Another LCD newbie question
mojo_risin
PostPosted: Mon Sep 09, 2013 3:51 pm     Reply with quote
I've been trying to get the 16x2 LCD working for two days now, biggest success being black squares on blue canvas. Here is the code:
// flex_lcd.c
#define LCD_RS    PIN_A2
#define LCD_E     PIN_A3
#define LCD_DB4   PIN_A4
#define LCD_DB5   PIN_A5
#define LCD_DB6   PIN_A6
#define LCD_DB7   PIN_A7
// If you only want a 6-pin interface to your LCD, then
// connect the R/W pin on the LCD to ground, and comment
// out the following line.
//#define USE_LCD_RW   1
#define lcd_type 2        // 0=5x7, 1=5x10, 2=2 lines
#define lcd_line_two 0x40 // LCD RAM address for the 2nd line
int8 const LCD_INIT_STRING[4] =
 0x20 | (lcd_type << 2), // Func set: 4-bit, 2 lines, 5x8 dots
 0xc,                    // Display on
 1,                      // Clear display
 6                       // Increment cursor
void lcd_send_nibble(int8 nibble)
// Note:  !! converts an integer expression
// to a boolean (1 or 0).
 output_bit(LCD_DB4, !!(nibble & 1));
 output_bit(LCD_DB5, !!(nibble & 2));
 output_bit(LCD_DB6, !!(nibble & 4));
 output_bit(LCD_DB7, !!(nibble & 8));
 delay_cycles(1);
 output_high(LCD_E);
 delay_us(2);
 output_low(LCD_E);
// Send a byte to the LCD.
void lcd_send_byte(int8 address, int8 n)
output_low(LCD_RS);
#ifdef USE_LCD_RW
while(bit_test(lcd_read_byte(),7)) ;
#else
delay_us(60);
#endif
if(address)
   output_high(LCD_RS);
   output_low(LCD_RS);
 delay_cycles(1);
#ifdef USE_LCD_RW
output_low(LCD_RW);
delay_cycles(1);
#endif
output_low(LCD_E);
lcd_send_nibble(n >> 4);
lcd_send_nibble(n & 0xf);
void lcd_init(void)
int8 i;
output_low(LCD_RS);
#ifdef USE_LCD_RW
output_low(LCD_RW);
#endif
output_low(LCD_E);
delay_ms(15);
for(i=0 ;i < 3; i++)
    lcd_send_nibble(0x03);
    delay_ms(5);
lcd_send_nibble(0x02);
for(i=0; i < sizeof(LCD_INIT_STRING); i++)
    lcd_send_byte(0, LCD_INIT_STRING[i]);
    // If the R/W signal is not used, then
    // the busy bit can't be polled.  One of
    // the init commands takes longer than
    // the hard-coded delay of 60 us, so in
    // that case, lets just do a 5 ms delay
    // after all four of them.
    #ifndef USE_LCD_RW
    delay_ms(5);
    #endif
void lcd_gotoxy(int8 x, int8 y)
int8 address;
if(y != 1)
   address = lcd_line_two;
   address=0;
address += x-1;
lcd_send_byte(0, 0x80 | address);
void lcd_putc(char c)
 switch(c)
    case '\f':
      lcd_send_byte(0,1);
      delay_ms(2);
    case '\n':
       lcd_gotoxy(1,2);
    case '\b':
       lcd_send_byte(0,0x10);
    default:
       lcd_send_byte(1,c);
And here is the main file:
#include <18F4523.h>
#fuses NOWDT, NOMCLR,NOPROTECT,INTRC_IO, PUT, NOLVP
#include "lcd.c"
void configuration();
main() {
    configuration();
    while (1)
        output_toggle(PIN_A0);
        lcd_putc("\fHello World\n");
    return 0;
void configuration() {
    //CONFIGURATION
    setup_oscillator(OSC_4MHZ);
    setup_adc_ports(NO_ANALOGS);
    set_tris_a(0b00000000);
It doesn't work on breadboard or in Proteus. Now I see I must be doing something really wrong here, but I couldn't find it for ages. Please help me.
Pins are connected like this:
Vss - Ground
Vdd - 5 V
Vo - 10K pot
RS - pin A2
RW - Ground
EN - pin A3
D4 - pin A4
D5 - pin A5
D6 - pin A6
D7 - pin A7
The display is this:
http://www.amazon.co.uk/1602-Character-Display-Module-Blacklight/dp/B009GEPZRE/ref=sr_1_1?s=electronics&ie=UTF8&qid=1378763356&sr=1-1&keywords=16x2+lcd
PostPosted: Mon Sep 09, 2013 4:09 pm     Reply with quote
possible problems...
1) LCD driver is called flex_lcd.c but your program loads 'lcd.c'
I use the flex_lcd driver ,so I know it works but I copied and renamed it to my_flex_lcd.dvr
2) contrast is set wrong..
Usually you need about .5 volts.
3) does the test LED blink at a 1/2Hz rate?
This would confirm the PIC is alive and running right
4) some other internal peripheral is defaulted 'on' or 'attached' to your LCD pins ?
5) Get rid of Proteus.....
hth
jay
mojo_risin
PostPosted: Mon Sep 09, 2013 4:28 pm     Reply with quote
Got it!
I had two pins wired wrong... feel stupid to admit, but that's what was happening. Pins RA6 and RA7 do not come sequentially, RA7 comes before RA6, and I had connected D7 to RA6. Not very bright.
Thanks for the reply! It was you suggestion for an active peripheral that got me to look again at the datasheet. Really, thanks a lot!
