Mahdi
| gets() problem |
Posted: Sun Dec 29, 2013 5:24 am |
hi buddies
i want to send string and receive with uart protocol in isis simulator
transmitter code :
| Code: | #include <33FJ32MC204.h>
#use delay(crystal=80M)
#pin_select U1TX=PIN_C6
#pin_select U1RX=PIN_C7
#use rs232(UART1, baud=230400,errors)
#include <stdio.h>
#include <string.h>
#INCLUDE <stdlib.h>
#include <LCD.C>
signed int8 x=10,y=-20,z=35,a=0;
unsigned int8 trt,batt;
char trt1[40],x1[10],y1[10],z1 [10],crt[2];
strcpy(trt1,"");
strcpy(x1,"");
strcpy(y1,"");
strcpy(crt,",");
itoa(trt,10, trt1);
itoa(x,10, x1);
itoa(y,10, y1);
itoa(z,10, z1);
strcat(trt1,crt);
strcat(trt1,x1);
strcat(trt1,crt);
strcat(trt1,y1);
strcat(trt1,crt);
strcat(trt1,z1);
lcd_gotoxy(1,1);
printf(lcd_putc,"%s",trt1);
puts(trt1);
delay_ms(10);
receiver code :
#include <33fj32mc204.h>
#use delay(crystal=80m)
#use i2c(MASTER,I2C1,FAST)
#use rs232(UART1,baud=230400,errors)
#define gyro_xsens 6
#define gyro_ysens 6
#define gyro_zsens 6
#include <var.c>
#INCLUDE <lcd.c>
char x1 [40],bb;
#INT_RDA
void rda_isr(void)
output_high(pin_a1);
gets(x1);
bb=getc();
output_low(pin_a1);
#INT_TIMER3
void timer3_isr(void)
output_high(pin_a0);
i2c_start();
i2c_write(0xd0);
i2c_write(0x43);
i2c_start();
i2c_write(0xd1);
gxh=i2c_read(1);
gxl=i2c_read(0);
i2c_stop();
i2c_start();
i2c_write(0xd0);
i2c_write(0x45);
i2c_start();
i2c_write(0xd1);
gyh=i2c_read(1);
gyl=i2c_read(0);
i2c_stop();
i2c_start();
i2c_write(0xd0);
i2c_write(0x47);
i2c_start();
i2c_write(0xd1);
gzh=i2c_read(1);
gzl=i2c_read(0);
i2c_stop();
gx = make16(gxh,gxl) - gx_OFFSET;
gy = make16(gyh,gyl) - gy_OFFSET;
gz = make16(gzh,gzl) - gz_OFFSET;
gxrate = gx/gyro_xsens;
gyrate = gy/gyro_ysens;
gzrate = gz/gyro_zsens;
output_low(pin_a0);
void main(){
setup_timer3(TMR_INTERNAL | TMR_DIV_BY_64, 1562);
enable_interrupts(INT_timer3);
enable_interrupts(INT_RDA);
while(TRUE){
i use pin a1 for rda interrupt to measure period of interrupt(blue line)
and pina0 for timer3 interrupt to measure............. (yellow line)
in rda interrupt i have 500 us delay until data received
in timer3 interrupt i have 90 us delay until interrupt finished and timer3 set to 2.5 ms and fire.
all things is work but After a period of time, rda interrupt lock for 10 ms why?
ccs v 5
thanks |
Gabriel
Posted: Sun Dec 29, 2013 6:13 am |
Thats one strange baud rate.
Read the sticky post related to Proteus.
Why not just make a small sample program to comunicate between the pics first and then include all the other stuff you are doing? That way you know your comms are working.
G. _________________ CCS PCM 5.078 & CCS PCH 5.093 |
Posted: Sun Dec 29, 2013 8:19 am |
A number of comments ignoring Proteus....
1) What is the maximum crystal frequency the chip supports?......
This will stop the code working in a real chip.
2) INT_RDA, implies _one_ character is available to be read. Do a search here for why you should not use 'gets' in this interrupt, and for replacements.
INT_RDA used like this will lock the receive chip, till a line feed is seen. |
Mahdi
Posted: Sun Dec 29, 2013 12:30 pm |
| Ttelmah wrote: | A number of comments ignoring Proteus....
thanks
when i disable timer3 interrupt the rda interrupt work without any problem.
In my opinion the getc() clear buffer and flag of interrupt but gets() cant it.
now i should clear flag of uart receiver but how ? |
andrewg
Joined: 17 Aug 2005 Posts: 316 Location: Perth, Western Australia
Posted: Mon Dec 30, 2013 12:59 am |
| Mahdi wrote: | when i disable timer3 interrupt the rda interrupt work without any problem.
In my opinion the getc() clear buffer and flag of interrupt but gets() cant it. | gets will clear the buffer and interrupt flag, but it's the wrong function for a serial interrupt handler. You might think it's working, but it isn't. INT_RDA is called for each character and you need to call getc() exactly once for each interrupt. Usually your interrupt handler will put each character into a buffer which your mainline loop will read. See the CCS example "EX_SISR.C". If you need gets() functionality, you will need to write it yourself. _________________ Andrew |
