silvanose
| gsm interface to pic16f877a |
Posted: Sat Sep 28, 2013 11:29 pm |
How can I display sms on 16*2 lcd and how to make a call ? I am using gsm900 module and pic 16f877a. _________________ Fly in excellence |
Joined: 01 Jul 2010 Posts: 9657 Location: Greensville,Ontario
Posted: Sun Sep 29, 2013 5:18 am |
Start small...
first get the 877 to flash an LED at 1HZ rate...
... this will confirm your hardware is correct
next get the 877 to send 'hello world' to LCD module...
... confirms you've got that 'up and running'
next get a PC connected to the PIC...
... confirm you can send and receive from the PC
now connect the GSM to the PIC...
You need to do each step..building knowledge nd getting familiar with the PIC, C and 'how it all works'..
and
be sure to learn the 'search' feature on this forum. Ther's lots of threads about PIC and GSM here, but don't just copy and paste code,odds are real good it won't work first time!
That's why you need to take small steps.
hth
jay |
ezflyr
Posted: Sun Sep 29, 2013 2:06 pm |
Start by reading the forum archives as this exact project - I guess it's a common school assignment! - has been covered many, many times.....
It's not enough to tell you are using a 'SIM900', you've got to post a link to the actual hardware you are using. The basic SIM900 can be directly connected to the PIC, while the. (more common) breakout board mounted version usually has RS232 interface hardware..... We need to know what you've got!
Also, in the Code Library there is a working SMS "driver" by forum user Gabriel.....
John |
SSR
ezflyr
Posted: Tue Oct 01, 2013 1:04 pm |
Didn't I already say that??
| Quote: |
John |
SSR
Posted: Wed Oct 02, 2013 7:58 am |
Surely, but i missed that. Don't worry it won't take much of forum space.  |
silvanose
Posted: Wed Oct 02, 2013 10:50 am |
Thanks for all. I tried this project and it works fine. Thanks Gabriel. _________________ Fly in excellence |
Gabriel
Posted: Wed Oct 02, 2013 11:49 am |
no problem...
thanks to the other guys that took the time to point you in the right direction. specially ezflyr who helped out with the driver.
[cartoon deleted]
Thanks yes, cartoons no. Sorry.
- Forum Moderator
++++++++++++++++++ _________________ CCS PCM 5.078 & CCS PCH 5.093 |
