#BYTE register declaration
Fabrici
PostPosted: Wed Dec 18, 2013 12:30 pm     Reply with quote
Hello all,
CCS Version : CCS PCD C Compiler, Version 5.006, 7054
Chip used : DSPIC33FJ09GS302
In my program, I declare two registers :
#BYTE CMPCON1 = 0x0540
#BYTE CMPCON2 = 0x0544
and, a little further, I affect values to them :
CMPCON1 = 0x8585;
CMPCON2 = 0x0485;
but, here is what the compiler has traducted (in .lst file) :
.................... CMPCON1 = 0x8585;
03D0: MOV.B #85,W0L
03D2: MOV.B W0L,540
.................... CMPCON2 = 0x0485;
03D4: MOV.B #85,W0L
03D6: MOV.B W0L,544
It writes 8 bit value, and I've asked for a 16 bit value. I imagine that I wrote something wrong.
Can you help me dealing this problem ?
Here is the whole code (it is in debugging state) :
#include <33FJ09GS302.h>
//// Historique des version
//// 1.00 :   Initial version
//// Definition FUSES
#FUSES ICSP1      // ICD uses PGC1/PGD1 pins
#FUSES NOJTAG      // JTAG disabled
#FUSES DEBUG      // Debug mode for use with ICD
//#FUSES WPOSTS1   // Watch Dog Timer PostScalar 1:1
#FUSES PLLWAIT      //Clock switch will wait for the PLL lock signal
#FUSES NOWDT      // No Watch Dog Timer
#FUSES FRC_PLL     //Internal Fast RC oscillator with PLL
#FUSES OSCIO        //OSC2 is general purpose output
#FUSES NOIOL1WAY    //Allows multiple reconfigurations of peripheral pins
#FUSES NOWRT       //Program memory not write protected
#FUSES NOPROTECT    //Code not protected from reading
#USE DELAY (clock=7370000)
#USE RS232(BAUD=9600, XMIT=PIN_B1, RCV=PIN_B0, STREAM=COM_A)
#BYTE CMPDAC1 = 0x0542
#BYTE CMPDAC2 = 0x0546
//// Affectation des signaux
#define LED_BLINK PIN_A1
#define TRIGGER_ENABLE PIN_B5
#define POWER_ENABLE PIN_B15
#define TIMER1_VALUE 0x8FF2      // 50 ms
#define TIMER2_VALUE 0x8FF2      // 50 ms
#define TICK_BLINK_LED 50
// Variables Globales //
enum
   RS232_WAITING = 0,
   RS232_COMMAND = 1,
   RS232_HARG = 2,
   RS232_LARG = 3,
   RS232_END = 4,
   RS232_TIMEOUT = 10
} RS232_serial_state = 0;
unsigned int16 tick_counter_blink_led;      // compteur clignotement leds
int1 bStateBlinkingLed;                  // Indicateur état led clignottante
unsigned int8 SerialCommand;
unsigned int8 SerialHArg;
unsigned int8 SerialLArg;
int1 NouvelleCommandeRS232;
// CONFIGURATION DSPIC33 //
#USE FAST_IO(a)
#USE FAST_IO(b)
// Routine d'interruption //
#INT_TIMER1
void timer1_interrupt_handler()
   // Le timer est réglé pour ticker toutes les 50 ms
   set_timer1(TIMER1_VALUE);
   // Gestion led clignotante
   tick_counter_blink_led ++;
   if(tick_counter_blink_led > TICK_BLINK_LED)
      bStateBlinkingLed ++;
      tick_counter_blink_led = 0;
#INT_TIMER2
void timer2_interrupt_handler()
   if(RS232_serial_state != RS232_WAITING)
      RS232_serial_state = RS232_TIMEOUT;
#INT_RDA
void RS232_interrupt_handler()
   char c;
   c = fgetc(COM_A);
   switch(RS232_serial_state)
      case RS232_WAITING :
         if(c == 0x02)         // STX
            RS232_serial_state = RS232_COMMAND;
            set_timer2(TIMER2_VALUE);
      case RS232_COMMAND :
         SerialCommand = c;
         RS232_serial_state = RS232_HARG;
      case RS232_HARG :
         SerialHArg = c;
         RS232_serial_state = RS232_LARG;
      case RS232_LARG :
         SerialLArg = c;
         RS232_serial_state = RS232_END;
