alan
Joined: 12 Nov 2012 Posts: 358 Location: South Africa
| [SOLVED] Using SS in #USE SPI |
Posted: Tue Oct 01, 2013 3:37 pm |
dsPIC33FJ12MC202
CCS V 5.012
How do I map the SS in the following code:
| Code: | #pin_select SCK1IN=PIN_B4
#pin_select SDI1=PIN_B6
#pin_select SDO1=PIN_B5
#use spi(SLAVE, SPI1, MODE=3, BITS=8, ENABLE=PIN_B7, stream=SPI_PORT1)
or do I have to use setup_spi and what are the name of the SS pin for pin _select then.
The compiler gives an "Option invalid Wrong SS pin" error.
Regards
jeremiah
Posted: Tue Oct 01, 2013 4:58 pm |
Remove the enable option and put in a pin_select for the SS:
SS1IN=PIN_B7 |
alan
Posted: Tue Oct 01, 2013 10:59 pm |
Thanks jeremiah. That solved it, but I had to keep the ENABLE OPTION, for the compiler to set the register for SS.
Regards
Alan |
