LCD not working!
Sid2286
LCD not working!
PostPosted: Fri Dec 27, 2013 5:42 am     Reply with quote
I'm using flex_lcd.c with connection as follows:
#define LCD_DB4   PIN_D0
#define LCD_DB5   PIN_D1
#define LCD_DB6   PIN_D2
#define LCD_DB7   PIN_D3
#define LCD_E     PIN_D6
#define LCD_RS    PIN_D4
#define LCD_RW    PIN_D5
I have designed a circuit with above pin connections,
now when I write the following code:
#include <18F4520.h>
#device ICD=TRUE ADC=12
#fuses HS, NOLVP, NOWDT
#use delay (clock=8M)
#include <flex_lcd.c>
#include <stdlib.h>
   delay_us(30);
   while(true)
      lcd_putc("\fHello World\n");
      output_high(Pin_b4);
      output_low(Pin_B4);
my pin B4 is not blinking as it should, nothing comes on LCD, it goes completely blank.
Whereas when I write only the blinking code by commenting the LCD init and LCD_putc, the pin B4 toggles properly.
Not sure what is going wrong.
Please help.
Sid
PostPosted: Fri Dec 27, 2013 6:46 am     Reply with quote
comments:
1) you should have a delay_ms(1000) before the lcd_init();. This allows the LCD module to 'startup and configure itself' before you(the PIC) tries to access it. All LCD modules are similar,needing a small time before you use them. The datasheet will have this spec.Some are faster ,some as slower,but over the years I've settle on 1 second.If you only need to write to the LCD you can save a pin and get rid of the 'am I ready' code.See the driver's comments at the top of the file.
2) I'm assuming those defines are in the flex driver?If so, that's kinda bad practise.Normally you put them in your main() program, just before the #include flex_lcd.c line.Also 'bad' is modifying the original driver.I've always copied the original, calling the copy 'my_flex_lcd.c',make changes in it.That way the original is STILL original!.Also see <>around it, as I use "".The brackets tell the compiler where to find the file,so I wonder if it's finding the original and not the local copy? If it's using the original,then your program would stop and not work correctly. A dump of the listing will quickly tell you what's going on.
3)Some LCD module require contrast to be set with a pot on pins 1,2,3.Do you get black rectangles where the character should be?
As the program doesn't work right( no LCD, no blinking) my guess is either incorrect wiring or corrupted driver and the PIC program is 'hanging' while trying to see if the LCD module is ready.
If you can, post the 'program.lst' file here as it will tell us what's going on.
hth
jay
PostPosted: Fri Dec 27, 2013 7:49 am     Reply with quote
One thing that would cause a complete hang, would be no power to the LCD.
It'd never go 'ready' so the code would sit waiting for ever.
Also, triple check that you are connecting to DB4 to 7 on the LCD, not DB0 to 3.
PostPosted: Fri Dec 27, 2013 9:57 am     Reply with quote
practise.Normally you put them in your main() program, just before the \
Temtronic,
The original flex driver, as posted, does require editing the driver file to
set the #define statements for the pins:
http://www.ccsinfo.com/forum/viewtopic.php?t=24661
Later, a forum member added a post showing how he generalizes the
driver to allow it to be used the way you describe:
http://www.ccsinfo.com/forum/viewtopic.php?t=24661&start=97
I myself have done something similar for years, but I've done it in a
more simple way. I edit the flex_lcd.c driver and add a #ifndef/#endif
pair of statements for one of the pin #define statements:
#ifndef LCD_DB4
#define LCD_E     PIN_A1
#define LCD_RS    PIN_A3
#define LCD_RW    PIN_A2
#endif
Then, the user can #include the flex_lcd.c file and put the pin #define
statements above it. Example:
#define LCD_DB4   PIN_C0
#define LCD_DB5   PIN_C1
#define LCD_DB6   PIN_C2
#define LCD_DB7   PIN_C3
#define LCD_E     PIN_A5
#define LCD_RS    PIN_A2
#define LCD_RW    PIN_A3
#include "flex_lcd.c"
This is all similar to the way CCS does it in their driver files.
Sid2286
PostPosted: Sun Dec 29, 2013 9:44 pm     Reply with quote
I did check the connections again and they seems to be fine. I also checked the program on proteus and its working ok, so the connections are ok.
