Using timer0 and timer1's interruptions in the same code
seed_87
PostPosted: Sun Oct 13, 2013 2:16 pm     Reply with quote
Hi!
Can it be done? What would be the downside of that?
I'd imagine if the PIC called one of the isr (lets say timer1's isr) then it wouldnt interrupt that isr in order to call timer0's isr, right?
In any case, would you still do it?
Something like (btw, using PIC16F887):
//Configuracion timer0 - RTCC
setup_timer_0( RTCC_INTERNAL | RTCC_DIV_64);
set_timer0(0);
enable_interrupts(INT_RTCC);
//Configuracion timer1
setup_timer_1(T1_INTERNAL | T1_DIV_BY_8);
set_timer1(0);
#int_rtcc
void timer0_isr()
#INT_TIMER1
void clock_isr()
Mike Walne
PostPosted: Sun Oct 13, 2013 2:49 pm     Reply with quote
Can it be done?
Yes
Depends on the PIC.
With PIC16's you have to wait for one ISR to finish before the other can run.
With PIC18s you get two priorities. The higher level can interrupt the lower level.
Of course, with the usual caveats.
Mike
seed_87
PostPosted: Sun Oct 13, 2013 5:49 pm     Reply with quote
Oh, i see..
Many thanks mike!!
PostPosted: Mon Oct 14, 2013 1:01 am     Reply with quote
and (of course) the 'having to wait', shouldn't matter, provided you repeat the mantra (and use it), of 'keep the handlers short'. If the handler just does the job required (read a time, increment a counter, etc. etc.), and exits immediately, the second handler will then be called with only a tiny delay. Smile
