DS1307, send me bad values....
aasanchez
PostPosted: Tue Jul 02, 2013 2:40 pm     Reply with quote
Hi, greetings, now i have a problem please if you could help me, this gonna be wonderful.
I trying use a DS1307 clock, and i use this lib: http://www.ccsinfo.com/forum/viewtopic.php?t=23255 but in the serial port monitor, (included in this compiler, this is the result
45 85 85
45 85 85
45 85 85
45 85 85
45 85 85
45 85 85
45 85 85
Obviously this values are wrong, but i cant find the error... please could you help me
This is the code:
#include <18F4520.h>
#FUSES HS
#FUSES NOWDT                //No Watch Dog Timer
#FUSES NOPROTECT
#FUSES NOLVP                //No low voltage programing
#use delay (clock=20000000) //Fosc=20Mhz
//Configuracion RS232
#use fixed_io(c_outputs=PIN_C6)
#use rs232(baud=9600, parity=N, xmit=PIN_C6, rcv=PIN_C7, bits=8, stream=RS232)
#include <ds1307.c>
void main(){
    BYTE sec;
    BYTE min;
    BYTE hrs;
    ds1307_init();
    //Set date for->15 June 2005 Tuesday
    //Set time for->15:20:55
    ds1307_set_date_time(15,6,5,2,15,20,55);
    while(TRUE){
        ds1307_get_time(hrs,min,sec);
        printf("%d %d %d",hrs,min,sec);
        printf("\r\n");
PostPosted: Tue Jul 02, 2013 5:29 pm     Reply with quote
hardware...
do you have the correct I2C bus pullup resistors ? typically 3k3r or 4k7r will work.
do you have a battery connected to the DS1307 ? it's needed for proper operation
hth
jay
aasanchez
PostPosted: Tue Jul 02, 2013 5:43 pm     Reply with quote
No have battery, and resitors is 4k7... Thanks a lot...
PostPosted: Tue Jul 02, 2013 7:25 pm     Reply with quote
hmmm.. just noticed you've used 'fixed_io'...
I'd remove that,recompile, and see what happens.
Normally, for 99.999999% of the programs ever seen here, you do NOT need to use fixed_io. Let the compiler handle the 'details' as it sees to.
Unless you need really tight, fast code( not needed here...) using 'fast_io' an cause you 'problems'.
hth
jay
asmallri
PostPosted: Wed Jul 03, 2013 12:41 am     Reply with quote
The DS1307 will not work correctly or reliably with the battery terminal floating (no battery or unconnected battery). During development this can be easily fixed using either a pull up resistor or pull down resistor - it does not matter which.
Regards, Andrew
fatalyric
Re: DS1307, send me bad values....
PostPosted: Wed Aug 21, 2013 1:13 pm     Reply with quote
45 85 85
45 85 85
45 85 85
45 85 85
45 85 85
45 85 85
45 85 85
I have this problem :( Need help pls (I use 18f4580, SDA=B5 SCL=B6 ===> I edited ds1307.c )
PostPosted: Wed Aug 21, 2013 1:20 pm     Reply with quote
1. Don't use pins B6 or B7 for i2c. They are used by the ICD debugger/programmer.
2. Make sure you have a 3 volt battery connected to the Vbat pin.
fatalyric
PostPosted: Fri Aug 23, 2013 9:31 am     Reply with quote
I hate I2C, ahahaha Very Happy
proteus simulator work fine Cool , but real is
45 85 85
45 85 85
45 85 85
Shocked
PostPosted: Fri Aug 23, 2013 9:37 am     Reply with quote
The real problem is that Proteus is NOT working according to the REAL hardware! We all know Proteus is full of bugs, erros, faulty DRCs...
The numbers you show us, tell us, that you do not have a 3 volt battery connected to the DS1307. The datasheet clearly states you MUST have one connected in order for the RTC to function properly.
I've used 1307s for years, have hundreds in the real world, all work fine.
If you still have problems then post your schematic as well as a picture of the hardware setup.
hth
jay