My .lst file is as follows:
CCS PCH C Compiler, Version 4.124, 58401               30-Dec-13 09:06
               Filename: D:\LCD TEST\lcd_test.lst
               ROM used: 624 bytes (2%)
                         Largest free fragment is 31312
               RAM used: 11 (1%) at main() level
                         22 (1%) worst case
               Stack:    6 locations
0000:  GOTO   01FE
.................... #include <18F4520.h>
.................... //////// Standard Header file for the PIC18F4520 device ////////////////
.................... #device PIC18F4520
.................... #list
.................... #device ICD=TRUE ADC=12
.................... #fuses HS, NOLVP, NOWDT
.................... #use delay (clock=8M)
0026:  CLRF   FEA
0028:  MOVLW  0D
002A:  MOVWF  FE9
002C:  MOVF   FEF,W
002E:  BZ    004A
0030:  MOVLW  02
0032:  MOVWF  01
0034:  CLRF   00
0036:  DECFSZ 00,F
0038:  BRA    0036
003A:  DECFSZ 01,F
003C:  BRA    0034
003E:  MOVLW  97
0040:  MOVWF  00
0042:  DECFSZ 00,F
0044:  BRA    0042
0046:  DECFSZ FEF,F
0048:  BRA    0030
004A:  RETURN 0
.................... #include "D:\LCD TEST\flex_lcd.c"
.................... // flex_lcd.c
.................... // These pins are for the Microchip PicDem2-Plus board,
.................... // which is what I used to test the driver.  Change these
.................... // pins to fit your own board.
.................... #define LCD_DB4 PIN_D0  //  PIN_D0 b3
.................... #define LCD_DB5 PIN_D1  //  PIN_D1 b4
.................... #define LCD_DB6 PIN_D2  //  PIN_D2 b5
.................... #define LCD_DB7 PIN_D3  //PIN_D3 b6
.................... #define LCD_E     PIN_D6 //A1
.................... #define LCD_RS    PIN_D4 //A3
.................... #define LCD_RW    PIN_D5
.................... // If you only want a 6-pin interface to your LCD, then
.................... // connect the R/W pin on the LCD to ground, and comment
.................... // out the following line.
.................... #define USE_LCD_RW   1
.................... #define lcd_type 2        // 0=5x7, 1=5x10, 2=2 lines
.................... #define lcd_line_two 0x40 // LCD RAM address for the 2nd line
.................... int8 const LCD_INIT_STRING[4] =
....................  0x20 | (lcd_type << 2), // Func set: 4-bit, 2 lines, 5x8 dots
....................  0xc,                    // Display on
....................  1,                      // Clear display
....................  6                       // Increment cursor
.................... void lcd_send_nibble(int8 nibble)
.................... // Note:  !! converts an integer expression
.................... // to a boolean (1 or 0).
....................  output_bit(LCD_DB4, !!(nibble & 1));
004C:  BTFSC  14.0
004E:  BRA    0054
0050:  BCF    F8C.0
0052:  BRA    0056
0054:  BSF    F8C.0
0056:  BCF    F95.0
....................  output_bit(LCD_DB5, !!(nibble & 2));
0058:  BTFSC  14.1
005A:  BRA    0060
005C:  BCF    F8C.1
005E:  BRA    0062
0060:  BSF    F8C.1
0062:  BCF    F95.1
....................  output_bit(LCD_DB6, !!(nibble & 4));
0064:  BTFSC  14.2
0066:  BRA    006C
0068:  BCF    F8C.2
006A:  BRA    006E
006C:  BSF    F8C.2
006E:  BCF    F95.2
....................  output_bit(LCD_DB7, !!(nibble & 8));
0070:  BTFSC  14.3
0072:  BRA    0078
0074:  BCF    F8C.3
0076:  BRA    007A
0078:  BSF    F8C.3
007A:  BCF    F95.3
....................  delay_cycles(1);
007C:  NOP
....................  output_high(LCD_E);
007E:  BCF    F95.6
0080:  BSF    F8C.6
....................  delay_us(2);
0082:  BRA    0084
0084:  BRA    0086
....................  output_low(LCD_E);
0086:  BCF    F95.6
0088:  BCF    F8C.6
008A:  RETURN 0
.................... // This sub-routine is only called by lcd_read_byte().
.................... // It's not a stand-alone routine.  For example, the
.................... // R/W signal is set high by lcd_read_byte() before
.................... // this routine is called.
.................... #ifdef USE_LCD_RW
.................... int8 lcd_read_nibble(void)
.................... int8 retval;
.................... // Create bit variables so that we can easily set
.................... // individual bits in the retval variable.
