c has the following very simple main function:
   printf("\r\nApplication Version 1.0\r\n");
   printf("\r\nYou can put whatever code you want here.");
   printf("\r\nSo enjoy!");
   while(TRUE);
Now I am trying to extend that simple example by a timer as follows:
   printf("\r\nHere is some code now:");
   setup_timer2(TMR_INTERNAL | TMR_DIV_BY_8);
   set_timer2(0xCF2B);        //Setzwert für 10ms-Ueberlauf
   enable_interrupts(INT_TIMER2);   //Timer2 Interrupt freigeben
   while(TRUE);
#INT_TIMER2
void Timer2_ISR(void)
   printf("\r\nHello timer world\r\n");
But now my timer never seems to be called. Something wrong with interrupt vectors? Any ideas on how to get this simple example working?
Any help appreciated. Thanks.
PostPosted: Fri Jan 10, 2014 1:20 am     Reply with quote
Where is your line to enable Global interrupts ?
arnadan
PostPosted: Fri Jan 10, 2014 1:40 am     Reply with quote
Yes I just noticed that I forgot that. Added it now:
   enable_interrupts(GLOBAL);   //Timer2 Interrupt freigeben
   while(TRUE);
#INT_TIMER2
But still it doesn't work.
Notice: As mentioned above this is the Ex_PCD_Bootload.c sample from CCS, so it is relocated in program memory.
PostPosted: Fri Jan 10, 2014 2:02 am     Reply with quote
I question how that compiles, or if you tested it, because according to the
PCD compiler manual the correct form is:
asmallri
PostPosted: Fri Jan 10, 2014 2:06 am     Reply with quote
   while(TRUE);
#INT_TIMER2
You are using printf both inside and outside the interrupt handler. This is a novice mistake. Easy rule of thumb - don't put printf's in interrupt handlers.
Regards, Andrew
arnadan
PostPosted: Fri Jan 10, 2014 2:13 am     Reply with quote
OK: Printf in interrupt not a good idea, but its only a test program. Interrupts are enabled correctly. How I know this:
If I compile and download the program using ICD-U64 programmer everything works fine!
ONLY if I relocate the program (by including PCD_Bootloader.h) the program does not work anymore.
Maybe I should not have posted my example at all but just simple asked:
Can anybody provide a CCS Ex_PCD_Bootload.c sample (which is in the samples directory) that does contain some interrupt handler?
arnadan
PostPosted: Thu Jan 16, 2014 12:30 am     Reply with quote
After contacting their support CCS found the root cause of my problem:
"There is a compiler bug with the jump_to_isr() function when compiling a multiple compilation unit that is causing the problem you have having."
Thank you CCS for the support. Hope this bug will be fixed soon.
jeremiah
PostPosted: Thu Jan 16, 2014 7:47 am     Reply with quote
You can work around that by #including the .c files at the bottom of your main file and setting the project to only compile the main file. Not the most elegant method, but I do it all the time (there are other bugs with multi-comp)
arnadan
PostPosted: Fri Feb 07, 2014 6:30 am     Reply with quote
The bug has meanwhile been fixed by CCS. But as Jeremiah wrote there seem to be other bugs with multi-comp. So thanks Jeremiah for your suggestion: that's the way I am going to build my projects. now!
