Ringo42
| bmp085 |
Posted: Wed Oct 13, 2010 7:32 pm |
Anybody used a bmp085 pressure sensor? I'm trying to connect it to an 18f452 but the readings don't make sense.
Ringo _________________ Ringo Davis |
kaka khan
Posted: Sat Sep 28, 2013 5:25 am |
| send your code i will check it |
Posted: Sat Sep 28, 2013 5:56 am |
After 3 years you think he is still waiting for someone to 'check' his code?
Don't bump old threads.
If you want to use the code for your own purposes, then it is best to send him a private message and ask for the code. |
dyeatman
Posted: Sat Sep 28, 2013 5:58 am |
The driver in the Code Library by Al Testani works perfectly
for both the BMP085 and the BMP180. I have tested both. _________________ Google and Forum Search are some of your best tools |
savotech
Posted: Thu Jan 16, 2014 3:56 am |
please post the link to altestani code
please someone help me with a working bmp085 driver, i am not too good at i2c |
Posted: Thu Jan 16, 2014 2:53 pm |
Seriously, have you even spent 1 minute to search the link yourself?
I never heard of the sensor, but in 10 seconds I was able to find it two times.
Edit:
I had posted here the two methods I used to find the link but its so easy that I refuse to help you. If you don't want to put some effort in it, then I don't see why we should spent out time on helping you. |
