#PIN_SELECT problems
Goto page 1, 2  Next
bela
PostPosted: Sun Sep 15, 2013 12:00 pm     Reply with quote
Hi All,
I have an issue mapping my SPI to my RPx pins.
Chips tried: 24FJ64GA002, dsPIC33FJ64MC802, 33FJ12GP202
Compiler: PCD 4.097
#PIN_SELECT U1TX=PIN_B8   //UART works fine
#PIN_SELECT U1RX=PIN_B9   //UART works fine
#PIN_SELECT SDI1=PIN_B15
#PIN_SELECT SDO1=PIN_B14
#PIN_SELECT SCK1OUT=PIN_B13
//then #use SPI(etc)
//then #use RS232(etc)
Always results in 3 errors referring to the SPI 3 pin selects:
Invalid pre-processor directive: invalid pin (chip)
If I comment out the SPI stuff, the UART works fine on any RP pins I choose.
So, I tried two of the SPI lines on B9 and B8 - same error.
checking inside the chip editor, all correct pins are set for RP.
Help :\ ! Struggling to figure this one out...
I've resorted to an 18F at 10 MIPS but is way too slow for what I'm doing (SD card storage over SPI and not fat)
Any help is appreciated.
regards,
Darren
[Bela Electronic Designs, Bedford]
PostPosted: Sun Sep 15, 2013 12:20 pm     Reply with quote
On the first of those chips at least, the SPI, is _not_ software selectable. It is relocatable to two different pin pairs, using a fuse. I2C1SELA or I2C1SELD.
Didn't look at the other chips.
bela
PostPosted: Sun Sep 15, 2013 12:41 pm     Reply with quote
Hi thanks for your reply.
According to the family data sheet the SPI is software selectable.
Table 10-2 shows the Inputs (for SDI)
and 10-3 show the Outputs (CLKOUT and SDO)
The same tables show U1TX and U1RX.
or have I mis-understood it?
There are 10 types of people in this world; those who understand binary and those who don't.
PostPosted: Sun Sep 15, 2013 3:01 pm     Reply with quote
They are using 'mixed meanings' for the phrase 're-mappable pins'. Most are mappable to any of the RP pins, but the SPI is not.
If you look at table 1-2, the SPI lines are shown as only mappable to the SCL1/2 SDA1/2 SDI1/2 pins or the ASCL1/2 ASDA1/2 ASDI1/2 pins, with the selection done using the fuses already mentioned. They are 're-mappable', but _not_ to the general re-mappable peripheral pins.
So the UART is mappable using #pin select, but the SPI can only be mapped to the two alternate locations using the fuses.
Now I agree the pages later in the stuff dealing with the re-mappable pins disagrees. One or the other is a data sheet error. The compiler is treating the first as 'right', and the fuses shown also say this is right (the alternate is shown here too).
To further confirm this, MPLAB, does not have the re-mapping register for the SPI implemented.
I'd suspect a generic bit of data sheet has been cut and pasted...
jeremiah
PostPosted: Sun Sep 15, 2013 3:57 pm     Reply with quote
I didn't check on the two other chips, but the pic24fj64ga002 does have SPI on the RP pins. #pin_select is appropriate for SPI on the first chip (I didn't check the other ones). Only I2C is not remappable past those specific pins.
You either need to upgrade your compiler or there is more to your code than you are showing us. I just tossed those pin selects into one of my pic24fj64ga004 programs, changed my include to the 002 and it compiles fine. This is with both 4.140 and 5.011
EDIT: This is one reason the forum rules state you provide a complete solution (Which would have been easy to do in your case since all you would have needed was a blank main to show this issue). As it stands, I am mostly certain it is your compiler revision, but you need to follow forum guidelines so we can better help.
EDIT: Looking at the data sheet for the other two pins, I am pretty confident they are the same (PIN_SELECT is correct).
jeremiah
PostPosted: Sun Sep 15, 2013 4:19 pm     Reply with quote
I wanted to separate this post out.
#case
#include <24FJ64GA002.h>
#FUSES NOWINDIS                 //Watch Dog Timer in Window mode
#FUSES NOJTAG                   //JTAG disabled
#FUSES HS                       //High speed Osc (> 4mhz for PCM/PCH) (>10mhz for PCD)
#FUSES NOIOL1WAY                //Allows multiple reconfigurations of peripheral pins
#FUSES NOCKSFSM                 //Clock Switching is disabled, fail Safe clock monitor is disabled
#FUSES PR
#use delay(clock=22118400)
#pin_select U1TX=PIN_B8   //UART works fine
#pin_select U1RX=PIN_B9   //UART works fine
#use rs232(baud=9600,UART1,errors)
#pin_select SDI1=PIN_B15
#pin_select SDO1=PIN_B14
#pin_select SCK1OUT=PIN_B13
#use spi(SPI1, master)
void main(){
  while(TRUE);
The OP should take this program and try to compile it. If it doesn't compile, then he needs to upgrade. This compiles fine with the latest compiler revision.
