Winstar GLCD display
hemnath
PostPosted: Tue Oct 08, 2013 12:43 am     Reply with quote
I'm using PIC18LF2520, Oscillator type: Internal 1Mhz, GLCD: Winstar WG12232A-YYH, Compiler version: 4.114
Earlier i worked with KS0108 display. But i have problem with winstar display. I can't see the enable pin.
Which driver can i use to display the text on the display?
Thanks in advance:)
PostPosted: Tue Oct 08, 2013 2:35 am     Reply with quote
You'd have to write your own.....
However not (possibly) quite as bad as it sounds. This display has two controllers each operating half the display. Each is a SBN1661, and these are compatible with the SED1520. Now the SED 1520, uses a subset of the commands supported by the SED1335 (which supports larger panels). There is a driver for the 1335 with the compiler. There are two separate 'enable' pins for the two chips, pins 5&6 (CE1, and CE2). Temporarily ignore half the display, and using just one enable, try the SED1335 driver, modified for the smaller display. If this can be got working, then it just becomes a matter of enabling the second chip when using the second half of the display, and offsetting the X coordinate.
hemnath
PostPosted: Tue Oct 08, 2013 3:57 am     Reply with quote
Thanks Ttelmah for your suggestion.
First, I'm displaying all the pixels ON. But nothing on the display.
#include "18F2520.h"
#fuses INTRC_IO
#use delay(clock = 1000000)
#define CS1 PIN_B4
#define CS2 PIN_B5
#define A0  PIN_B3
   // R/W pin - LOW; RES pin- HIGH
   output_high(CS1);
   output_high(CS2);
   output_high(A0);   // command mode
   output_a(0x3F);      //
      output_low(CS1);
      output_high(CS2);
      output_high(CS1);
      output_low(CS2);
PostPosted: Tue Oct 08, 2013 4:19 am     Reply with quote
You are just toggling the chip selects. You still have to write data, set direction etc...
As I said, look at the SED1335 driver, and modify this for one half the display width.
You are not going to get very far just operating the select lines. You need byte wide data, plus the R/W control etc...
hemnath
PostPosted: Tue Oct 08, 2013 4:42 am     Reply with quote
In SED1335 Driver, I have changed the following lines,
GLCD_WIDTH as 122
GLCD_HEIGHT as 32
input_d() as input_a()
A0 as PIN_B3
CS as PIN_B4
But don't know what to assign to these defines,
#ifndef GLCD_RD
#define GLCD_RD            PIN_B5
#endif
#ifndef GLCD_WR
#define GLCD_WR            PIN_B1
#endif
hemnath
PostPosted: Wed Oct 09, 2013 2:30 am     Reply with quote
I have only R/W pin.. What is GLCD_RD and GLCD_WR in that driver?
Which pins should i connect to?
Please help.
PostPosted: Wed Oct 09, 2013 3:12 am     Reply with quote
As I said, _modified_.
The larger chip has separate read/write pins. The smaller has instruction/data enable, chip enable, and a combined R/W. The point is that the basic command set is the same, so you have to write the I/O section using this, to talk to your display.
It's called programming.....
hemnath
PostPosted: Wed Oct 09, 2013 3:42 am     Reply with quote
Yes i have modified the code as you said.
sample code:
#fuses INTRC_IO
#include "SED1335_LPM.c"
glcd_systemSetup();
glcd_init(ON);
glcd_power(ON);
glcd_fillScreen(ON);
SED1335_LPM.c
#ifndef GLCD_WIDTH
#define GLCD_WIDTH         122
#endif
#ifndef GLCD_HEIGHT
#define GLCD_HEIGHT        32
#endif
#ifndef GLCD_CHAR_WIDTH
#define GLCD_CHAR_WIDTH    8
#endif
#ifndef GLCD_CHAR_HEIGHT
#define GLCD_CHAR_HEIGHT   8
#endif
#ifndef GLCD_RST
#define GLCD_RST           PIN_C1
#endif
#ifndef GLCD_RD
#define GLCD_RD            PIN_C0
#endif
#ifndef GLCD_WR
#define GLCD_WR            PIN_C0
#endif
#ifndef GLCD_CS
#define GLCD_CS            PIN_B4
#endif
#ifndef GLCD_A0
#define GLCD_A0            PIN_B3
#endif
and output_d() as output_a()
But nothing is displayed on the display. I don't know what to do now. Please help.
PostPosted: Wed Oct 09, 2013 4:18 am     Reply with quote
As I said, _you_need to modify the code. Not just the settings.
hemnath
PostPosted: Wed Oct 09, 2013 4:37 am     Reply with quote
I dunno where to modify. So i'm writing of my own. Please check this program. It is not working. Does my glcd_cmd and glcd_data are correct?
#fuses INTRC_IO
#define A0    PIN_B3
#define CS1   PIN_B4
#define CS2   PIN_B5
const unsigned char data[]  = {0x00, 0x00, 0xE7, 0xE7, 0xE7, 0xE7, 0x00, 0x00};    // invert of H
void glcd_data(unsigned char z);
void glcd_cmd(unsigned char c);
unsigned int i;
   output_high(CS1);      // CS1 connected to PIN_B0
   output_high(CS2);     //  CS2 connected to PIN_B1
   glcd_cmd(0xe2);   //software Reset
   glcd_cmd(0xa0);   //Select ADC = 0
   glcd_cmd(0xa4);   //Static  Drive OFF
   glcd_cmd(0xa9);   //Select Duty = 1 /32
   glcd_cmd(0xc0);   //Set Start Line 0(C0H)~31(DFH)
   glcd_cmd(0xb8);   //Set Page Address 0(B8H)~3(BBH)
   glcd_cmd(0x00);   //Set segment Address 0(00H)~(4FH)
   glcd_cmd(0xaf);   //Set Display ON
      output_high(CS1);
      output_high(CS2);
      glcd_cmd(0xC0);   // display start line
      glcd_cmd(0xB8);
      for (i = 0; i < 8; i++)
         glcd_data(data[i]);
   output_low(A0);
   output_a(c);
   output_low(CS1);
   output_low(CS2);
   delay_ms(50);
   output_high(CS1);
   output_high(CS2);
   output_high(A0);
   output_a(z);
   output_low(CS1);
   output_low(CS2);
   delay_ms(50);
   output_high(CS1);
   output_high(CS2);
hemnath
PostPosted: Thu Oct 10, 2013 5:32 am     Reply with quote
by which command, the chip gets activated?
output_high(CS1);
(or)
output_low(CS1);
oxo
PostPosted: Thu Oct 10, 2013 5:53 am     Reply with quote
Read the display data sheet and understand it. If you can't do that, then embedded programming is not for you.
