Timer0 interrupt and printf
foxOnTheRun
PostPosted: Mon Oct 21, 2013 1:25 pm     Reply with quote
Straight to the point:
PIC16F690@8MHz (internal osc).
setup_timer_0(RTCC_INTERNAL|RTCC_DIV_8|RTCC_8_bit);
I'm using this to generate 1khz pwm:
#int_TIMER0
void TIMER0_isr(void) // 250 * (4*4)/8000000 --> *2 = 1kHz / 1ms
output_toggle(DIS_ctrl);     // on/off
pwm_ctrl = 1 - pwm_ctrl;    // flip status high/low state
// will stay up for t_on time
if (pwm_ctrl == 1)
    t_off = t_on;  // next
    set_timer0(get_timer0() + (255 - t_on) + tmr0_offset); // timer0 count onward
// else will stay down for t_off time
else set_timer0(get_timer0() + t_off + tmr0_offset);
And the main is something like this:
t_on = 125; //50% duty c. pwm wave
set_adc_channel(ch_discharge);
output_low(DIS_ctrl);
set_timer0(0);
enable_interrupts(int_TIMER0);
while (key == 0) {
    read_i();
    read_i();
    // printf(lcd_putc,"\n%4Lu       ", value_i());
Where read_i() is:
void read_i(){
vett_i[1] = vett_i[0];
vett_i[0] = read_adc() + 1;
And value_i() is:
unsigned int16 value_i(){
return ((vett_i[0]+vett_i[1]+1)/2);
Well, I can see that with the printf commented, the pwm frequency is fixed at 1KHz, as expected. But if I uncomment the printf I can spot some freq. distortion on the output wave, right when printf is working.
I've searched the forum and I see no mention that the printf should interfere with interrupts sources (it's only a printf after all) - but, I guess, it's the LCD slowlyness that breaks stuff around.. is it?
About the timer0 procedure, before, I used input() function to poll the output pin state: can somebody confirm if is it's slower of faster than setting and checking a simple variable? (well, educated guess: almost the same or slower) - any other obeservation, are greatly welcomed ;)
Listen, why don't you relax? Take a pill, bake a cake or go and read the encyclopedia.
PostPosted: Mon Oct 21, 2013 1:37 pm     Reply with quote
http://www.ccsinfo.com/forum/viewtopic.php?t=51316
http://www.ccsinfo.com/forum/viewtopic.php?t=51284
Always post your compiler version.
Mike Walne
PostPosted: Mon Oct 21, 2013 4:39 pm     Reply with quote
It helps if you post a SHORT but complete compilable code we can copy and paste as is to test.
How much frequency variation are you getting?
Could you not use the hardware PWM module?
Mike
PostPosted: Tue Oct 22, 2013 2:24 am     Reply with quote
Yes, compiler version, and a compilable version. Problem is that there are lots of things 'not shown', which might be the core of the problem...
I don't think this is the GIE problem, since this would leave the interrupt disabled, and stop the output.
Have to 'second' the remark, why not use the hardware PWM?
However thoughts:
What port is the LCD on?. What pin is being toggled in the interrupt?. Are you using fast_io?.
If the pin being toggled, is the spare pin on the same port as the LCD, what you may be seeing, is the TRIS register being changed as the LCD is accessed. If so, consider going to fast_io.
Which LCD driver?. CCS, or flex_lcd?.
Comments like "the main is something like this:", makes us very unwilling to look further, especially given that what is posted, won't work....
johanpret
PostPosted: Tue Oct 22, 2013 4:06 am     Reply with quote
Compiler Bug. I had the same problem only to find out the printf switch of the Global interrupt flag. Apparently its fixed in V5.0.13 but I still have problems with V5.0.13 as well. V4.0.141 its working.
Johan Pretorius
PostPosted: Tue Oct 22, 2013 4:53 am     Reply with quote
The current compiler problem with the GIE bit, results in the interrupts being _disabled_. This would stop his output.
However when this was first found, it resembled an _earlier_ problem where the interrupts were being disabled, and sometimes not re-enabled.
This is why everybody has asked 'compiler version'?.