PostPosted: Mon Sep 16, 2013 1:18 am     Reply with quote
I can confirm it is a version problem.
If you look at the device database for this chip in this version, the compiler only 'knows' about what it thinks is an I2C/SPI port, with the pins remapped by fuses.
In common with quite few of these later chips, the SPI is actually a separate peripheral, but this compiler doesn't know about it, and so doesn't know that this is re-mappable...
Support for the separate peripheral is there about twenty compiler versions later.
bela
PostPosted: Mon Sep 16, 2013 1:25 am     Reply with quote
Thanks for the replies.
Sorry for not posting full code. However, it's very close to the example you supplied except #use SPI commented out and printf ("Test msg");
The sample code you supplied will not compile:
Invalid pre-processor directive: invalid pin (chip) x3
and
SPI Module not assigned, use #PIN_SELECT
To be honest, I usually do bit banging when it comes to SPI, that's why I haven't come across this yet.
This is fairly fundamental so if it's a compiler bug, I would expect to get a fix for free. What are the chances of that?
Many thanks for all help.
Darren.
alan
PostPosted: Mon Sep 16, 2013 1:40 am     Reply with quote
Good luck with that. Maybe CCS has changed. When I started with v3 and just bought it, I submitted bug reports about twice weekly, after 3 months of this, I still had no working complier and CCS just told me that my maintenance has run out, so sorry.
So I just worked around the bugs for about 2 years, before I finally decided that I would upgrade as I needed new chip support.
Regards
PostPosted: Mon Sep 16, 2013 2:28 am     Reply with quote
I'd say 'no hope' on a bug this old.
The point is that if you as a user had encountered this a few weeks/months after buying, then 'yes'. However for a compiler well over 3 years old. Not really.
It was fixed soon after. The code compiles and works on 4.104.
Given that, if you ask very nicely, they might possibly be prepared to let you upgrade 'cheaply' to a version like 4.141.
It goes back also to the 'takes about ten versions for CCS to get things to work'... Support for these chips, was only added a very few versions earlier.
bela
PostPosted: Mon Sep 16, 2013 7:43 am     Reply with quote
To be honest, so many CCS bugs and issues have tripped me up / delayed projects that I'm about to switch to XC8 / XC16 from the Microchip.
Doesn't look like we'll need the extra optimisation which will set up back a couple of grand.
However, If I don' get time to learn XC before the next software project comes along, it'll back to go old CCS PCD!
I mean, we sell our embedded programming knowledge as a product for money. If the customers knew what a joke our chosen compiler is...
Thanks everyone who helped.
bkamen
PostPosted: Mon Sep 16, 2013 10:09 am     Reply with quote
When you can't do something easily in CCS and have to do it "the long way' -- you'll find you end up doing it just like you'd have to in XC.
Both compilers have their strong points. There's no need to trashtalk.
I can prototype things much faster in CCS than in XC (and yes, I have them *all*).
And then, let's talk about some of the whacky bugs in MPLABX... oh yea.
PostPosted: Mon Sep 16, 2013 10:36 am     Reply with quote
Yes.
XC, simplifies the problems for itself, but not trying to be too smart.
CCS does a huge amount for you, but by doing so, creates extra problems.
Worth realising that you can directly access the pin selection registers and not use #PIN SELECT at all. This is how you have to do it in XC, and it works in CCS.
bela
PostPosted: Tue Sep 17, 2013 1:08 am     Reply with quote
Agreed but some of the things wrong here are pretty fundamental.
And, as you all predicted, CCS have just said it's an old version of the compiler and refused to help me any further.
If I sent out a PCB design with important sections of the circuit not working and then only respond by saying, "you can buy the new version", we wouldn't be in business.
Agreed on MPLABx. only saving grace for me is that it runs on Linux.
Of course, Microchip have introduced the peripheral library which seems pretty tidy but is also in its infant stages so I hope it gets better as I don't have any intention of learning hundreds of register names.
Thanks again.
Douglas Kennedy
PostPosted: Tue Sep 17, 2013 7:20 am     Reply with quote
This remapping via #pin_select is constrained.
First the chip has to support it..I know it is too obvious to be useful advice but it is necessary. Not all pins on a chip are remappable.
Second it must have a RP pin designation by Microchip. RP comes in two forms RPI and just RP.
Third again it may be too obvious but a RPI pin can't be remapped to an output.
EX the spi SDO ( MOSI) can't be mapped to a RPI pin.
Then of course the SPI slave must be electrically compatible.
On 3v parts some remappable pins are 5v tolerant for input some aren't.
Goto page 1, 2  Next
Page 1 of 2
