Help with ADC
Martin_P
Help with ADC
PostPosted: Mon Sep 09, 2013 8:36 am     Reply with quote
Hello
I'm trying to work with the ADC now but I have some problems.
I want that a LED lights if the value is under half. But the LED lights allways. So I hope that someone can help me.
I use the dsPIC33FJ256MC710A, the PCD compiler from CCS and the dsPICDEM MCLV development boar.
#include <33FJ256MC710A.h>
#include <stdio.h>
#include <stdlib.h>
#fuses XT,NOWDT
#use delay(clock=8000000)
#define LED PIN_E1
    int x;
    set_tris_e(0);      //LED output
    set_tris_b(1);      //input
    setup_adc_ports(sAN8);
    set_adc_channel(0);
    delay_ms(10);
        x=read_adc();
        if(x<511)
            output_high(LED);
            output_low(LED);
PostPosted: Mon Sep 09, 2013 8:52 am     Reply with quote
two comments
1) normally you don't use adc_clock_internal, check the datashet for when you should...
2) what's the resolution of the ADC ? Normally you have to specify how many bits( 8, 10, 12 depending on the PIC type)
also confirm that your ADC source is 'active' and not 'stuck' either high or low.
hmm..
set_adc_channel(0);
you've setup AN8 but select channel 0 .....
again , check the datasheet, but that just looks wrong...
I'd think set_adc_channel(8); might be right...
hth
jay
Martin_P
PostPosted: Mon Sep 09, 2013 9:00 am     Reply with quote
thank you
that was the mistake