.................... #bit retval_0 = retval.0
.................... #bit retval_1 = retval.1
.................... #bit retval_2 = retval.2
.................... #bit retval_3 = retval.3
.................... retval = 0;
008C:  CLRF   15
008E:  BCF    F95.6
0090:  BSF    F8C.6
0092:  NOP
.................... retval_0 = input(LCD_DB4);
0094:  BSF    F95.0
0096:  BCF    15.0
0098:  BTFSC  F83.0
009A:  BSF    15.0
.................... retval_1 = input(LCD_DB5);
009C:  BSF    F95.1
009E:  BCF    15.1
00A0:  BTFSC  F83.1
00A2:  BSF    15.1
.................... retval_2 = input(LCD_DB6);
00A4:  BSF    F95.2
00A6:  BCF    15.2
00A8:  BTFSC  F83.2
00AA:  BSF    15.2
.................... retval_3 = input(LCD_DB7);
00AC:  BSF    F95.3
00AE:  BCF    15.3
00B0:  BTFSC  F83.3
00B2:  BSF    15.3
00B4:  BCF    F95.6
00B6:  BCF    F8C.6
.................... return(retval);
00B8:  MOVFF  15,01
00BC:  RETURN 0
.................... #endif
.................... // Read a byte from the LCD and return it.
.................... int8 lcd_read_byte(void)
.................... int8 low;
.................... int8 high;
.................... output_high(LCD_RW);
00BE:  BCF    F95.5
00C0:  BSF    F8C.5
00C2:  NOP
.................... high = lcd_read_nibble();
00C4:  RCALL  008C
00C6:  MOVFF  01,14
.................... low = lcd_read_nibble();
00CA:  RCALL  008C
00CC:  MOVFF  01,13
.................... return( (high<<4) | low);
00D0:  SWAPF  14,W
00D2:  MOVWF  00
00D4:  MOVLW  F0
00D6:  ANDWF  00,F
00D8:  MOVF   00,W
00DA:  IORWF  13,W
00DC:  MOVWF  01
00DE:  GOTO   00E8 (RETURN)
.................... // Send a byte to the LCD.
.................... void lcd_send_byte(int8 address, int8 n)
.................... output_low(LCD_RS);
00E2:  BCF    F95.4
00E4:  BCF    F8C.4
.................... while(bit_test(lcd_read_byte(),7)) ;
00E6:  BRA    00BE
00E8:  MOVFF  01,13
00EC:  BTFSC  01.7
00EE:  BRA    00E6
.................... #else
.................... delay_us(60);
.................... if(address)
00F0:  MOVF   11,F
00F2:  BZ    00FA
....................    output_high(LCD_RS);
00F4:  BCF    F95.4
00F6:  BSF    F8C.4
.................... else
00F8:  BRA    00FE
00FA:  BCF    F95.4
00FC:  BCF    F8C.4
00FE:  NOP
.................... output_low(LCD_RW);
0100:  BCF    F95.5
0102:  BCF    F8C.5
0104:  NOP
0106:  BCF    F95.6
0108:  BCF    F8C.6
.................... lcd_send_nibble(n >> 4);
010A:  SWAPF  12,W
010C:  MOVWF  13
010E:  MOVLW  0F
0110:  ANDWF  13,F
0112:  MOVFF  13,14
0116:  RCALL  004C
.................... lcd_send_nibble(n & 0xf);
0118:  MOVF   12,W
011A:  ANDLW  0F
011C:  MOVWF  13
011E:  MOVWF  14
0120:  RCALL  004C
0122:  RETURN 0
.................... void lcd_init(void)
.................... int8 i;
0124:  BCF    F95.4
0126:  BCF    F8C.4
0128:  BCF    F95.5
012A:  BCF    F8C.5
012C:  BCF    F95.6
012E:  BCF    F8C.6
.................... delay_ms(15);
0130:  MOVLW  0F
0132:  MOVWF  0D
0134:  RCALL  0026
.................... for(i=0 ;i < 3; i++)
0136:  CLRF   0A
0138:  MOVF   0A,W
013A:  SUBLW  02
013C:  BNC   014E
....................     lcd_send_nibble(0x03);
013E:  MOVLW  03
0140:  MOVWF  14
0142:  RCALL  004C
....................     delay_ms(5);
0144:  MOVLW  05
0146:  MOVWF  0D
0148:  RCALL  0026
014A:  INCF   0A,F
014C:  BRA    0138
.................... lcd_send_nibble(0x02);
014E:  MOVLW  02
0150:  MOVWF  14
0152:  RCALL  004C
.................... for(i=0; i < sizeof(LCD_INIT_STRING); i++)
0154:  CLRF   0A
0156:  MOVF   0A,W
0158:  SUBLW  03
015A:  BNC   016E
....................     lcd_send_byte(0, LCD_INIT_STRING[i]);
015C:  CLRF   03
015E:  MOVF   0A,W
0160:  RCALL  0004
0162:  MOVWF  0B
0164:  CLRF   11
0166:  MOVWF  12
0168:  RCALL  00E2
....................     // If the R/W signal is not used, then
....................     // the busy bit can't be polled.  One of
....................     // the init commands takes longer than
....................     // the hard-coded delay of 60 us, so in
....................     // that case, lets just do a 5 ms delay
....................     // after all four of them.
