asadi.siyavash@gmail.com
| 18f46k22 RS232 not work in real test (SOLVED) |
Posted: Sat Aug 24, 2013 6:49 am |
Hi all,
I have a problem with 18f46k22, I simulate it in Proteus it work very well but when I want to do it in real it doesn't work just I see 00 in output of rs232 this is my code:
#include <18F46K22.h>
#device adc=16
//#FUSES INTRC_IO //Internal RC Osc, no CLKOUT
#FUSES NOPLLEN //4X HW PLL disabled, 4X PLL enabled in software
#FUSES WDT_NOSLEEP //Watch Dog Timer, disabled during SLEEP
#FUSES NOPBADEN //PORTB pins are configured as digital I/O on RESET
#FUSES NOMCLR //Master Clear pin used for I/O
#FUSES NOXINST
#use delay(clock=20000000) //Extended set extension and Indexed Addressing mode disabled (Legacy mode)
//!#byte SPBRG =0xFAF
//!#byte SPBRGH=0xFB0
//!#byte TXSTA =0xFAC
//!#byte BAUDCON=0xFB8
//!#BIT BRG16 =0xFB8.3
port_B_pullups(0xFF);
setup_timer_3(T3_DISABLED | T3_DIV_BY_1);
setup_timer_4(T4_DISABLED,0,1);
setup_timer_5(T5_DISABLED | T5_DIV_BY_1);
setup_timer_6(T6_DISABLED,0,1);
setup_comparator(NC_NC_NC_NC);// This device COMP currently not supported by the PICWizard
output_b(0xFF);
printf("hi");
I think i should set some registers, but I don't know anything about it and I don't use it before, I'll be glad to help me,
best regards.
Last edited by asadi.siyavash@gmail.com on Sat Aug 24, 2013 7:11 am; edited 1 time in total |
Posted: Sat Aug 24, 2013 7:11 am |
I solve it,
my problem was in set fuses
correct fuse set is :
#fuses HSH,PUT,NOPROTECT,NOLVP,NOWDT,NOBROWNOUT,NOPLLEN,NOPBADEN |
I don't delete this topic because maybe someone like me will have same problem. |
Joined: 01 Jul 2010 Posts: 9637 Location: Greensville,Ontario
Posted: Sat Aug 24, 2013 11:26 am |
Now you know WHY regulars here do NOT use Proteus !!
It cannot properly simulate even very,very simple code.
Do yourself a big favour, delete and NEVER reinstall it.
jay |
Posted: Sat Aug 24, 2013 12:15 pm |
Can I say, why do people refer to Proteus, when they mean Isis....
Proteus, is a very good schematic PCB package. I use it. It has an attached simulator (Isis), which is also competent for analog simulation. It also links to a PCB drafting package (Ares).
The first problem with Isis, is that PIC's are just too varied for it. For example the rules that work for the I2C on one PIC will be wrong for another, but the supplied rules don't cope with this. Biggest problem though is that it takes what you tell it as gospel. If you say "I'm using a 10MHz clock", it'll accept this, even if the selected oscillator fuses haven't got a hope of working. It also has more complex problems when you use a lot of peripherals. Often telling you things won't work, when they are from working chips, or that they will, when the decoupling is incompetent....
It will work for basic PIC configurations, if setup correctly, but these are the ones that any experienced PIC user would know without trying. Unfortunately for anything more complex, it is likely to mislead you. It is too easy to generate configurations that won't work in the real world, but run in the simulation.
I have Proteus, Ares, and Isis. I use Proteus and Ares to draw PCB's. I will sometimes use Isis rather than Spice for analog. However Isis and the PIC, I consider 'useless'.
Unfortunately a large number of educators seem 'unaware' of it's limitations, and encourage students to use it.
