Mach X failed to program
Simnix
PostPosted: Tue Nov 05, 2013 12:44 am     Reply with quote
PIC C Compiler version 4.109
When I use my Mach X programmer/debugger via ICD, it fails to program when I use the PIC C Compiler IDE. But, when I program the controller via the DIP socket, it programs OK. How can I tell the software to program via the ICD when there is no controller in the DIP socket ?
regards
Simnix
PostPosted: Tue Nov 05, 2013 5:01 am     Reply with quote
You need to run CCSload. Set it to use either 'Mach-X supplies power', or 'Target powered' (which are the ICSP settings, rather than the 'ZIF socket' setting). Exit. Then use the IDE. The IDE connects 'via' CCSload, and it is the CCSload settings that are used.
Simnix
PostPosted: Tue Nov 05, 2013 5:43 am     Reply with quote
When I program using PIC C Compiler IDE it comes up with "Download Failed", when I run ccsload and press the test button on the devices tab, it comes up with "Chip not detected". I have selected "MACH-X supplies power". Confused
Just for note, when I place the controller in the ZIF socket it and select "ZIF Socket", it programs OK.
Regards
Simnix
Simnix
PostPosted: Tue Nov 05, 2013 8:20 am     Reply with quote
Hi
Found the problem, two faulty controllers. Used a brand new controller and it worked. Derr Rolling Eyes
Thanks for your initial help.
Regards
Simnix
PostPosted: Tue Nov 05, 2013 9:45 am     Reply with quote
Might be something just slightly 'else'.
Depending on the circuit, Mach-X can only supply limited power. It might be 'borderline', on not supplying enough power, so some chips program, while others don't.
There have been threads here in the past about how best to wire here, and the limitations.
Simnix
PostPosted: Tue Nov 05, 2013 9:49 am     Reply with quote
Thanks for the heads up. I will investigate further.
Simnix
