TM1809
jackmicro
TM1809
PostPosted: Fri Nov 15, 2013 10:15 pm     Reply with quote
Hello all,
Do any of you golden hearted coders know of any library to handle LED strips, namely the TM1809 chip?
Any help will be truly appreciated.
Jack
PostPosted: Sat Nov 16, 2013 1:28 am     Reply with quote
Google for it. Look at his ws2811.c file:
http://www.insomnialighting.com/products/rgbsmdws2811.html
PostPosted: Sat Nov 16, 2013 5:32 pm     Reply with quote
here's a test I did 2 years ago....yikes, time flies !!
it might help...
jay
//46k22_ws2801_2.c
//46k22 ws2801 8 LED test code
// working blu-grn-red-yel-vio-tel-bnk-wht
#include <18f46k22.h>
#include "46k22_fuses.h"
#include "46k22_pins.h"
#use delay(clock=16000000)
#use rs232(baud=9600,xmit=SIO_TX1,rcv=SIO_RX1,errors,stream=SIOport)
#use rs232(baud=9600,xmit=SIO_TX2,rcv=SIO_RX2,errors,stream=USBport)
#include "46k22_LCD.c"
#include "jay_DS1307.c"
#USE SPI (MASTER, SPI1, MODE=0, BITS=8, STREAM=SPI_1, MSB_FIRST)
#define LED_STRIP_LEN 8 // number of LEDs on the strip
#define RAND_MAX 255
unsigned int32 led_strip_colors[LED_STRIP_LEN];
void send_frame() {
  unsigned int16 i;
  unsigned int8 red,green,blue;
  for(i=0;i<LED_STRIP_LEN;i++) {
    blue = led_strip_colors[i] & 0xFF;
    green = (led_strip_colors[i] >> 8) & 0xFF;
    red = (led_strip_colors[i] >> 16) & 0xFF;
    spi_write(red);
    spi_write(green);
    spi_write(blue);
  delay_us(500);    // delay 500us to latch the IC
    unsigned int16 i;
   unsigned int16 x;
lcd_init();
printf(lcd_putc,"WS2801 test 1");
while(true){
    for(i = 0 ; i < LED_STRIP_LEN ; i++) {led_strip_colors[i] = 0;}
    led_strip_colors[0] = 0xFF0000;  // red
    led_strip_colors[1] = 0x00FF00;  // green
    led_strip_colors[2] = 0x0000FF;  // blue
    led_strip_colors[3] = 0x00FFFF;  // green + blue
    led_strip_colors[4] = 0xFF00FF;  // red + blue (purple)
    led_strip_colors[5] = 0xFFFF00;  // red + green (org)
    led_strip_colors[6] = 0x000000;  // off + off + off
    led_strip_colors[7] = 0xFFFFFF;  // red + green + blue (white)
    send_frame();
lcd_gotoxy(2,2);
printf(lcd_putc,"%lu pass",x);
x=x+1;
}// forever while loop
}// end of main
jackmicro
PostPosted: Sat Nov 16, 2013 5:51 pm     Reply with quote
many thanks. appreciated!
