runo
| GPS example |
Posted: Tue Oct 08, 2013 4:29 pm |
(GPS with pic 16f877a) how do communications ?(example for gps )
Help me please ?
#include <main.h>
#fuses XT,WDT,NOPROTECT,NOBROWNOUT,NOLVP,NOPUT,NOWRT,NODEBUG,NOCPD
#use delay (clock=4000000)
#use rs232 (baud=9600, xmit=pin_C6, rcv=pin_C7, parity=N, stop=1,ERRORS)
char klavye[50];
#int_rda
void serihaberlesme_kesmesi()
disable_interrupts(int_rda);
output_high(pin_d0);
gets(klavye);
delay_ms(2000);
output_low(pin_d0);
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_psp(PSP_DISABLED);
setup_spi(SPI_SS_DISABLED);
setup_timer_1(T1_DISABLED);
setup_CCP1(CCP_OFF);
setup_CCP2(CCP_OFF);
printf("AT");
putchar(0x0D);
enable_interrupts(int_rda);
Why not run ? |
ezflyr
Posted: Tue Oct 08, 2013 7:59 pm |
Frankly, your code is a mess, and we have no idea what "Why not run" means.....
A sample of issues I found on a quick scan of your code:
1. No PIC type defined
2. We have NO idea what's in Main.h
3. Your serial ISR disables interrupts - not necessary
4. Your serial ISR uses gets() - this is incorrect, it should read a SINGLE character with getc()
5. You are repeatedly enabling int_rda in a while() loop - why???
This wheel has been invented, and re-invented many times here on the forum, so I suggest you spend a few hours reading the forum archives.....
Seriously, before you even think of a GPS project, at least get your PIC to flash an LED. Learn to crawl before you try to run!
John |
TMLtech
Posted: Thu Oct 10, 2013 3:40 am |
| And there is huge delay inside the interrupt vector. |