....................     #ifndef USE_LCD_RW
016A:  INCF   0A,F
016C:  BRA    0156
016E:  GOTO   0226 (RETURN)
.................... void lcd_gotoxy(int8 x, int8 y)
.................... int8 address;
.................... if(y != 1)
0172:  DECFSZ 0E,W
0174:  BRA    0178
0176:  BRA    017E
....................    address = lcd_line_two;
0178:  MOVLW  40
017A:  MOVWF  0F
017C:  BRA    0180
....................    address=0;
017E:  CLRF   0F
.................... address += x-1;
0180:  MOVLW  01
0182:  SUBWF  0D,W
0184:  ADDWF  0F,F
.................... lcd_send_byte(0, 0x80 | address);
0186:  MOVF   0F,W
0188:  IORLW  80
018A:  MOVWF  10
018C:  CLRF   11
018E:  MOVWF  12
0190:  RCALL  00E2
0192:  GOTO   01D8 (RETURN)
.................... void lcd_putc(char c)
....................  switch(c)
0196:  MOVF   0C,W
0198:  XORLW  0C
019A:  BZ    01A6
019C:  XORLW  06
019E:  BZ    01B6
01A0:  XORLW  02
01A2:  BZ    01C2
01A4:  BRA    01CC
....................     case '\f':
....................       lcd_send_byte(0,1);
01A6:  CLRF   11
01A8:  MOVLW  01
01AA:  MOVWF  12
01AC:  RCALL  00E2
....................       delay_ms(2);
01AE:  MOVLW  02
01B0:  MOVWF  0D
01B2:  RCALL  0026
....................       break;
01B4:  BRA    01D8
....................     case '\n':
....................        lcd_gotoxy(1,2);
01B6:  MOVLW  01
01B8:  MOVWF  0D
01BA:  MOVLW  02
01BC:  MOVWF  0E
01BE:  BRA    0172
01C0:  BRA    01D8
....................     case '\b':
....................        lcd_send_byte(0,0x10);
01C2:  CLRF   11
01C4:  MOVLW  10
01C6:  MOVWF  12
01C8:  RCALL  00E2
01CA:  BRA    01D8
....................     default:
....................        lcd_send_byte(1,c);
01CC:  MOVLW  01
01CE:  MOVWF  11
01D0:  MOVFF  0C,12
01D4:  RCALL  00E2
01D6:  BRA    01D8
01D8:  GOTO   01F0 (RETURN)
.................... char lcd_getc(int8 x, int8 y)
.................... char value;
.................... lcd_gotoxy(x,y);
.................... // Wait until busy flag is low.
.................... while(bit_test(lcd_read_byte(),7));
.................... value = lcd_read_byte();
.................... output_low(lcd_RS);
.................... return(value);
.................... #include <stdlib.h>
bkamen
PostPosted: Mon Dec 30, 2013 12:15 am     Reply with quote
Whoa whoa whoa...
Is this running on proteus or real hardware!?!
You did read this at the top of the forum list:
http://www.ccsinfo.com/forum/viewtopic.php?t=47549
Yes?
Sid2286
Resovled
PostPosted: Mon Dec 30, 2013 4:21 am     Reply with quote
Yeah I know proteus is not an idea way to test circuits, but just to confirm if the connections were proper I had to resolve to it.
Anyways the problem is resolved, Just the way temtronic suggested.,
delay before the initialization made it work. Smile
Sid
gpsmikey
PostPosted: Mon Dec 30, 2013 10:19 am     Reply with quote
I think everyone has been bitten by the "delay needed before init" feature at some point. Good that it is working now.
mikey
mikey
PostPosted: Mon Dec 30, 2013 11:51 am     Reply with quote
Yes, very true.
Key I think is that in many cases the delay needs to be longer than the data sheet may suggest.
The PIC in most cases starts to wake at perhaps only 3v. Depending on the rise time of the supply, this can be several mSec before the LCD reaches the point where it starts to wake.
So you can have a display that says in it's data sheet that it needs 300mSec after the supply comes on, before the first command, which refuses to work, till the delay at the start of the code is set to perhaps 400mSec....
I'd suggest using a figure perhaps of 1.5* the data sheet figure to give good reliability.
Have a good New Year.