      case RS232_END :
         if(SerialCommand == 0x03)
            NouvelleCommandeRS232 = 1;
            NouvelleCommandeRS232 = 0;
            SerialCommand = 0;
            SerialHArg = 0;
            SerialLArg = 0;
         RS232_serial_state = RS232_WAITING;
      case RS232_TIMEOUT :
            printf("%x%x",0xFF, 0x02);
            SerialCommand = 0;
            SerialHArg = 0;
            SerialLArg = 0;
      default:
// Programme principal //
   unsigned int16 PuissanceEclairage;
   int16 iConfigPortA = 1 |   // RA0 : ADC_IN
                  0<<1 |   // RA1 : LED_BLINK
                  0<<2 |   // RA2 : GND
                  0<<3 |   // RA3 : GND
                  0<<4 |   // RA4 : GND
                  0<<5 |   // RA5 : Unimplemented
                  0<<6 |   // RA6 : Unimplemented
                  0<<7 |   // RA7 : Unimplemented
                  0<<8 |   // RA8 : Unimplemented
                  0<<9 |   // RA9 : Unimplemented
                  0<<10 |   // RA10 : Unimplemented
                  0<<11 |   // RA11 : Unimplemented
                  0<<12 |   // RA12 : Unimplemented
                  0<<13 |   // RA13 : Unimplemented
                  0<<14 |   // RA14 : Unimplemented
                  0<<15;   // RA15 : Unimplemented
   int16 iConfigPortB = 1 |   // RB0 : SERIAL_IN
                  0<<1 |   // RB1 : SERIAL_OUT
                  0<<2 |   // RB2 : GND
                  0<<3 |   // RB3 : DAC_OUT
                  0<<4 |   // RB4 : GND
                  0<<5 |   // RB5 : TRIGGER_ENABLE
                  0<<6 |   // RB6 : PGED
                  0<<7 |   // RB7 : PGEC
                  0<<8 |   // RB8 : GND
                  0<<9 |   // RB9 : GND
                  0<<10 |   // RB10 : GND
                  0<<11 |   // RB11 : GND
                  0<<12 |   // RB12 : GND
                  0<<13 |   // RB13 : GND
                  0<<14 |   // RB14 : GND
                  0<<15;   // RB15 : POWER_ENABLE
   //// Initialisations ////
   //// DAC
   int iConfigCMPCON1 =    1 |      // RANGE : High range = 1
                     0<<1 |   // CMPPOL : Comparator Output Polarity Control Bit
                     1<<2 |   // HGAIN : DAC Gain Enable bit
                     0<<3 |   // CMPSTAT : Current state of Comparator output
                     0<<4 |   // HYSPOL : Comparator Hysteresis Polarity selection bit
                     0<<5 |   // EXTREF : Internal reference source provide reference to DAC
                     0<<6 |   // INSEL 0 : Select CMPxC input pin
                     1<<7 |   // INSEL 1 : Select CMPxC input pin
                     1<<8 |   // DACOE : DAC Output Enable
                     0<<9 |   // FCLKSEL : Digital filter and pulse stretcher clock selection bit
                     1<<10 |   // FLTREN : Digital filter enable bit
                     0<<11 | // HYSSEL 0 : Comparator hysteresis select bits
                     0<<12 | // HYSSEL 1 : Comparator hysteresis select bits
                     0<<13 | // CMPSIDL : Stop in iddle mode bit
                     0<<14 | // Unimplemented
                     1<<15;   // CMPON : Comparator Operating Mode bit
   int iConfigCMPCON2 =    1 |      // RANGE : High range = 1
                     0<<8 |   // DACOE : DAC Output Enable
