So because of the problems I've been having with the older ccs compiler through MPLABX, I've decided to give the demo of the latest version a shot using the CCS IDE and everything. I'm running into an issue while trying to program my ICD3 through it though... so first of all: is it possible to program using the ICD3 through the CCS IDE? From what I gather it should be?
But after I've gone and installed the demo and the 'icd/icd2/icd3/realice interface' thing, I still get the errors:
"Could not load function: DBG_PASSTHROUGH. Make sure you are running the latest version"
and
"Missing Library. On the CCS download page d/l and execute icd/icd2/icd3/realice interface software. Then re-run this software"
But... no matter how many times I install that straight from the site I keep getting the same message
Any ideas?
Rick Harris
Posted: Tue Nov 05, 2013 10:46 am
I'm having the same problem. Did you ever find a solution?
diogoc
Posted: Thu Nov 14, 2013 2:57 pm
I have the same problem. Solution please..
Posted: Thu Nov 14, 2013 3:01 pm
This is NOT CCS tech support.
As stated in the upper right portion of the web page, send a message to
