pic 18F97J94 usb driver not supported
fbinotti
PostPosted: Sun Dec 22, 2013 11:50 am     Reply with quote
my compiler (PCH 5.016) say:
"Unknown PIC Device, USB not supported in this library."
Can you update the library?
Thank you & best regards
Fabrizio Binotti
PostPosted: Sun Dec 22, 2013 12:00 pm     Reply with quote
You need to ask CCS.
This is a _user_ forum, not 'technical support'. Note what it says at the top of the page. Quote:
"CCS does not monitor this forum on a regular basis".
PostPosted: Sun Dec 22, 2013 3:42 pm     Reply with quote
However, that having been said, if you
'#DEFINE USB_HW_GENERIC_18F67J50'
the existing library should work. Obviously you'll need to set the fuses and clocks to match your chip, but the actual USB hardware is standard for the more complex chips with buffering selectable to anywhere in memory.