                     0<<15;   // CMPON : Comparator Operating Mode bit
   //CMPCON1 = iConfigCMPCON1;
   //CMPCON2 = iConfigCMPCON2;
   CMPCON1 = 0x8585;
   CMPCON2 = 0x0485;
   //// Ports I/O
   set_tris_a(iConfigPortA);
   set_tris_b(iConfigPortB);
   //// Configuration des résistances tirées au GND
   output_low(PIN_A2);
   output_low(PIN_A3);
   output_low(PIN_A4);
   output_low(PIN_B2);
   output_low(PIN_B4);
   output_low(PIN_B8);
   output_low(PIN_B9);
   output_low(PIN_B10);
   output_low(PIN_B11);
   output_low(PIN_B12);
   output_low(PIN_B13);
   output_low(PIN_B14);
   //// Initialisation des divers signaux
   output_low(LED_BLINK);
   output_low(TRIGGER_ENABLE);
   output_low(POWER_ENABLE);
   //// Initialisation variables
   bStateBlinkingLed = 0;
   SerialCommand = 0;
   SerialHArg = 0;
   SerialLArg = 0;
   //// Timer 1 (Led clignotante)
   setup_timer1(TMR_INTERNAL);
   clear_interrupt(INT_TIMER1);
   //// Timer 2 (Timout reception RS232)
   setup_timer2(TMR_INTERNAL);
   clear_interrupt(INT_TIMER2);
   //// Enable global interrupts
   //// Boucle de fonctionnement
   do
      // Gestion Led clignotante
      if(bStateBlinkingLed)
         output_high(LED_BLINK);
      // Gestion commandes RS232
      /*if(NouvelleCommandeRS232)
         switch(SerialCommand)
            // Définition du mode de fonctionnement
            case 0x00:
               if(SerialLArg == 0x01)
                  // Mode Flash
                  output_high(TRIGGER_ENABLE);
                  printf("%x%x",0x00, 0x00);
               else if(SerialLArg == 0x02)
                  // Mode Eclairage
                  printf("%x%x",0x00, 0x01);
            // Enable Light (mode Eclairage)
            case 0x01:
                  output_high(POWER_ENABLE);
                  printf("%x%x",0x01, 0x00);
                  printf("%x%x",0x01, 0x01);
            // Réglage puissance éclairage
            case 0x02:
               PuissanceEclairage = (SerialHArg << 8) + SerialLArg;
               CMPDAC1 = PuissanceEclairage & 0x03FF;
               printf("%x%x",0x02, 0x00);
            // Unknown command
            default:
               printf("%x%x",0xFF, 0x01);
      //// Tests
      CMPDAC1 = 500;
   while (TRUE);
newguy
PostPosted: Wed Dec 18, 2013 12:54 pm     Reply with quote
Almost. You want #word not #byte.
PostPosted: Wed Dec 18, 2013 3:13 pm     Reply with quote
real close !!
you have ...
...which means that 'CMPCON1' is 8 bits long( a byte) located at 0x540
you really need
#WORD CMPCON1 = 0x0540
...which means that 'CMPCON1' is 16 bits long( a word) located at 0x540
hth
jay
Fabrici
PostPosted: Thu Dec 19, 2013 4:01 am     Reply with quote
A big thanks for the help.
It works perfectly now (at least for this part ^^).
Have a nice day.
PostPosted: Thu Dec 19, 2013 9:15 am     Reply with quote
As a comment, there is also a way of doing larger things.
#BYTE can be used two different ways.
By default it creates a 'byte' sized variable at a location. #WORD creates a 16bit variable at a location.
However you can also use it like this:
int32 val;
#BYTE val=0x1234
Done like this, #BYTE _locates_ the already defined variable at the specified memory address. This allows you to define things like fp values, or even arrays at a particular location in RAM.
Can be useful sometimes. Smile
